A1990 DEAD
  • Arshad alam4659
    • Aug 2020
    • 156
    • India
    A1990 DEAD
    I Have a a1990 820-01041-a no power
    PP3V3_G3H_RTC_X= 3.3v
    PP3V3_UPC_TA_LDO=3.3v
    PPBUS_G3H=12.4v
    dc is showing 5v stuck 200 ma
    what problem anyone help
  • mon2
    • Dec 2019
    • 14208
    Are you power cycling?
    4v88 is considered low. Check the cd3215 - each ldo on these parts must be working.
    Review this thread:
    https://repair.wiki/w/MacBook_Pro_A1...k_at_5V_repair
    • Arshad alam4659
      • Aug 2020
      • 156
      • India
      Review this thread:
      yes one cd3215 was bad i was changed cd3215 now condition normal 20v
      but also no power on can you suggest what next check
      • mon2
        • Dec 2019
        • 14208
        What is the current draw now? Do you have power cycling? What is the voltage to ground of ppbus_g3h?
        • Arshad alam4659
          • Aug 2020
          • 156
          • India
          PPBUS_G3H =12.5V
          • mon2
            • Dec 2019
            • 14208
            Measure the voltage to ground of ALL_SYS_PWRGD. You may measure at TPC4F9.
            Also, interested in the voltage to ground of:
            SMBUS_3V3_BATT_SCL
            SMBUS_3V3_BATT_SDA
            • Arshad alam4659
              • Aug 2020
              • 156
              • India
              SMBUS_3V3_BATT_SCL
              SMBUS_3V3_BATT_SDA
              SMBUS_3V3_BATT_SCL=3.40V
              SMBUS_3V3_BATT_SDA=3.40V
              • Arshad alam4659
                • Aug 2020
                • 156
                • India
                ALL_SYS_PWRGD​= 0V
                • mon2
                  • Dec 2019
                  • 14208
                  This means that at least one of the power rails is not good. Remove all power / no battery. Meter in resistance mode.
                  Measure the resistance to ground of each and every inductor (usually grey in color; 2 leads) to ground. We are checking for a low resistance that may indicate a defective or shorted part is on that rail. If there is an excessive current draw, that local rail will shut off and cause the ALL_SYS_PWRGD line to be stuck low '0' = 0 volts.
                  Post all suspects.
                  • Arshad alam4659
                    • Aug 2020
                    • 156
                    • India
                    Post all suspects.
                    P5VUSBCT_R=0L
                    P3V3G3H_VSW=0L
                    PP0V95_S0_CPUVCCIO_REG_R=54.1OHM
                    CHGR_PHASE2=0L
                    P1V2_PHASE=0L
                    PPVIN_S0SW_LCDBKLT=0L
                    VR_PHASE_GPU_VDDCI=28.7OHM
                    GPUFB_LL=0L
                    PPVCORE_S0_GFX_PH1=1.7OHM
                    PPVCORE_S0_GFX_PH3=1.7OHM
                    PPVCCSA_CPU_R15.5OHM
                    PPVCC_CPU_PH3=2.1OHM
                    PPVCC_CPU_PH2=1.9OHM
                    PPVCC_CPU_PH1=1.9OHM
                    PPVCCGT_CPU_PH2=4.7OHM
                    PPVCCGT_CPU_PH1=4.7OHM
                    DID I POST CORRECTLY
                    • mon2
                      • Dec 2019
                      • 14208
                      Low voltage rails will feature low resistance to ground by design. To me, the resistance check looks ok.
                      With no power to the board, measure the resistance from PPBUS_G3H to each inductor on the board.
                      Post any measurement that is low in value which means the high side mosfet has leaked.
                      • Arshad alam4659
                        • Aug 2020
                        • 156
                        • India
                        OK SHOP IS CLOSING TIME I WILL UPDATE TOMORROW THANKS
                        • mon2
                          • Dec 2019
                          • 14208
                          I believe that you will be missing the PP1V8_S5 rail? Facing a similar issue on an iMAC 2017.
                          Remove all power. Meter in DIODE mode. Red meter probe, yes red to ground. Black meter probe to the point to test.
                          Measure the PP1V8_S5 rail using DIODE mode. Post the measurement. We are checking if there is a possible shorted part on this rail.
                          More...see here:
                          A1989 (820-00850-A) - S5 rails missing : r/mobilerepair (reddit.com)
                          Your case may be the same - corrupt T2 firmware. Somewhere on this forum are dumps of the T2 eeprom that you can consider to review. Backup your image (just in case) -> apply the dump for your machine from the forum and test again.
                          Download the dumps from post # 17:
                          BY-U301 software and usb rom files requested - Badcaps
                          Continue to post your progress.
                          • Arshad alam4659
                            • Aug 2020
                            • 156
                            • India
                            no beep inductor with ppbus_g3h
                            • Arshad alam4659
                              • Aug 2020
                              • 156
                              • India
                              More...see here:
                              diode mode
                              PP1V8_S5=0.345
                              volt
                              PP1V8_S5​=0v
                              • Arshad alam4659
                                • Aug 2020
                                • 156
                                • India
                                More...see here:
                                i have no programmer U301
                                I HAVE SAME board 820-01814-a can i swap this chip working board
                                • Arshad alam4659
                                  • Aug 2020
                                  • 156
                                  • India
                                  can this be done by doing dfu mode
                                  • mon2
                                    • Dec 2019
                                    • 14208
                                    Yes, can be restored with DFU.
                                    Yes, can be swapped with a known good chip.
                                    • Arshad alam4659
                                      • Aug 2020
                                      • 156
                                      • India
                                      not working 5v stuck
                                      • Arshad alam4659
                                        • Aug 2020
                                        • 156
                                        • India
                                        and again swapped with original but also stuck in 5 vlt how
                                        • thedirekter
                                          A1990 Dead, Odd Voltages on USB-C, Nothing on AWAKE's
                                          by thedirekter
                                          Hey all,
                                          Been lurking for a while to find a solution to my dead A1990 (board # 820-01326-05, I can't find a bv for that one so I've been using 820-01041 for reference) but have come up empty handed. I haven't really done any diagnostics on electronics like this though so I'm sure I've probably missed something. I've soldered and diagnosed keyboards and cars but this is definitely new to me.
                                          My overview thus far:
                                          After browsing the web one night, I closed the lid while it was on the charger, left it on my desk overnight and it was dead in the morning. No response...
                                          01-02-2024, 11:32 AM
                                        • Cemal Odabasioglu
                                          MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                                          by Cemal Odabasioglu
                                          I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                                          Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                                          Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                                          Observations...
                                          01-14-2025, 03:54 PM
                                        • robka
                                          MacBook Pro 2018 - A1990 Dead - not charging - only 5V
                                          by robka
                                          my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
                                          I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
                                          The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
                                          After that the Macbook was dead. It isn't charging anymore.
                                          The USB-C Port where the charger was plugged is burned. Also The Cable and the...
                                          03-02-2024, 02:58 PM
                                        • JoeDeeS
                                          Macbook Pro 15" 2019 (A1990, 820-01814) CD3215 shenanigans
                                          by JoeDeeS
                                          Hi! Thanks in advance for taking your time reading this / helping me out .
                                          I have this MB Pro which had a defective CD3215C00Z. After replacing that one, I figured out that I needed to replace the other one as well since I only had CD3215C00 chips (without the Z at the end).
                                          Now the funny thing is where I replaced both the CD3215 chips, it takes 5V ~.32A and the other side that I didn't touch now takes 20V ~.45A (then drops down to .03A).
                                          Do I need to replace the 2 CD3215 chips that I didn't touch as well? Feels so counterintuitive so I'm having...
                                          01-20-2023, 06:14 AM
                                        • pcash0007
                                          Dead 2018 Macbook Pro A1990 820-01041-07 stuck at 5V 0A
                                          by pcash0007
                                          First time looking at a logic board this closely, learnt enough from videos and forums here to be dangerous
                                          I was doing a OS update when the screen went blank at some point. Does not seem to be in DFU mode (checked using apple configurator).
                                          PPDCIN_G3H is 5.16V​
                                          PPBUS_G3H is 0.045V
                                          Resistance between TP_PPBUS_G3H and ground is 23.8 Ohms (which seems low)
                                          F7000 and F7001 seems fine.
                                          From what I learnt seems like there might be short on the down side on PPBUS_G3H.
                                          Is injecting low voltage and see what...
                                          03-07-2024, 06:19 PM
