acer 4752 no power!!!!
  • ry x hunter
    • Jun 2013
    • 184
    • philippines
    hi guys.. i receive a unit acer aspire 4752 and it cant turn on so i decide first to test the charger and its ok.. i decide to check input voltage along dc and its ok but 1 thing bothering me.. i check the output on ic pu4103 and here is the value rt8223mgqw.. ill check the schematic and i found that no 5 volts output on pin 24.. i try to remove it and resoldered again ad power goes on but after i test on and off a several time problem came back its no power again..
    i check all the pin output on that ic but i am not familiar for the voltage that came out. pls helpppp
    here are the reading on the ic what ive got..
    rt8223mgqw
    pin 1-1v
    2-2.3v
    3-2.1v
    4-2.1v
    5-0v
    6-1.2v
    7-3.8v
    8-3.8v
    9-8.4v
    10-3.9v
    11-3.8v
    12-0.4v
    13-0.8v
    14-3.8v
    15-0v
    16-19v
    17-5.2v
    18-3.5v
    19-0.2v
    20-5v
    21-5v
    22-9.9v
    23-2.6v
    24-5v
  • ry x hunter
    • Jun 2013
    • 184
    • philippines
    Re: acer 4752 no power!!!!
    problem fix after i reseat the parts on mainboard but always came back after several test..
    • spleenharvester
      • Mar 2010
      • 913
      Try a BIOS flash. I had a similar problem on an Asus mainboard once where after reseating something or changing a BIOS setting the problem would go away.
      But may be a bit risky if it's really that temperamental.
      Another possibility is a BGA problem or a dry solder joint elsewhere, might be worth doing a mild reflow. Which parts are you reseating?
      Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
      • sasser
        • Dec 2012
        • 364
        • Malaysia
        Anyone have diagram forAcer Aspire 4752 - 2332G50Mn? I touch fet the code number is brand nikos p1403ev and got really hot. Is that culprit on the fet?
        • degutji
          • Dec 2012
          • 173
          • Indonesia
          Try this
