How to use lab power supply
  • nazrul145
    • Jan 2014
    • 337
    • BD
    Hello boss, how are u? I think everybody is fine. Today i need your help. I think you will be help me how to use lab power supply to find short on laptop motherboard. Pls Share youre knowledge with us and keep update our service line... Thank you.
  • khaahk
    • Dec 2013
    • 818
    • Estonia
    Re: How to use lab power supply
    If you apply voltage across very low resistance then the result must be many amps.
    I apply low voltage (depending on the rail - 1V is mostly enough) and limit the current to 1A and touch by hand, if nothing heats up then it is time to add more amps. If the short is inside a big IC (northbride or smth), then even 3A might turn it only slightly warm. If you give too much amps at once and the short is inside a small cap, then it might burn up and you might get damaged pcb.
    The main point is that you don't need to use high voltage to find shorts.
    I attach the negative lead with alligator clip to ground and for positive lead i use either a alligator clip with needle or if more amps are needed then soldering is required. I used rather thick wire (~2mm diam) to solder the alligator clips to, because if you don't then the wires are going to heat up instead. If any questions - ask and will try to answer
    • nazrul145
      • Jan 2014
      • 337
      • BD
      I am not clear about positive lead connection. negative lead connect with pcb ground? and positive lead use with needle. I m not understand what is needle. pls give me an example, how to connect positive lead for finding 3.3v rail short. please clear me. Many many thanks for reply. wait for reply.
      • Learn2Day
        • Jun 2013
        • 254
        • Portugal
        Needle is a really thin tip. When using many amps you DON'T want to touch the metal, I use a multimeter tip, it's thin enough and provides you some plastic protection..
        One little tip to add, when seeing or feeling heat wasn't working for me, I spread some solder paste around the area, applied current, and the capacitor started bubbling at the bottom almost immediately.
        Good luck!
        Galaxy S6 Edge x2 (Gold&White)
        Asus GL552VW-i7 6700HQ|GTX 960M|15.6"FHD|16GB DDR4|512GB M.2 SSD+1TB SSD
        Clevo W230SD - i7 4710MQ|GTX960M|13"QHD+|16GB DDR3L|500GB+256GB mSATA SSD+1TB HDD
        Try Harder!
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
          07-01-2024, 06:34 AM
          LM358 LM358S-13 Datasheet
          The LM358 LM358S-13 consists of two independent, high gain, internally frequency compensated operational amplifiers which were designed specifically to operate from a single power supply over a wide range of voltages. Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage.
          Application areas include transducer amplifiers, dc gain blocks and all the conventional op amp circuits which now can be more easily implemented in single power supply systems. For example, the LM358 series can be directly...
          10-07-2024, 04:12 AM
        • RichBon
          power supply amps does not read
          by RichBon
          HP ENVY x360 - 15-dr1017tx
          ​i have these board which when turn on power lights on but amps volt is 000
          09-20-2024, 01:14 PM
        • shamsudeen
          Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
          by shamsudeen
          Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
          I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
          i know that in linear power supply the noise will be very low comparing to SMPS supply....
          07-19-2025, 07:14 AM
