No Power on GPU - Cpu heats up lights + fans - no display
  • cekcons
    • Mar 2022
    • 15
    • turkey
    I can not find the exact model of the board since its a rebrand of clevo.
    If i am correct it has 6/7 gen i7 with gtx 950m
    I already replaced uP1642P on it at gpu side that controls gate.
    Gpu has two power mosfets. I take out both. Seems fine ( both 87350d)
    Even both is outside still gate gets shorted to ground when power is on instead of 5v.
    When i give 1.1v on gpu side it draws 0.6 A or so. Heats up slightly.
    I am bout to lose my mind. Please help.
  • rogfanther
    • Jul 2006
    • 458
    • Brazil
    Pictures, please, from both sides of the board.
    • cekcons
      • Mar 2022
      • 15
      • turkey
Name:	WhatsApp Görsel 2024-08-24 saat 10.35.28_c3cc17f8.jpg
      • joesmoe91
        Dell Precision 5530 15" died to blown chip. Replaced chip and now only get momentary fans, lights, no screen or boot
        by joesmoe91
        My Dell Precision 5530 turned off suddenly when I was running Matlab and wouldn't turn on, show any lights, fans, and/or any signs of activity at all. I opened the case, removed the battery and looked at the board with a thermal camera while the AC adapter was connected. I saw that PU1252 was >120C so figured the chip had died on me Got the part number off the attached schematic (see Mouser link below) and replaced the chip. After replacing the chip the board (connected to AC adapter) was able to briefly power on, spin the fans a little bit, and turn on the front led lights....
        02-22-2024, 07:38 PM
      • emil_t
        RTX3090 working fine but fans not spinning
        by emil_t
        Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
        04-12-2024, 06:54 AM
      • Vanillaboard
        MSI Z390 MPG Gaming Plus wont start. No lights no Fans
        by Vanillaboard
        MSI MPG Z390 Gaming Plus - 15.2V on GPU ATX Connector, Now Board Won't Start
        I was experimenting with my MSI MPG Z390 Gaming Plus motherboard and accidentally applied 12.5V to the GPU ATX connector. The motherboard immediately powered off, and now it won't start anymore.
        The graphics card seems to be fine, so no issues there.
        I've measured the voltage at JFP1, and I'm getting 3.95V, as well as on the PS_OUT# pin of the SuperIO. As far as I know, these should be at 5V in standby, right?
        Now my question is: where exactly do these...
        10-18-2024, 02:40 PM
      • b-slayer
        Asus Strix-G15-G513RM fans don't work
        by b-slayer
        I have an Asus Strix-G15-G513RM, who starts normally, but as the fans don't work, it stops and is really really hot,
        The Bios was the latest one, (327), but I managed to downgrade it to version 325 to see if it changed something,
        (as I read somewhere that a corrupted bios can explane my problem), but nothing, it just went full blow during the downgrade,
        (so now, i can say that the fans are fonctionnal), but as it restarted, the fans won't turn at all again.
        ah, and in the Bios, even when the temperature is really hot, the fan are a 0 rpm,...
        09-04-2025, 04:58 AM
      • JayPoorJay
        Hot Water Rad - A Few ECU Fans and a Timer Switch
        by JayPoorJay
        Good Afternoon, Good People.
        I know this will be an elementary little project for most if not all of you, but I thought I would write a post and get put on track, rather than bumbling my way through it with all kinds of trials and errors.
        I REALLY would appreciate y'alls help.
        This is the problem - My wife and I purchased a big ol Victorian/Colonial House in NYC two years ago. The kitchen is surrounded on 3 sides by exterior walls, there is also a 1/4 of the kitchen floor (ceramic tiles) that has a crawl space underneath, and the kitchen gets FREEZING cold...
        10-29-2024, 12:54 PM
