samsung np-rv508
  • mazloum
    • Sep 2012
    • 504
    • Lebanon
    samsung np-rv508
    Hello
    this samsung scala_15ul rev: mp1.0It came to me with no charging but works great on battery if charged on another laptop:
    i found isl6255 very hot, so i changed it. now the charge is good but got a new problem:
    if i plugged the ac the battery will charge , and then if i remove the ac , the battery will still indicates that it is charging. and the power adapter led is on even if no ac source. and the battery will drain even if the laptop is off
  • mazloum
    • Sep 2012
    • 504
    • Lebanon
    Re: samsung np-rv508
    i replaced the isl6255 again but this time with one from another damaged board. it works fine
    thanls all
    • razenxd
      How can I charge that battery pack?
      by razenxd
      it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
      At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
      Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
      Now, I have noticed a few things.
      The "dead" battery, while connected to charger and NOT Charging will...
      12-05-2024, 06:11 AM
    • guruji
      samsung galaxy book 3 np940xfg battery charge
      by guruji
      hello
      I have a samsung laptop galaxy book 3 np940xfg board is BA41-03013a venus3-14.The laptop turns on when connected with battery but the battery has random charging it charges till 70% and then it starts going in reverse the percentage.removed the board and disconnected the battery and attached the 65watt adapter the boot rom for tbt 3v is absent and the laptop does not power on. another strange issue in both the usb-c ports when you reverse the cable the power indicator light does not glow.they using a common dual port CYPD6228-96bzxi and 2 thunderbolt chips intel JHL8040R.
      my...
      08-14-2025, 08:12 AM
    • ruletero
      Acer a515-43 low battery charge voltage
      by ruletero
      Hi
      Acer A515-43
      LA-H801P
      Fail: Does not charge battery, has low voltaje on connector.
      Laptop didn't want to turn on, only charge led blinked.
      I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
      I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
      Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
      10-24-2022, 02:31 PM
    • Klevjetack
      Charge a L19D3PDA battery externally from the laptop
      by Klevjetack
      Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
      03-05-2024, 07:26 AM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
