HP dv9500 hangs on win7 logo !!
  • SM-Piyes90
    • Feb 2014
    • 120
    • Morocco
    Hello everyone in here .
    I have an old laptop dv9500 model running windows 7 , before i experience this problem , i was having a graphics problem due to bad GPU BGA solder , after that i was still working with it by disabling the GPU , and working with a poor but stable factory resolution .
    Now when i power it on , it stays on the windows logo screen , so i took it to a BGA reflow service in the hope that reflowing the GPU would fix the problem , but it still persists , even after trying another HDD .
    Is anyone familiar with this problem ?
    Could the BIOS be involved or the GPU ?
  • lefos
    • Nov 2013
    • 321
    • Greece
    Re: HP dv9500 hangs on win7 logo !!
    Have you tried any other OS? You can try with a live linux cd.
    It might be from the gpu as you are describing it.
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      The GPU went bad completely. Replacement is the only solution.
      A working TV? How boring!
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Being an HP, the CPU may have failed.
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • SM-Piyes90
          • Feb 2014
          • 120
          • Morocco
          Ok i got the picture .
          Thanks to all of you.
          • theone111
            by theone111
            3. Problem: TV shuts down
            07-22-2024, 10:36 AM
          • MICHAEL_2013
            Change Logo Aptio Setup Utility 2021 (ROM Layout mismatch detected) Problem
            by MICHAEL_2013
            Good afternoon, Lords of great wisdom. My problem is the following: I bought a Chinese laptop with GN117_MB_V31-T board. (Aptio Setup Utility 2021) (There is no info for that board). And I want to change the logo of the bios. I have used Aptio_V Afuwin to do the bios Backup, then I change the logo with AMI ChangeLogo Tool v5.0.0.2 and everything seems perfect. But when you restart the new logo appears ok. But it automatically enters the bios, appearing a new option RECOVERY, ROM LAYOUT MISMATCH DETECTED - PARTIAL UPDATE IS NOT ALLOWED. If I give ESC it enters windows without problem but always...
            06-28-2021, 03:12 PM
          • letmealone
            Smart Tech LE-4048SA stuck at SMARTTV logo: problem solved.
            by letmealone
            I had this tv set, stuck at the 'SMARTTV' screen with coloured logo. Impossible to find the original Smart Tech firmware, so i searched in kazmielec.tech some firmware compatible with the tv-set hardware (CV338H-T42 card and Y400HJ6.PE1 screen). The firmware i tried was wrong and it bricked the TV, just showing a black screen and not entering stand by anymore. I supposed it needed special hardware to reflash the NAND, but i was wrong, it just needed a working compatible firmware. Still in the kazmielek page i tried ' CV338H-T42_1920x1080_Telefunken TF-LED43S81T2' and it finally worked. I wrote...
            09-16-2024, 10:03 AM
          • eduwins
            Dell Inspiron15 5000 , stuck on logo ,Bios problem
            by eduwins
            can someone help me to fix this bios, stuck on dell logo,i7 11th gen....
            11-27-2023, 04:38 AM
          • Zeonalbasta
            Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
            by Zeonalbasta
            i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
            The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
            09-13-2024, 01:17 PM
