Dell G3 3579 (LA-F611P) not charging
  • Robocop
    • Sep 2015
    • 8
    Hey guys,
    I've seen several questions about this exact issue, but I've never found the fix, so I would appreciate if we can start over the whole debugging process again from start to finish, for my specific issue.
    In the BIOS setup, (see pic) the AC adapter is detected with the correct power rating, the battery is stated as charging (when plugged in, of course), and the battery health is stated as "Excellent" (as expected, since this is a brand new battery purchased a couple of weeks ago). However, the battery never charges (the percentage never increases).
    The "My Dell" app says "Charging", Battery Health "Excellent", but Charge Rate is "0%/hour" (see pic).
    The computer works fine from the battery and from AC adapter.
    It really looks like the computer "thinks" the battery is charging, but the current doesn't actually get to the battery.
    I tested with two brand new batteries (a noname one, and a genuine one purchased from Dell).
    I tested with another Dell AC Adapter (more powerful than the original one) and both are detected correctly in the BIOS.
    I also replaced the barrel connector in the computer, but the issue is still there.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Resistance between CSOP/CSON pins
    Resistance between CSIP/CSIN pins
    Voltage on pin17/18/19/21/22/24/8/14/15/16 of charging IC.
    No power connected(adapter and battery removed) while measuring resistance between CSON/CSOP & CSIP/CSIN pins of charger IC.
    Charger IC used is ISL 9522 or 9538?
    • Robocop
      • Sep 2015
      • 8
      ISL 95522.
      Resistance between:
      CSOP/CSON: 2.3 ohms
      CSIP/CSIN: 2.6 ohms
      Voltage on pin:
      8: 5.25V
      14: 19.44V
      15: 19.45V
      16: 2.13V
      17: 19.12V
      18 5.28V
      19: 0V
      21: 3.29V
      22: 3.29V
      24: 3.13V
      Note: I connected the AC adapter and the battery to measure those voltages, but the battery was already down to 0V before measuring.
      • mon2
        • Dec 2019
        • 14255
        CSOP/CSON: 2.3 ohms
        This is ok and expected to be ~2 ohms for the full path.
        CSIP/CSIN: 2.6 ohms
        This does not look correct. Confirm these measurements again. No power. Meter in lowest resistance scale. This measurement should be ~4-5 ohms. If not, check each resistor that is in the path.
        PRB02 + current sense resistor (PRB01) + PRB03 = 2R2 + 0R005 + 2R2 = 4R4 + 0R005 = ~4R5 ohms.
        • mon2
          • Dec 2019
          • 14255
          Never mind..just saw the legend to the left that notes that prb02 is 0 ohms for this charger IC.
          So this measurement is ok.
          • mon2
            • Dec 2019
            • 14255
            Pin 19 (ACIN) is 0 volts?
            What is the voltage of pin 7 (ASGATE) on this charger IC which is used to enable the 2*DCin mosfets (gate voltage)?
            What is the ACOK voltage?
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Pin19 missing voltage as mon2 has highlighted.
              • Robocop
                • Sep 2015
                • 8
                I really read 0V on pin19.
                pin 24 (ACOK): 3.12V
                You asked "pin 7 (ASGATE)" but according to the schemas, pin 7 is LGATE2, and ASGATE is pin 13 so here are both:
                pin 7: 4.82V
                pin 13: 1V
                • mon2
                  • Dec 2019
                  • 14255
                  Pins 7 (asgate) does not have the correct voltage. This should be boosted to around 25v to enable the dcin mosfets. Suspecting that you have leakage in the dcin mosfets.
                  watch this video (5:35 onwards is good):
                  https://youtu.be/9zYTlkU9WGE?feature=shared
                  ps: this dual package design has me cross eyed - watch the PIN numbers and compare to the video.
                  Update:
                  For sanity, posting a partial schematic taken from another logic board for this same charger IC - matched from the share video. It appears that pin #19 is ok at 0 volts (based on this pin definition). ASGATE is still not valid for a normal operation = gate pin driver for the N-channel mosfets onboard.
                  continued...
                  your logic board does not make use of the ASGATE voltage.
                  Share the voltage to ground of the logic gate @ PUB02. Pins 1, 2 and also 4 (output). Measure each.
                  Click image for larger version  Name:	charger_pinout.png Views:	0 Size:	262.5 KB ID:	3300569
                  • Robocop
                    • Sep 2015
                    • 8
                    Pin 1: 3.2V
                    Pin 2: 3.07V
                    Pin 3: 0V
                    Pin 4: 3.03V
                    Pin 5: 3.03V
                    (I don't understand why I get 3.07V on pin 2... I expected 0V (gnd to gnd...))
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      PUB02 is working perfectly. This diagram is so confusing 'coz of dual usability of two types of charging IC.
                      • Robocop
                        • Sep 2015
                        • 8
                        So what would be the next step? Testing the mosfets? How do I do this? 😳
                        • Bowline
                          by Bowline
                          06-11-2025, 10:13 AM
                        • lawrenceptrini
                          Battery not charging - Dell Inspiron 3593 FD155 LA-JO81P (REV 1.0) (A00)
                          by lawrenceptrini
                          Hi Guys,
                          I am seeking some assistance with a Dell Inspiron 3593 FD155 LA-J081P (REV 1.0) (A00) laptop
                          The laptop is working fine with the adapter plugged in and also with a charged battery.
                          Problem is that the laptop is not charging the battery. The battery is recognized in the bios but the
                          ac adapter is listed as 'Not Installed'. So for instance, when a charged battery from another source
                          loses its charge, it stays on 0%.
                          Measurements taken
                          Charging IC (ISL95522HRZ) 32 pins
                          Voltage to ground with ac adapter only plugged in:
                          1)...
                          08-26-2024, 06:45 PM
                        • shatteredhalo
                          Dell Inspiron 15 5559 AAL15 LA-D071P battery not charging
                          by shatteredhalo
                          I'm troubleshooting an issue with a laptop where it doesn't seem to want to charge the battery. The laptop will run off the battery alone and use/drain the battery normally in this situation, it will run off the AC adapter alone, and it will run with both charger and battery connected, but it doesn't seem to charge the battery under any circumstance.
                          At startup of the laptop, the following error message is displayed by Dell SupportAssist: "Alert! The AC power adapter wattage and type cannot be determined. The battery may not charge. The system will adjust...
                          08-20-2020, 09:45 PM
                        • Grucha98
                          Dell Latitude E7440 battery not charging only works on AC Adapter LA-9591P
                          by Grucha98
                          Hi, i have problem with dell E7440, battery is not charging. Idk all story. Original Dell Adapter broken up (its not give 19V) i guess first ac adapter broken up and it broken charging circuit in laptop. Laptop has clone battery (Green Cell)
                          Laptop works on clone adapter, and its not charging battery. Like on photo. I checked mosfets near battery plug. They are not shorted. But on PQ809 and PQ810 are low on diode mode (both 0.25V) I desoldered them and check on bench and they are good both 0.5V on diode mode. I checked only drain - source way. So its board circuit it should be higher,...
                          09-09-2024, 11:22 AM
                        • inkman
                          Dell battery not charging
                          by inkman
                          Dell battery.
                          7.4v
                          Genuine dell charger.
                          I have this dell battery thats been left on storage for long time
                          and its not charging anymore inside laptop.
                          Software aida 64 indicates battery has zero wear level,voltage at 2.8v.
                          I am using it in dell computer it came with.
                          When laptop is running, aida 64 indicates battery is not charging.
                          I think battery is locked.Please help me revive this battery, it is in really
                          nice condition.Any question please ask.
                          08-28-2023, 06:18 AM
