acer aspire 4752 JE40 HR MB 10267-4 no power
  • crazypepe
    • Oct 2012
    • 34
    • Philippines
    hi guys
    just want to know what you thinkk about this and if a replacement is needed
    thanks in advance
    its an acer 4752 no power liquid spilled
    3.3v/5v power ic
    rt8223mgqw-gp-u1
    pin
    1=1.17v
    2=0.02
    3=1.98
    4=1.98
    5=1.26
    6=1.26
    7=0.28
    8=3.37
    9=4..6
    10=0.28
    11=0.28
    12=0.0
    13=2.71
    14=3.38
    15=0.0
    16=19.31
    17=5.01
    18=3.35
    19=0.0
    20=0.06
    21=0.06
    22=4.59
    23=3.32
    24=0.06
    attached is the picture of the ic
    and schematics
    thanks
  • alihomee
    • Dec 2012
    • 1580
    • malaysia
    Re: acer aspire 4752 JE40 HR MB 10267-4 no power
    check voltage on power switch and battery tarmenal
    • sorinac
      • Jul 2013
      • 123
      • Romania
      looks like the chip has 3.3v_aux on pin 8 and 5v_aux on pin 17
      and you have on pin 18: 3.35v for enable
      but no 3.3v_pwr and 5v_pwr output
      so you need to replace the chip if you don't have any external shorts
      • dj_ricoh
        • 2073
        on what pins?
        the right side!
        Pins 7 and 24?
        • sorinac
          • Jul 2013
          • 123
          • Romania
          3.3v_pwr should be on pin 7 and 11
          5v_pwr should be on pin 20 and 24
          also both images sides are identic except that enc pin 18
          here is the schematic without password .
          • alihomee
            • Dec 2012
            • 1580
            • malaysia
            check all pins on 3 or 4 you get 3v and also check voltages on bios chip
            • sorinac
              • Jul 2013
              • 123
              • Romania
              both 3 and 4 pins are connected to vref which is generated internal in rt8223b
              and is 2v (check the datasheet) also he can't have voltage on bios because 3d3v_pwr on pin 7 must be ok.
              crazypepe try new chip rt8223b
              • whaldsz
                • Apr 2013
                • 395
                • Philippines
                You need to replace this chip.
                • holmes222
                  • Aug 2009
                  • 61
                  • INA
                  have problem to with 4752 ..
                  power on normal with battery ..without battery is no response power on
                  charging can only do in windows (laptop already on with batt)
                  charging in non power on laptop, charge led on then off,power button press nothing happen, remove charger, remove batt, install batt ..power on normaly
                  could be thic power ic broke?
                  • xxxvirus1987xxx
                    unlegendary
                    • Sep 2014
                    • 24
                    • philippines
                    for me to be fast in trouble shooting replace the power ic then check again....
                    the voltage....
                    • Zazaku
                      • 16
                      • Indonesia
                      nyimax
                      • Zazaku
                        • 16
                        • Indonesia
                        is it same 10267-1 and 10267-4 ?
                        • gamel Expert77
                          • Jan 2015
                          • indonesia
                          nyimak aku
                          • Zazaku
                            • 16
                            • Indonesia
                            Originally posted by gamel Expert77
                            nyimak aku
                            apanya sing di simak.. hehe
                            • bluestone
                              • Jun 2011
                              • 343
                              • Ghana
                              RT8223A is compatible with TPS 51125A which is more common, try replacing it
                              • raizenn27
                                • Jun 2011
                                • 97
                                • philippines
                                i have the same model of unit but my problem is that the mobo cant detect hdd and odd.,i check the power supply for the hdd and i read it only 3v..,can someone help me on this problem..
                                • Joseph cauchi
                                  jccomputers
                                  • Jan 2015
                                  • 89
                                  • Malta
                                  Pin 8 and pin 17 are 3.3v& 5v VEGR check
                                  • lebana
                                    • Jan 2015
                                    • 81
                                    • sudy
                                    thank u
                                    • Imteaj
                                      • Oct 2016
                                      • 7
                                      • Bangladesh
                                      change ptc4102,ptc4101 it willbe work
                                      • qonma
                                        Kuli Solder
                                        • Jun 2017
                                        • 184
                                        • INDONESIA
                                          ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 03:28 PM
                                          ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 02:30 PM
                                          ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-06-2024, 05:27 AM
                                          ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
