How to IT8227E-256
  • 220vdc
    • Nov 2022
    • 18
    • Italy
    How to IT8227E-256
    Hi, which Is the simple and cheap way to programm Lenovo chip IT8227E-256? Possibile whit Ch341A? Thanks
  • LEO037_2029_
    BIOS_LEGEND
    • Nov 2023
    • 83
    • Argentina
    220vdc hi to programm IT8227E its necessary have SVOD 3 - SVOD 4 - RT809H - VERTYANOV - SAS .... etc
    these reprogrammers are expensives.
    good luck
    I hope this information helps you
    • Dan20701
      • Sep 2020
      • 204
      • United Kingdom
      Hello all, Really sorry for crashing this thread, I am also trying to program this same chip in a zif socket IT8227E-256, 1928-BXA.
      Any help would be very apricated. I am not even sure I have the chips the right way around, I have tried a few ways on both programmers.
      I get the chip busy message on one of them, nothing but errors. Not sure what chip to pick on RT809H in the setup, Please if anyone can help.
      Thanks.
      • mon2
        • Dec 2019
        • 14662
        https://www.youtube.com/watch?v=wLGj6EM42_g
        • Dan20701
          • Sep 2020
          • 204
          • United Kingdom
          Thanks mate, looks like it needs to be set on 3v. Will give this a go soon.
          • Dan20701
            • Sep 2020
            • 204
            • United Kingdom
            Hello, I got the chips to read ok but will not erase and on my programmer it will not work on 3v I need 3.3v for it to work.
            I cut a lot of the address errors out so the log is not to long.
            I am sure I was reading somewhere on here the little bios chip 25q is needed to erase the ITE chip is there a recommended chip to use for this?
            Any idea's please?
            Software version 0.0.5.5 date 4.01.2025
            Running Microsoft Windows 10 Pro 64 bit
            Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
            .NET Framework Version: 4.8 or later
            Device connected in work mode
            Firmware version 0.0.4.1 date 4.1.2025
            ITE mode selected
            check pins ok
            selected motherboard ZIF Socket 128_ITE By Damian
            CHECK GND
            Now plug power to the motherboard
            Device ID: 27
            Device Revision: 2
            ITE series detected
            Flash ID: FFFFFF
            Start reading: 16/01/2025 10:36:39
            End reading: 16/01/2025 10:36:42
            Read OK
            Start erase in: 16/01/2025 10:36:54
            Erase error
            address: 0x000000
            Erase error
            address: 0x03FC00
            End erase in: 16/01/2025 10:36:54
            Erase OK
            Thanks.​
            • Maxpower3
              Bad Veteran
              • Feb 2018
              • 1352
              • France
              Device ID: 27
              Flash ID: FFFFFF weird
              Click image for larger version  Name:	image.png Views:	0 Size:	212.1 KB ID:	3549814
              • Dan20701
                • Sep 2020
                • 204
                • United Kingdom
                Thanks so much for the reply's mom2 and Maxpower3. I am starting to think I have have got fake chips from aliexpress.
                I will get some more from another seller and try again in a week or 2 when they turn up.
                I am also thinking of getting the adaptor for SAS and Vertyanov, they just seem like a lot of money but if all else fails
                maybe this will do it.
                Thanks again.
                • Dan20701
                  • Sep 2020
                  • 204
                  • United Kingdom
                  At last, I had to get another programmer to do this chip, cannot see why the svod4 can't do it, it has the latest update.
                  I will give it another go with the svod soon. all my chips have programmed fine have about 20 of these chips now.
                  Thanks again.
                  • sassan
                    The new xgecu T76 vs rt809h programmer
                    by sassan
                    hello,
                    i want to buy a new programmer mainly for use for laptops bios chips and i'm between the Xgecu T76 and the famous RT809H.
                    i think that T76 is faster wich makes it the best choice for using Pogo pins,i asked the support if it supports Mec ships found on some Lenovo laptops i didn't get an answer yet.
                    i would like some ideas and which one do you recommend?...
                    03-06-2025, 05:36 AM
                  • Teeheeze
                    RT809H Programmer Firmware Corrupted
                    by Teeheeze
                    This is a shot in the dark, but I was just using my RT809H programmer and it got stuck in a certain state so I power cycled it. Now, the device LED just flashes quickly and does not connect to the software. I've tried to update the BIOS of it and it fails. I went so far as to remove the ROM from the programmer itself but it's some weird chip (I believe ATMEL, but I can't find any datasheet on it) so I've been unable to read the BIN from it w/ my other programmer. Chip has ATMLHC4C56BM CN written on it (I think). I'll upload an image. I have the programmer's BIN ready to program it manually. Anyone...
                    02-13-2025, 04:51 PM
                  • CornholioGSM
                    RT809H - direct read Toshiba eMMC timeout error
                    by CornholioGSM
                    Hello all,
                    help needed.
                    I want to made backup of boot and all partitions from emmc desoldered from old phone.
                    So i have wired emmc directly to RT809h - Dat0, GND,CMD, CLK, VCC, VCCQ - on programmer sw set Smart Identify to EMMC ISP and voltage to 3.3V.
                    In Settings (N) i have set area to user, boot1,boot2 and EXT and vccq set to 1.8V (tested 3.3V too).
                    Problem is, that i still get Read Timeout Error
                    OK - emmc can be dead...so i have tested emmc wires connection to micro SD adapter and then in card reader and emmc was detected.
                    So...
                    01-16-2025, 04:34 PM
                  • pabloroggeri
                    Program IT8886HE with RT809H
                    by pabloroggeri
                    I am trying to program the EC IT8886HE of a Lenovo V310-15ISK with RT809H. (Motherboard DA0LV6MB6F0 REV: E)
                    According to the programmer's software, it must be connected to the SM BUS of the EC (pins 87 and 88 if I'm not mistaken) through the ISP port of the programmer. However, when I want to read or delete the EC it tells me "bot error"
                    Someone has programmed these ECs to help me or tell me what mistake I am making. I leave the photos of the connection diagram, the error that appears and the photo of how I connected the ISP cables
                    Thank you so...
                    01-16-2025, 10:16 AM
                  • bhteam
                    Lenovo L490 Supervisor Password reset via rt809h
                    by bhteam
                    Hello fellow caps
                    I want to remove the Supervisor password on a Lenovo L490 laptop.
                    SIO is ITE8227
                    I understand that I need a jtag tool like RT809H to be able to talk to the chip and read/erase/write.
                    My question is:
                    Is the RT809H compatible with reading ITE8227 chips? I cant seem to find info on that before ordering the RT809H.
                    04-14-2022, 03:41 PM
