what is -4232tu, 3111EE etc in hp?
  • masud
    • Jul 2011
    • 317
    • Bangladesh
    what does it means?
    also i am in problem finding bios files of hp 110-3111EE. please help me if the 2mb file you have.
    thanks
  • lezsimply
    The Wanderer
    • 657
    • Philippines
    Re: what is -4232tu, 3111EE etc in hp?
    I think its sub model. try this bios file. update us if it works. thanks
    • khaahk
      • Dec 2013
      • 812
      • Estonia
      The bios needs to be decrypted, here is the correct one:
      Serial numbers need to be added with hp dmi tools.
      • to5it0
        Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
        by to5it0
        Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
        I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
        This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
        I have opened the laptop and identified the main BIOS chip...
        10-24-2025, 01:35 AM
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
      • m1ch43lzm
        Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
        by m1ch43lzm
        Hi everyone
        I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
        Programmer models: XGecu TL866II Plus / T48 / T56 / T76
        Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
        There's also an extra OTP Secu.R...
        09-06-2025, 05:47 PM
      • Forest79
        by Forest79
        However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
        07-23-2023, 07:39 AM
      • maanee11
        Help to get Lenovo BIOS bin file for Thinkpad T560
        by maanee11
        Hello Everyone,
        I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
        https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
        In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
        05-15-2022, 11:59 AM
