Dead Iphone 6 plus . İs it repairable?
  • shamzeli
    • Aug 2024
    • Turkey
    My friend has an old iphone 6 plus (dead by liquid damage long time ago), no previous repair trials have done.
    i opened it the first time yesterday.
    My observations ;i am doing reparing things as a hobby, not as a professional
    1- the liquid damage indicator on top is red, the one on the side still white.
    2- no obvious corrosions or blown component (i removed all shields).
    3- no short on pp_batt_vcc neither on vcc_main.
    4- when connecting the charging cable: with the battery connected it draws 440mA fixed, when battery disconnected it flactuate between 30-80mA.
    5- when disconnect everything from the logic board and connect the power supply to battery socket it draws 0 amper, when pressing the power button amperage goes to 90mA then 1-2 second later goes to zero again.
    does it meaning something or i am approaching in the wrong way? do you have any advice?
    thanks in advance.
  • double_DD
    How can I be sure that my EC chip is dead?
    by double_DD
    As the title suggests, how can I be sure that my EC chip is really dead?
    I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
    Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
    03-12-2025, 07:47 AM
  • disorder
    ps5 edm-033 dead after hdmi/usb ports destroyed
    by disorder
    hello guys,
    i need help to repair a edm-033 ps2
    history : as always hdmi port and usb ports destroyed after unplugged
    after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
    so i changed it
    now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
    but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
    i don't see any projection of liquid metal on pcb.
    01-14-2025, 12:48 PM
  • abbas101
    Iphone 6 Dead - Diagnosis
    by abbas101
    Dear All
    My iphone 6 is dead and not charging. I never diagnose mobile phones in my life before but would like to do this time and therefore need help. At initial I found this
    1. Battery is OK
    2. Using USB power meter I found that mobile is drawing .5 amp and then went to zero and repeat this pattern. at battery terminal there is no short.
    What should be my next step?
    10-20-2020, 03:30 AM
  • zunasthegreat
    Chieftec GPS-450-AA with dead 20N60C3
    by zunasthegreat
    Hello everyone hope all doing well!
    I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
    09-01-2024, 07:12 PM
  • Beton
    Finding a dead short component
    by Beton
    Hi guys!
    I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
    So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
    I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
    I have a bench PSU and if I try to inject voltage the voltage...
    12-10-2021, 01:05 PM
