HP AD_ID PIN understanding how it works
  • myth77
    • Feb 2017
    • 380
    • Croatia
    So, i have a HP LAPTOP that needs central pin of the specific voltage to be recognized by ite chip as original and correct wattage. My laptop needs around 19v volt and 7 a charger (135 W) and i attached from the schematic Adapter select for EC. The thing is i have only 200 w HP adapter. When i connect it the power led is not showing any light and output on AD_ID 0,56 V. According to the schematic if i replace resistor R5115 17,8k with 100 k resistor, will my laptop work? is that only thing i have to do to be able to power it on with my higher watt adapter?
    thx
    Schematic:
  • piernov
    • Jan 2016
    • 4435
    • France
    That table means "require *at least* the specified power rating".
    A 230 W genuine HP AC adapter that has a 100 kΩ high-side resistor should result in around 1.27 V on AD_ID. 0.56 V sounds like it is something like 90 W.
    • questore
      • Dec 2015
      • 503
      • csongrád
      thx
      Schematic:
      jost checked and a HP 150W charger has 1.0V and 240w charger has 1.7V on AD_ID.
      • jinu_j
        by jinu_j
        Hi
        05-03-2025, 10:51 PM
      • mikey5791
        by mikey5791
        Hi to all forum members,
        12-26-2024, 04:55 AM
      • MidnightRoller
        Can a resistor lose resistance after hot air?
        by MidnightRoller
        I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
        I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
        02-02-2022, 11:46 PM
      • artvandalai
        What resistor ohm will work better to repair this waterpik?
        by artvandalai
        The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
        01-05-2025, 04:10 PM
      • coldje
        Please check my understanding on this resistor
        by coldje
        Am I correct that this is a 5ohm power resistor, 5 watt? It's definitely burned and reading Open Line (OL).
        02-24-2024, 10:41 AM
