HP14 - DA0G7GMB8F0 REV.F
  • mon2
    • Dec 2019
    • 13840
    Meter in resistance mode. Measure the resistance from pin #4 (gate) of each of these mosfets to pin #32 of the charger ic. We are trying to locate which one of these mosfets is being driven by the charger ic (BGATE).
    • Darren Hibbert
      • 102
      Ok so Pin 32 to Gate of the 21321 MOSFET is 0.3 ohms
      Looking at that other MOSFET I sent a picture of, I just noticed it has 2 gates so maybe I never measured that one properly. Hopefully the 21321 MOSFET is the one we are looking for.
      • mon2
        • Dec 2019
        • 13840
        Yes, 21321 is the battery mosfet and the resistance check looks to be ok.
        Here is the datasheet for this P-channel mosfet:
        AONR21321 Datasheet | DigiKey
        Locate the high side mosfet driven by the same charger IC. We are hunting for a mosfet that is possibly leaking. The other mosfet found in the earlier post looks to be low in resistance and is a suspect. Review where the pin # 4 of that mosfet travels to the charger IC. It is possible that there will be a current limit resistor between the charger IC pin and the mosfet's gate pin.
        • Darren Hibbert
          • 102
          Ok pin 4 of the top (there are two) QA3112 goes to pin 7 (LGATE2) of the charger IC.
          • Darren Hibbert
            • 102
            Pin 4 of the bottom MOSFET goes to pin 9 (LGATE1)
            • Darren Hibbert
              • 102
              I'm really appreciating your help by the way 🙏🤩
              • mon2
                • Dec 2019
                • 13840
                Continue to hunt for the mosfet mated with the UGATE2 pin on the charger IC using the same method. One meter probe on UGATE2 pin on the charger IC; other meter pin on pin # 4 of the mosfet.
                Once that mosfet is located, proceed to test that mosfet using resistance mode (if manual mode meter, use a higher resistance scale). If you read 'OL' = over limit, switch to a higher resistance scale on the meter.
                Measure the mosfet as follows:
                source (1-2-3) & drain (5-6-7-8)
                source (1-2-3) & gate (4)
                gate (4) & drain (5-6-7-8)
                Post each measurement.
                • Darren Hibbert
                  • 102
                  Ok so UGATE2 of the charger IC goes to the MOSFET in the picture. I'm a little confused by it as it does not have a 1234 drain. Hopefully I've measured right but I'm unsure of the different layout of pins on this chip compared to your traditional MOSFET.
                  Here is what I got with my effort -
                  Source to drain - 0.9 M ohms
                  Source to gate - 3.6 M ohms
                  Gate to drain - 500 K ohms.
                  • mon2
                    • Dec 2019
                    • 13840
                    Good point and bad assumption on my part. Consult the datasheet and measure again to hunt down the respective gate / drain / source pins for this dual mosfet.
                    PS: Need to make a quick trip to Detroit - BBL.
                    • Darren Hibbert
                      • 102
                      Ok safe trip.
                      I checked the 3 pins on one side of the mosfet and they all go to Ground 🤷 (see pic)
                      The 3 on the other side obviously don't. The datasheet shows 3 Source pins and 3 Drain pins. 3 of these pins are grounded so I assume that MOSFET is shorted to ground?
                      I have a thermal cam so will try it while your on your trip and let you know the results.
                      • Darren Hibbert
                        • 102
                        Thermal cam showed nothing.
                        • Darren Hibbert
                          • 102
                          I did notice when I turned the laptop on, that the chipset was starting to heat up for the 3 seconds before it starts looping on and off, I assume this is normal?
                          • mon2
                            • Dec 2019
                            • 13840
                            Which chipset?
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              #34
                              I simply dont understand why we're after charging circuit when the system is charging battery?
                              The resistance to GND for cpu coils is perfectly fine-so SOC is not shorted.
                              • Darren Hibbert
                                • 102
                                Originally posted by mon2
                                Which chipset?
                                Next to the CPU
                                • Darren Hibbert
                                  • 102
                                  Is it at all possible that the laptop is switching on and off because of a corrupt BIOS?
                                  • mon2
                                    • Dec 2019
                                    • 13840
                                    Backup the original bios and test with a known good bios. If necessary, post your request for a fresh bios inside the bios forum.
                                    • Darren Hibbert
                                      • 102
                                      Hi.
                                      Tried a new BIOS but the laptop is doing the same on and off every 3 seconds with no picture. Time to move on to the next step I think. 🤔
                                      • Darren Hibbert
                                        • 102
                                        On the CPU inductors, I'm getting 35 ohms. I might be wrong but that sounds high to me?
                                        • mon2
                                          • Dec 2019
                                          • 13840
                                          Can you measure the 2nd mosfet again from post # 20 and post your measurements. The first measurement looks very low for a good mosfet.
                                          On the CPU resistance, it is not shorted with such a value.
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                            09-06-2024, 05:59 AM
                                          • meraklinetx
                                            Asus Z97-a power cycle, no boot no cpu voltage
                                            by meraklinetx
                                            Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                                            05-10-2023, 06:08 AM
