Dell N5110 Uma help
  • pakv
    • Dec 2020
    • 23
    • Türkiye
    Dell N5110 Uma help
    Friends, I searched on the internet and can you help me with the methods there?
  • pakv
    • Dec 2020
    • 23
    • Türkiye
    plz help
    • mon2
      • Dec 2019
      • 14662
      See attached.
      • pakv
        • Dec 2020
        • 23
        • Türkiye
        mon2 I did not understand anything
        • piernov
          • Jan 2016
          • 4439
          • France
          https://www.badcaps.net/forum/troubl...33#post1258433
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            The graphic conversion is already posted by me as highlighted by piernov. use forum search before posting.
            • Achille15
              Dell N5110 problem
              by Achille15
              so, I have this laptop Dell Inspiron N5110 with a heating problem on both CPU (I7-2680qm) and GPU (GT 525m), I tried many solutions, like changing thermal paste every month, using thermal pads on CPU and GPU, even using thermal pads on CPU nearby coils; but nothing worked, just minutes after booting the laptop shuts itself down so I thought it might be a short problem, so I decided to check what's going on, so I went online and some tutorial (general one) said to check inductors in order to find the shorted circuit, after checking (CPU removed), I found the culprit to be...
              03-29-2025, 04:41 PM
              Dell Inspiron N5110 10260-1 Laptop Boardview
              (was .gr file extension but looks like a .brd file so renamed)...
              10-27-2024, 07:31 AM
              Dell Inspiron N5110 Laptop Schematic
              bq24745...
              10-08-2024, 11:59 AM
            • Akhlz001
              by Akhlz001
              09-20-2025, 07:15 PM
            • master3112
              by master3112
              07-29-2025, 01:55 PM
