NM-D711 REV 1.0 Please help me
  • yasinknc
    • Dec 2020
    • TÜRKİYE
    The device works smoothly. There was a bios update in windows update. The update has been made and the device is now working, but it suddenly shuts down after 30-40 seconds. The electricity goes out. I tried multiple bios, ec and io software. The situation is the same. The question arises from what? Does anyone have information? please help
    motherboard: nm-d711 rev 1.0
    laptop: lenovo legion 5 pro 16ith6h
  • mon2
    • 14659
    Maybe this thread will help (see post #17 & #18):
    Bios repair Lenovo NM-D711 rev 2.0 - Badcaps
    What is the power rating of your power adapter? Is it the original one recommended for use with this laptop?
    • yasinknc
      • Dec 2020
      • TÜRKİYE
      yes original adapter. The computer was working smoothly. I did all the tests. This happened after the bios update. I am immediately reviewing the information in the link you sent.
      Edit: I tried but the result did not change
      • mon2
        • 14659
        I will conclude that you only need a known good bios for your logic board. Visit the bios forum and search for one or request one if it is not already posted.
        • akwky
          by akwky
          Hi!
          04-14-2025, 01:56 PM
        • TheUser
          Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
          by TheUser
          Hello to everyone ,
          This is my first post here, and i would like to share with you a small story in case you can help me.
          Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
          All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
          I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
          02-10-2024, 02:07 PM
        • lordgeny
          z490-f gaming bricked after bios update
          by lordgeny
          I had to assemble a PC with this Z490-F Gaming motherboard and an i7-1700K CPU. Upon the first boot, the CPU LED was red and flashing. I realized that I needed to update the BIOS. I didn't read the ASUS notice that said, "Before BIOS update, please download Intel ME update tool from ASUS support site, and update ME firmware to Version 14.1.53.1649V1.1 to ensure optimized system settings." I updated the BIOS without doing this, and everything seemed fine until the system performed an Intel ME update and shut down permanently. My attempts to reflash it were unsuccessful. Searching online,...
          11-02-2023, 09:03 AM
        • iMuhtaseb
          A1706 2017 critical update
          by iMuhtaseb
          this board suffered from a bad trackpad and bad keyboard after liquid damage; board was turning on no issues..
          we've replaced the bad trackpad and bad keyboard no issues whatsoever.. during 2nd final checkup we booted to an external macOS and there started the critical update issue; it boots externally but to the internal SSD it shows critical update; tried Wi-Fi tried Ethernet tried Hotspot same thing..
          One weird symptom is it takes too long to power on and show the Apple logo for some reason..
          I've taken a look into the MLB and noticed tiny liquid around Q3100.. its...
          08-13-2024, 08:41 AM
        • al3m0di
          Update bios EFCN58WW to EFCN59WW
          by al3m0di
          Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
          I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
          The BIOS version is EFCN58WW.
          When I turn on the device, it displays the message:
          "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
          The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
          I've tried
          07-29-2024, 10:32 AM
