a1706 820- 00239 works with charger cable
  • Joyoungjae
    • Oct 2020
    • 23
    • south korea
    hello everyone
    i have a problem to a1706
    First of all, it was delivered because the power was not turned on.
    5v was confirmed on the voltage meter.
    The battery was removed and checked.
    A short was confirmed in the ppvin_g3h_p3v3g3h line.
    During the tracking process, u7000 and d6902 were replaced and u6903 was reballed.
    The cause was c7081, and when I removed it, the short went away.
    However, 5v still came out from the voltage switch, and I confirmed that a short was coming out of the l6900.
    By replacing u6903, the short was eliminated and 20v was confirmed on the voltage meter.
    I thought the repair was complete and fully assembled it, but 5v was looping in the voltage switch.
    When I connect the battery data cable, the power does not turn on.
    When disconnected, it boots normally.
    I changed the u7000 again and the D6950, but there was no improvement.
    There are no signs of flooding at all. Does anyone know anything about this?
    Lastly, I cross-checked the batteries in three and there was no problem with the batteries.​
    Help me~~
  • mon2
    • 14216
    1) Remove all power. Meter in DIODE mode.
    Red meter probe (yes RED) to ground. Black meter probe to the point to test.
    Test
    SMBUS_SMC_5_G3_SCL
    SMBUS_SMC_5_G3_SDA
    2) Meter in DC voltage mode (20v or higher scale is OK). Measure the voltage to ground of PPBUS_G3H with the power adapter only. Then attach the battery and measure PPBUS_G3H to ground again.
    Post each measurement. It is possible that perhaps mosfet @ Q7065 is defective. You can measure the resistance across this mosfet (with no power to the board) to confirm if it is leaky or not.
    • baglaivlad
      A1706 820-00239 - Works, but sometimes shuts off when the charger is disconnected
      by baglaivlad
      Hello everybody!
      Have in work A1706 820-00239 model. Originally no power, shorted PPBUS_G3H because of corroded C6403, C6404. Some water damage around this components, but nothing major.
      After replacing this capacitors the laptop came back to work, I reinstalled MacOS and had no issues until I started to test Type-C ports. Sometimes the laptop shuts off immediately when some action with Type-C ports performed (charger disconnected or USB device inserted/disconnected). I checked Type-C port flexes, they are okay, but I cleaned them anyway. I can't see any signs of liquid...
      11-20-2024, 08:14 AM
    • flat-earther
      ASUS X54H laptop thinks it's always charging even with charger unplugged
      by flat-earther
      The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
      Windows also shows ''Plugged in'' when charger is not connected.
      This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
      Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
      If I let battery run out and say it has 3% Windows will...
      06-24-2025, 09:32 AM
    • capon5153
      Macbook A1706 works perfectly but no data on USB C
      by capon5153
      hello,
      so i have an macbook pro A1706, motherboard 820-00923, everything works and it does charge without a problem but when i plug anything to the usb c it doesnt do anything, it doesnt give 5V on usb drive or any other peripheral,
      i have opened the macbook and i can see some little corrosion on C7601 and C6950,, i have cleaned it and i measure 15v on C6950 PPVBAT_G3H_CONN
      06-22-2025, 09:42 AM
    • motormayhem
      Lenovo T460 Only Charges on One Charger
      by motormayhem
      Laptop Question
      I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
      A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
      05-12-2023, 01:46 PM
    • ktmmotocross
      HP 650 G1 - works only with battery+charger but not detecting battery
      by ktmmotocross
      Hello.
      Have this HP 650 G1 that works ONLY when battery first and then attach charger. otherwise it not work with charger or battery only.
      i cannot fing what is wrong with it. ACDET - ok, ADP_A_ID - 3.3V ACPRESS, Mosfets looks ok. even when working board dont see battery . data link on battery is ok 3.3V
      this charging circuit is hard. anybody knows what to measure?
      HP 650 G1
      6050A2566401-MB-A04
      sn - 5CG52238HF...
      02-11-2024, 12:13 PM
