IBM T40 cpu fan error after reflow
  • s_henya
    • Jan 2011
    • 482
    • Israel
    Hey,
    Got this laptop, the previous owner had a no video problem,
    So he gave it for repair,
    The tech told him he baked the motherboard in the oven for 10min at 200 derees celsius.
    The no video was solved but then came up fan error problem,
    The client gave up and sold it to me cheap for 30$
    Tested and saw the fan voltages alternating from 5v to 3v every few secs.
    Do you think its worth reparing or ordering a used board for 60$
    already found 2 bad caps, n3p 100 16v had high ESR, replaced them both but with no change.
    any ideas what could be the problem?
  • dj_ricoh
    • 2073
    Re: IBM T40 cpu fan error after reflow
    you got there 3 wires
    yes?
    5v 3.3v ground
    3.3v=100% for 20% = some V
    if you can tell us what voltage you got on the wires will nice.
    like fan pins.
    • Sus256
      HISENSE 65E7KQ PRO - no boot
      by Sus256
      Hi all!
      HISENSE 65E7KQ PRO
      RSAG7.820.13512 - chassis
      MT9618BAATAB - cpu
      RSAG7.820.12059 - power
      HD650Y3U77 - panel
      KLM8G1GETF - emmc
      The TV does not turn on, the standby indicator is on. All voltages are present.
      Emms is dead. Not readable, not detected.
      Replaced emmc.
      But with another dump there is no launch
      Terminal log
      UART
      AC_ON
      RPMB key is not yet programmed
      HASH1_VERSION=0x00000000 64bit
      E-B
      FDE enabled
      layout pattern onebin by SAR7,0...
      06-01-2025, 02:11 AM
    • Superbee_dad
      Sharp 80” long short flash backlight error - Help
      by Superbee_dad
      Hello Sharp TV experts
      Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
      > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
      > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
      01-24-2025, 11:51 PM
    • bpjl
      SEF 551.10 - Error starting the reflow oven.
      by bpjl
      When starting the SEF 551.10 reflow oven, the following problem occurs:
      It seems to me that this is related to corrupted software. Does anyone have files that can fix this device? Or maybe someone uses such an oven and is able to make a sector copy of the memory card located in the computer controlling this oven?
      PS.: Of course, appropriate emails for help have been sent to the manufacturer and distributor in my country. No response yet, but I don't expect much. It's a fairly old device and from what I know, it's no longer...
      10-17-2024, 06:30 AM
    • Curtissimo
      HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
      by Curtissimo
      Hi everyone.
      I have a HP Elitebook 850 G8.
      Serial: 5CG2324XM0
      ProdID 6L8D5EC#ABA
      It has a Winbond W25Q256JVEN Chip.
      I need to remove BIOS Password.
      I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
      Attached my dump.
      I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
      I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
      What I did:...
      08-26-2025, 04:42 AM
    • Maalobs
      Philips 60PFL8708S/12 - QFU1.2E LA - Error code 53
      by Maalobs
      I have a 2014 vintage Philips 60PFL8708S/12 that suddenly died in the middle of the kids watching a show.
      The relevant service manual for the chassis is available here.
      The TV no longer powers on, and leaving it powered on for a few minutes results in the layer-1 error with 2 blinks.
      When I short the SDM to ground I get the layer-2 error code 53.
      The inside of the TV has no damaged components and no swollen capacitors.
      In SDM-mode when all the power rails are left on despite entering the protection mode, I tracked down and measured...
      04-02-2019, 01:15 PM
