Lenovo E14 not working on charger works on battery
  • koby058
    • Jan 2017
    • 387
    • israel
    Hello.
    I have this laptop Lenovo E14 AMD
    when connecting type c power, the amp meter shows 20v, for a second it goes up to 0.5 amp and then back to 0.27amp
    the laptop works on battery.
    pushing 12v on PL3 make PU6 get hot, when removed PU6 and pushing 12v no power is pulled by MOBO
    Resistance on PU6 pin 2 is 4ohm
    Any advise how to continue ? do you think replacing pu6 will make it work?
    attached schematic
  • Mugi
    • Feb 2022
    • 13
    • uk
    Hello KOby058.
    How did you fix the above issue ?
    • Mugi
      • Feb 2022
      • 13
      • uk
      The charger is fine and the charger port also is fine. The USB amp meter it showing 19v with 02A. the laptop works with battery power but not main charger .
      Same problem us koby058
      • REpairAT
        • Nov 2020
        • 143
        • Austria
        Just fixed exactly this fault. Replace UT5, NX20P5090UK
        ​Let me know if it worked.
          NVDC charger configuration...
          11-05-2024, 03:28 PM
          ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
          Highly Integrated Narrow VDC Battery Charger for Notebook Computers
          The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
          for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
          Narrow VDC applications where the system power source is
          either the battery pack or the regulated output of the charger.
          This makes the max voltage to the system equal to the max
          battery voltage instead of the max adapter voltage. Operating
          at lower system voltage can improve...
          11-05-2024, 04:43 PM
        • ferah831208
          by ferah831208
          03-18-2025, 01:18 AM
        • flat-earther
          how to prevent a connected charger from draining battery when not charging?
          by flat-earther
          I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
          So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
          but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
          So the battery is backfeeding the charger and being drained.
          How can I prevent...
          08-07-2025, 01:04 PM
        • coasterghost
          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
          by coasterghost
          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
          System Hardware:
          Processor: AMD Ryzen 7 PRO 5850U
          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
          09-08-2025, 10:46 PM
