Macbook Air logicboard unknown Part? HELP
    Macbook Air 13 Logicboard, does anybody now what this Part is?
    The metal one!
    Thank you !!
    http://www.directupload.net/file/d/3...76pan5_jpg.htm
    Re: Macbook Air logicboard unknown Part? HELP
    Looks like a MOSFET.
    I know, you think I'm crazy huh.
    But, there are some modern SMD mosfets which have a small metal can like this.
    They have quite a low on-state resistance, around a few milliohms.
    Muh-soggy-knee
      Ok a MOSFET ?? This part gets hot...
      Can this part be a smd fuse? i thinkt not?
      How can i find this part?
        it's not a fuse. if it's short, check coils. when u spot the shorted one, remove coil and see wich side. after side well'see
          Ok thanks, wich coils do you mean?
            this coil for exaple i suspect is short as is near the part that is getting hot. check if short and remove it. asfter remove check if short is on A or B. second, give a full image and see what that coil is for : chipset, cpu, video and so on. after that find schematics and well try to spot the coil correspondance on diagram
            ps: better to describe the problem: no power on ? no usb, no video ... what problem has this macbook air ?
            magsafe green ?
            edit: if is macbook air A1370, you should have 7 coils total.
              the macbook won't turn on, nothing.
              mille grazie, for the pic and your describe, i will find the schematic and post it here...
              THE LOGICBOARD IS from a 2010 Macbook Air 13
              PART NR: 820-2838-A MACBOOK AIR 13 A1369
                no problem man, im here to lear too
                once i had a macbook with a hot component. after i said it's hot it's bad and gone for repair, i discovered that it was hot for a short in circuit, so hot= bad it's not the solution. first we need to check for coils, then we see one or other side
                i have a 2009 version of air here for sata zif hard drive change (hope is it )
                  friend i will check it out, and write it here, yes the board has 8 coils...
                  i could not find the schematic...
                    the coil show 0.0 ohm it should be ok??
                      to check coil, black wire to usb metal cover, red to one side a time of the coil. multimeter setup for short (if it has that funcion)or in diode mode. 000 001 002 003... is shorted.
                        Ok it shows 1 and didn't beep!!
                          we need a schematic and see that coil wich one is on it. let's wait for some expert
                            Ok, the board starts now, but screen is only black screen!!
                              Thanks. This helped me learn a bit about checking too.
                                what have you done to make it start ?
                                  it was the intigrated memory it was much of flux under it, the board starts but only black screen...
                                    i look for bios dump 820-3462-A
