Mosfet equivalent SM4508NHKP
  • Shulgin
    • Jun 2022
    • 21
    • France
    Hello doctors,
    Can I remplace SM4508NHKP (datasheet) by MDU1517 (datasheet) ? If not good have you any ideas for remplacement ?
    I work on Lenovo Legion Y540, NM-C221 Rev 2.0
    Thank you !
  • Shulgin
    • Jun 2022
    • 21
    • France
    I also have a MDU1514 (datasheet), is it better or worse ?
    • tofik
      MOSFET equivalent K8A60DA
      by tofik
      Hello guys,
      I have a shorted MOSFET K8A60DA with the following characteristics:
      Type Designator: TK8A60DA
      Marking Code: K8A60DA
      Type of Transistor: MOSFET
      Type of Control Channel: N -Channel
      Maximum Power Dissipation (Pd): 45 W
      Maximum Drain-Source Voltage |Vds|: 600 V
      Maximum Gate-Source Voltage |Vgs|: 30 V
      Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
      Maximum Drain Current |Id|: 7.5 A
      Maximum Junction Temperature (Tj): 150 °C
      Total Gate Charge (Qg): 20 nC
      Rise Time (tr): 25 nS
      Drain-Source
      07-19-2023, 05:18 AM
    • dreico33
      AON7403 Mosfet Equivalent
      by dreico33
      Hellow guys,
      I am trying to replace an AON7403 Mosfet but i dot not have in my stock the same. So i wonder if there is any equivalent to this Mosfet.
      Thank you very much.
      11-16-2024, 09:28 AM
    • Jane
      How do you test MOSFET in laptops ?
      by Jane
      I tried to use this method:
      Testing an N-channel MOSFET:
      Step 1: Discharge the Gate (turn off the MOSFET)
      Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
      Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
      Step 2: Charge the Gate (turn on the MOSFET)
      Now, place the red probe on the Gate (G) and the black probe on the
      09-27-2024, 03:31 AM
    • mohamed mm
      looking for equivalent mosfet for (IR3598MTRPBF)
      by mohamed mm
      I'm looking for an equivalent dule mosfet for (IR3598MTRPBF - Dual MOSFET Driver, High Side, and Low Side, 4.0V to 13.2V Drive voltage, 20 ns delay, QFN-16)
      it's for motherboard ram voltage.
      I hope someone can help me.
      Thank you.
      11-01-2023, 07:28 AM
    • jackx
      equivalent MOSFET 4C09B
      by jackx
      hello brother
      i need equivalent MOSFET 4C09B
      05-27-2024, 03:41 PM
