HP pavillion dv5-1010ev no picture
  • lefos
    • Nov 2013
    • 321
    • Greece
    Hello!
    This laptop powers on but doesn't have picture. It has an ati vga which I've changed with a new one but the problem still exists. I am wondering if anyone has any bios dump for this one please or any other suggestions?
    manufacturer p/n DA0QT8MB6F0 rev f. hp part number : 482324-001
    Thanks in advance.
  • sorinac
    • Jul 2013
    • 123
    Re: HP pavillion dv5-1010ev no picture
    reflow the chipset
    • lefos
      • Nov 2013
      • 321
      • Greece
      Thanks for your reply. If it is the small chipset then I have already done that. Do you think that it is worth to be changed?
      • sorinac
        • Jul 2013
        • 123
        here are the two bios-es that are from hp website
        i believe one is for board with dedicated gpu and other for onboard but i don't know which one. try each if u can
        also i have found the cpu to have gone bad on this model ,also give a good alchool clean on ram and socket
        but is more likely the rs780 chipset to be faulty.
        good luck.
        • lefos
          • Nov 2013
          • 321
          • Greece
          Thanks for the files sorinac. Well found out that the correct bios file is 30F2F38. Nothing changed after flashing the chip. I have seen that the scroll lock led is blinking 4 times. Been searching for self diagnosis but no result. Any ideas ?
          • dellxps15
            • Feb 2014
            • 1591
            • italy
            4 time = vga
            1 time = cpu
            2 time = bios damaged
            3time = ram
            4 = vga
            5= system board
            6= bad bios signature
            • lefos
              • Nov 2013
              • 321
              • Greece
              Thanks for the info. The odd thing is that I have already changed the vga chipset with a new one..
              I am thinking of giving the laptop back. I really don't like those hps..
              • MDY
                • Jan 2014
                • 75
                • Spain
                Did you try new CPU?
                • vinkos
                  • Jul 2013
                  • 51
                  • Netherlands
                  I think your model has two ATI chips .
                  I guess if you change one that maybe you change wrong one !
                  • lefos
                    • Nov 2013
                    • 321
                    • Greece
                    Thanks for your replies. I will try to change the small chipset and inform back.
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      If you don't get the HDD led blinking (system attempting to boot), it's the NB (small chipset) at fault. Don't need to replace, reballing will do.
                      A working TV? How boring!
                      • lefos
                        • Nov 2013
                        • 321
                        • Greece
                        Today I received the chipset and after the change it doesn't blink 4 times but just 1.
                        @dellxps are you sure that one blink is cpu fault? I have checked with other cpu but still the same..
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          1 blink as in blinking continuously, or as in 1 blink and that's it? Reflash BIOS and see what it does.
                          • lefos
                            • Nov 2013
                            • 321
                            • Greece
                            1 blink then again after 5-6 seconds .
                            • dellxps15
                              • Feb 2014
                              • 1591
                              • italy
                              i think 4 blink = vga, while 1 blink is chipset, so maybe a chipset reballing has gone bad?
                              hard to say to that point....lets wait for other suggestion.
                              • sorinac
                                • Jul 2013
                                • 123
                                today i fixed a dv5 board and one mos from the cpu power rail was faulty.
                                check if you have 0.9v on cpu and if the cpu is getting hot
                                • lefos
                                  • Nov 2013
                                  • 321
                                  • Greece
                                  Thanks guys for your time. @ sorinac cpu and gpu get both hot . Anyway I am giving the laptop back to its owner.
                                  • watanirar
                                    • Dec 2018
                                    • 24
                                    • youssoufia
                                    • sergio_av
                                      Acer Aspire E5-571G-52NH powers on, no picture. PCH_ENVDD goes off and on.
                                      by sergio_av
                                      Hi, I'm unexperienced with troubleshooting and I'm not sure how to proceed with this laptop.
                                      Motherboard is A5WAH LA-B991P I think, i5-5200U and nvidia 820m.
                                      When I received the laptop, CMOS battery had 0V. I took it out and all the testing has been done without a CMOS battery and without the main battery plugged in, I haven't been able to see physical damage, burnt or missing components with a quick visual inspection, and no shorts were found.
                                      Laptop charges the battery, powers on when ON button is pressed when powered from charger and when powered from the battery, but...
                                      01-01-2025, 05:27 PM
                                    • KYBOSH
                                      Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
                                      by KYBOSH
                                      Saved this beast from the landfill this weekend.
                                      Manfactured July 2013 in Mexico.
                                      I love working on plasma TVs.
                                      Its been a while but I was lucky enough to find 2 this week.
                                      The TV powers on and stays on but no picture. Havent checked for sound yet.
                                      No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
                                      Will start troubleshooting tonight.
                                      10-17-2024, 01:17 PM
                                    • Tr0ll
                                      by Tr0ll
                                      Original T-con:
                                      First replacement T-con:
                                      10-07-2023, 07:48 PM
                                    • JJAAMM
                                      by JJAAMM
                                      Problem
                                      07-06-2023, 06:01 AM
                                    • burbutsalos
                                      LG 55sk8000 plb ..snow in the middle of screen but can see that picture exists there
                                      by burbutsalos
                                      Hello everyone.
                                      I have this TV set which has this issue. It shows a vertical bar im the middle of the screen.
                                      The panel has 12 cofs and the problem seems to be on the territory of the first cof on the right side.
                                      The tv fires up and you can see a good picture exept that vertical part where multicoloured pixels exist.
                                      The strange thing there is that you can see behind that snow that it shows picture but as if there are these pixels in front so you cannot see clearly.
                                      The effect is there even on a completely black screen.
                                      The screen...
                                      10-21-2023, 02:57 AM
