Asus Predator Helios 300 Laptop - No power
  • sawuk
    • Jan 2024
    • 6
    Make: Asus Predator Helios 300
    Model: N20C3
    MFG date: 20/4/2021
    S/N: NHQATEK001116068A83400
    Motherboard model: GH51M LA-K862P Rev: 1A 2020-12-23
    Issue: Motherboard has no power, no charging light with charger plugged in and will not turn on with power button. Customer states Laptop went off all of a sudden with no warning.
    I have tried another charger and still does not work, customer confirmed that original charger works in another laptop of the same make and model.
    I then removed the components (RAM and SSD's) and still no power.
    I have removed the motherboard and tested the output of the DC IN jack on the board with the Charger connected and get 0.2V.
    I tested the charger before inserting into the laptop and get 19.8V. When the charger has been inserted into the laptop it trips the charger out.
    When I take the charger out I get a reading fluctuating between 0.1V and 0.4V from the charger tip. When the charger has been disconnected from the mains and left for about 10 seconds, I plug it back into the mains and test it, I get 19.8V back again.
    Anybody got any ideas on what it may be, or what I can do to try and diagnose it?
  • mon2
    • 14813
    Hello. Yes, review the dcin mosfets and the sticky above on charger circuits by piernov.
    • DeXXter
      • Aug 2023
      • 127
      • Chile
      Check resistance on 19v line, it looks like the first mosfet are blocking the power.
      • sawuk
        • Jan 2024
        • 6
        Thanks, I can't see the sticky when clicking the link. Only the users profile.
        • sawuk
          • Jan 2024
          • 6
          Hi, thanks for responding. Sorry for the late reply work commitments have prevented me from checking this.
          I am new to PCB repairs so bare with me. When checking each pin of the first MOSFET from the DCIN I am getting readings of close to 600 Ohms in diode mode on the multimeter. Does that sound correct?
          • rogfanther
            • Jul 2006
            • 458
            • Brazil
            Use the multimeter in resistance mode.
            • sawuk
              • Jan 2024
              • 6
              Every pin gives me a value then immediately goes to 1 on the multimeter. I am using red probe on GND and red probe on each MOSFET pin.
              I have struggled to find the correct openboardview file for this motherboard
