Macbook Pro M1 (A2338) - Not Charging but Detected and Post
  • bibinskii
    • Jun 2022
    • 7
    • Indonesia
    A client showed up with a Macbook Pro M1 stating that the battery doesn't get charged (no increase in percentage) but still charge. She left me with the battery 25% and still draining. The Macbook is fully functional. I checked with coconut battery and system report. Battery health shows 85% and stating normal condition, no abnormalities. When it is charging, the system says it takes 10 hour to finish charging. I went ahead to charge it for a longer period, the battery just drains (doesn't get charged).
    At first, I thought that this must be a battery issue. I went to replace the battery. But what do you know? It didn't work.
    From a visual inspection, the type C port looks okay. System report also shows the type of charger it is plugged in (so I don't think that there's trouble conecting to the charger).
    I'm at work now, so I don't have physical access to the device. After work I want to pick up ISL9240 from a store that I know. My suspect is from the ISL9240 (U5200). Any other suggestions?
  • mon2
    • Dec 2019
    • 14170
    The power adapter may be underrated. Be sure the power adapter is 100W or more with a power cable that is certified for 100W or more support.
    • bibinskii
      • Jun 2022
      • 7
      • Indonesia
      Nah I don't think thats the issue here. Wouldn't regular M1 A2338 come with 60W adapter?
      • bibinskii
        • Jun 2022
        • 7
        • Indonesia
        I've replaced the ISL9240, the machine still boots and charging, but no effects. I don't have a type-c meter, but stating from coconut battery it only gives 2-3 watts of charge.
        • jipikiller
          • Aug 2020
          • 15
          • arg
          im having a similar problem, did you solve it??
          • mon2
            • Dec 2019
            • 14170
            What is the history of your unit? Any liquid spill?
            Is the battery being detected by the laptop?
            Remove all power. Meter in resistance mode. Measure the resistance across C5260. One meter probe on one side of this part; other meter probe on the other side. What is the resistance in ohms of this part?
            • jipikiller
              • Aug 2020
              • 15
              • arg
              No liquid damage, but kinda dirty overall. came in with a faulty psu, changed that and worked ok for a day and came back with no charging battery, but detected. can see the battery and precentage, works with a charged battery
              strange issue, everything works but the battery starts chargin at first (like a minute when fully booted) and then nothing, just the connected logo. i have another same model working to make somes tests and comparission measurments. tried dfu restore just in case but same problem.
              Will check that first on monday when open the shop.
              • jipikiller
                • Aug 2020
                • 15
                • arg
                resistance in c5260 is 2 ohms
                • mon2
                  • Dec 2019
                  • 14170
                  This is ok. Was the lcd replaced or is the original?
                  There have been cases where the lcd replacement units are causing the charging function to fail.
                  • jipikiller
                    • Aug 2020
                    • 15
                    • arg
                    omg yes it was replaced with an original one, im frying my head with this haha. but i tried with the lcd disconnected and same issue. just does not make sense. heres a video for reference, when boot charge foro 1 or 2 min then stays with the bat not charging just the plugged in logo. mon2
                    • mon2
                      • Dec 2019
                      • 14170
                      Review this thread which may be similar to your case. Was the battery that you tested a known good battery? The battery in the video has quite a number of charge cycles on it.
                      https://www.badcaps.net/forum/troubl...en-replacement
                      • jipikiller
                        • Aug 2020
                        • 15
                        • arg
                        yeah i tried this battery on another working machine and charges ok (charged from 0 to 100% just to be sure thats ok), also tested another OEM battery with 200 cycles and does the same.
                        thanks im cheking that thread right now.
                        • Gueric
                          Macbook Pro M1 (A2338) 820-02020 not charging.
                          by Gueric
                          I returned home from college. My MacBook battery was flat. Plugged it in. Nothing. Won’t boot. Waited for an hour. Nothing.
                          When plugging the charger : 20v at 0.02 amps.
                          pressing any key will make the « low battery » icon show up. Then switch to 5v and 420mA constant. Trackpad clicks, keyboard works.
                          Decided to put the board into another M1 body with a charged battery, it’s booting perfect, still 5v and 420mA tho, and battery is not charging.
                          I diode moded every pin of U5200 and they’re all fine. I know very little about Apple silicon machines...
                          07-23-2025, 01:54 PM
                        • flat-earther
                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                          by flat-earther
                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                          Windows also shows ''Plugged in'' when charger is not connected.
                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                          If I let battery run out and say it has 3% Windows will...
                          06-24-2025, 09:32 AM
                        • drlarsen
                          MacBook Air M1 A2337 battery/charging issue
                          by drlarsen
                          Hello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
                          I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
                          On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
                          After some hours, the battery status did not improve. Restore via DFU did not help.
                          I connected the power adapter to a Kill-a-Watt...
                          07-17-2025, 02:35 PM
                        • robka
                          MacBook Pro 2018 - A1990 Dead - not charging - only 5V
                          by robka
                          my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
                          I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
                          The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
                          After that the Macbook was dead. It isn't charging anymore.
                          The USB-C Port where the charger was plugged is burned. Also The Cable and the...
                          03-02-2024, 02:58 PM
                        • Woodsworth
                          MacBook Pro A2289 no signs of life except clicking trackpad and charging
                          by Woodsworth
                          I hope this is the correct place to post about this device. I originally posted regarding this on iFixit so see the details from that post below:
                          "I'm hoping someone can give their opinion on the symptoms I'm seeing before I spend any more time and put money into this. I got this MacBook from a customer and after looking at it they decided they didn't want it.
                          It doesn't turn on and there's no visual signs of life. I have tried resetting the NVRAM, SMC, power cycling, unplugging the battery, using the charger with the battery unplugged. Removed the...
                          03-15-2024, 04:06 AM
