A1708, 820-00875 20V 0.0185A
  • Theking3737
    • Aug 2024
    • 9
    • Netherlands
    I have a A1708, 820-00875, in front of me that doesn't turn on and my ammeter says 20V and 0.0185A. The person I bought it from told me that it turns on occasionally but crashes and after that it's hard to get it to power on again. So far I couldn't get it to power on at all. I opened it up and removed the logic board. I measured 0.015V at PPBUS_G3H with a resistance to ground of 2.2 Ω. I then measured the resistance between PPBUS_G3H and L7420, L7410 and L7430 and those are basically all shorted at 0.4 Ω. The resistance for all the other inductors seems fine.
    I suspect U7420, U7430 or U7420 could be dead. I think lifting L7420, L7410 and L7430 one by one an checking if the short is gone is the best course of action, am I right?
    I do have a donor board that still has a bunch of these chips on them and I hope they still work. Although it being shorted to PPBUS_G3H kinda worries me.
  • mon2
    • Dec 2019
    • 14368
    Remove all power. Flux and remove the fuse @ F7000. Measure the resistance to ground on each side of the removed fuse using the PCB pads.
    Which side is with the low resistance to ground of 2R2? If the downstream / consumer side, then power up again and check the voltage to ground of PPBUS_G3H as created by the ISL9239 controller. Is this voltage stable?
    With no power, measure the resistance from the downstream side of the F7000 fuse to any inductor on the board. Keep testing each inductor for a low resistance path from PPBUS_G3H (F7000, pin 2). If you find a low resistance value then that high side mosfet is most likely leaky and may have caused damage to that power rail. Post all suspects. Hoping it is not the CPU rail.
    • Theking3737
      • Aug 2024
      • 9
      • Netherlands
      I removed F7000 and noticed a very low resistance on L7420, L7410 and L7430 (all were at 0.4 Ω). The rest seemed fine. I then removed L7430 and L7410 (read about it on another post). After removing L7410 I noticed that the short was gone. I thought this could mean that U7410 was dead. So I decided to replace U7410 with a chip that I got from a donor board. After replacing it the short was gone!
      I plugged in the ammeter and it showed that it was pulling a few hundred milliamps. PPBUS_G3H was also back at 13V. I decided to put it back into the case and test it out. I pressed the power button and the fan started to spin, the touchpad was clicking again and the ammeter showed more than 2.6A at some point. But sadly no display, also not on an external display using a dongle. I even tried a different case with a different display, but still the same result. The light on the caps lock button also doesn't seem to work and I never heard the MacBook chime.
      • mon2
        • Dec 2019
        • 14368
        Measure the voltage to ground of ALL_SYS_PWRGD.
        • Theking3737
          • Aug 2024
          • 9
          • Netherlands
          I measured ALL_SYS_PWRGD (on R7806) at 3.19V. When measuring, the battery was not connected and I saw fan spin.
          • mon2
            • Dec 2019
            • 14368
            A logic '1' at this signal implies that all power rails are OK. Is the fan running at all times or only briefly? Is the fan spin 'normal speed' or crazy high to cool down burning cookies speed? If crazy high, then some sensor detection has failed which is often from the sensor(s) inside of the trackpad.
            • Theking3737
              • Aug 2024
              • 9
              • Netherlands
              The fan spins briefly after pressing the button. If it spins, it spins quite slowly, I'd say it's inaudible. I also tried putting the board in a different case with a different screen, trackpad, keyboard, etc. It made no difference.
              • mon2
                • Dec 2019
                • 14368
                Do wait on other comments but suspicion is that the first post mentioned a low resistance to ground on PPBUS_G3H. Your investigation led you to the multiphase power supply linked to the GPU via U5410 / L7410. By replacing U5410, the short on PPBUS_G3H was removed.
                This means that the high side of U5410 (internal mosfet) was leaking so the original ~13v travelled onto the GPU power rail and often this is not good news as this will kill the GPU. A dead GPU will result in no video.
                • Devin Anderson
                  A1708 820-00875-A bios
                  by Devin Anderson
                  i have a a1708 efi lock and cannot enter dfu.
                  Model: Macbook Pro Late 2016
                  Model Number: A1708
                  Serial Number: C02SQDCEGVC1
                  Board id# 820-00875-A
                  EMC2978
                  i need to unlock efi please...
                  10-06-2024, 06:34 PM
                • fozzo
                  Macbook Pro A1708 820-00875 No boot
                  by fozzo
                  Hello Guys,
                  I have a 820-00875 board here which is not booting. Fan spin for some seconds but no boot, actually I saw it booting once but then after putting passcode screen became black and system freezed.
                  History
                  Mac was working normally and then system freezed with a screen glitch. The customer then rebooted it and it started but stop after he put passcode (same behaviour wich I saw once. No prior repair on motherboard just a changed battery some months ago.
                  Diagnosis
                  Checked all power lines all present as well as ALL_SYS_PWRGD that sits at 3.3V. ...
                  05-19-2022, 02:35 AM
                • dbuergi
                  MacBook A1708 820-00840-a speaker making strange noises
                  by dbuergi
                  i fixed a A1708 which was not working. Not its booting but the left speaker is making buzzing and sizzling noises. I added a short video to show it.
                  https://www.dropbox.com/scl/fi/ju6v7...=lewlrdkh&dl=0
                  I already reflowed the audio codec chips but that didn't help. Any ideas what to do?
                  06-02-2025, 11:20 PM
                • ahoonid
                  A1708 820-00840 No boot - trackpad clicks - 20V 0.55amp
                  by ahoonid
                  Hi everyone.
                  I have MacBook Pro A1708 with a confusing issue.
                  The laptop doesn't turn on. Strangely, the trackpad clicks and fan spins. Caps lock doesn't turn on and no chime.
                  Initially, the amp meter didn't turn on at all on one of the usb c ports. On the other port, I got 20V and half an amp tho (no battery connected).
                  I replaced the bad CD3215 chip and now it works as well. Both ports turn on with same amp readings.
                  The initial issue however remains.
                  No boot. No backlight. No chime. No keyboard. Only signs of life are clickable trackpad...
                  05-10-2025, 04:19 PM
                • EpicFix
                  MacBook Pro A1708 820-00840 stuck @ 5V, no power, no charging
                  by EpicFix
                  Hey guys, I need a little help here. I have a MacBook Pro A1708 820-00840 stuck @ 5V. Started off affecting just one port but now it's affecting both. Both CD3215 ics were replaced but the issue remains. One port does a loop and the other stays at a constant 5V. Both CD3215 have 3V incoming. I checked for PP3V3_G3H @ R3000, C3100 and C3108, R3001, C3200 and C3208. The weird thing is though that the ammeter shows the current draw (5V @ 0.5A) coming out from the port as opposed to it going in. Any ideas on helping me fix this?
                  04-08-2025, 09:55 AM
