MacBook Air A2681 M2 for repair
  • princepal
    • Feb 2019
    • 33
    • india
    today I received MacBook Air A2681 M2 for repair. The MacBook is working have a startup sound and charging sound but no video on the screen I checked the backlight voltage which is 0V then I checked the backlight ic enable there is 0V on anyone please help me.
  • PITERPENY
    • Jul 2023
    • 461
    • Ukraine
    My actions would be the following: try another display that is known to work, if it doesn’t help, I would try to check the connection to an external monitor with and without a connected display
    • mon2
      • 14547
      The trackpad contains a hall effect LID sensor. When the lid is considered to be OPEN, the display backlight is enabled.
      Carefully check the voltage to ground of IPD_LID_OPEN_1V8.
      • princepal
        • Feb 2019
        • 33
        • india
        thanks for your help. a customer go the service center and replaced new screen and now the MacBook works
        • mon2
          • 14547
          Thanks for the update. I believe there is a lid angle sensor in the display that may have played a role in this fault.
          • PITERPENY
            • Jul 2023
            • 461
            • Ukraine
            I thought it was a problem with the display! Was it possible to restore Truton on the new display? They say you need to move the camera from the old display to get the Truton back!
            • ChaosLegionnaire
              by ChaosLegionnaire
              09-13-2022, 09:02 AM
            • computeka
              Macbook Air A2337 820-02016-07 No sound problem
              by computeka
              How about everyone, I have a MacBook Air which did not turn on, it had a lot of corrosion on the card where the sound plug and the fingerprint go, I have replaced it and the device now turns on but has no sound, if I connect a headphone through the plug, yes There is sound but the external speakers do not sound....
              05-08-2024, 10:26 AM
            • Comp_Pro
              Macbook Air 820-00165 Static Chime Sound
              by Comp_Pro
              Hello all,
              I have a weird issue to solve here. This macbook air came in showing a black screen even though the backlight was lit. The display was not the issue as I tried another known good display. Upon trying to restart it, sometimes it boots up but freezes at the login page. More commonly however, the macbook will give the chime sound but then get stuck repeating the sound. The first chime sound is normal but the subsequent chimes sounds are crackly. Voltages seem normal, no liquid damage. I did find a blotch of something near one of the crystals on the other side of the CPU...
              11-02-2023, 03:23 PM
            • tommy97
              Apple MacBook A1707 No Audio/Sound
              by tommy97
              I'm having an issue with an A1707 MacBook Pro—there's no audio output. Initially, the MacBook came in with a no-power problem, and I found a faulty U6400, which I've now replaced. The laptop now powers on, but there's still no sound.
              I've also replaced U6300, but the problem persists.
              Here are the current voltage readings:
              • PPV18_S0: 1.8V
              • R6402: 1V
              • R6405: 1V
              • R6403: 1V
              • AUD_SPKRAMP_RESET_L: 1.3V
              • PPBUS: 12.6V
              03-10-2025, 11:22 AM
            • Jamey021
              Yep...I broke it MOAR after fixing it. a2681 MacBook Air
              by Jamey021
              So, what are the odds I shorted the M2 CPU? I got in an a2681 MacBook Air. Liquid damage. Ordered from China and replaced a chip (APL109D 343S00555) cleaned corosion and ultrasonic..The whole 9 yards.
              Last night I put it all together and it came on beautifully. 20V- Apple Logo. I celebrated and knocked the LCD connector loose right away while holding the laptop. Now, it wont boot and it cycles on the volt meter.
              Cycle 20v - .02a then volt meter goes off, then it comes on and rinse and repeat. Classic sign of a MacBook short. I looked at the board with my thermal camera and I can...
              01-22-2025, 05:22 AM
