Locked HDD
  • Phoenix83
    • Jan 2014
    • 53
    • Slovakia
    Locked HDD
    Hi
    Friend bought a laptop from the internet and the HDD is locked. It's saying:
    This drive is locked by bitlocker drive encryption, or something like this. Previous owner said that the password doesn't know. Any chance to unlock it?
    Don't think so. Probably he will have to buy a new HDD.
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Locked HDD
    with windos, IDK. but with a linux live disk "dd if=/dev/zero of=/dev/sda" if its the only HDD in the computer. this will wipe EVERYTHING which works because bitlocker is at the partition or filesystem level. you will have to reinstall the OS.
    Follow the white rabbit.
    • domas
      News Hater
      • May 2013
      • 323
      • Denmark
      Re: Locked HDD
      http://superuser.com/questions/40880...with-bitlocker
      1 second on google
      you basically have to wipe the whole crap by deleting partitions, not formating them
      and you can do that in your preferred method, either by removing hard drive and using some controller or booting a cd without taking the hdd out (it can be windows cd, some linux live cd, etc)
      • Phoenix83
        • Jan 2014
        • 53
        • Slovakia
        Re: Locked HDD
        ok. it's done.
        Now installing the Win.
        • mnciks11
          ACER WITH WINDOWS 11 STARTED ASKING FOR A BITLOCKER KEY RIGHT AFTER REMOVING THE RAM
          by mnciks11
          Hello everyone
          I am faced with a weird problem, a client came in the office to upgrade the ram on his acer aspire 3 A315 11th Gen, the ram was upgraded perfectly fine, then after that the machine keeps looping on the bitlocker key, it can not pass that screen of bitlocker, went to bios to change secure boot policy but still the same, tried everything guys that i can think of, still doing the same thing, client does not have the microsoft account for recovery, so here i need your brains...I programmed the bios with a virgin file with no serial number still asking for the bitlocker...
          08-27-2024, 12:57 AM
        • lallollas
          Acer chromeBook c733-c3uy Locked need help
          by lallollas
          chromebook locked without google account i alreadu edit rom and change value enrol 1 to 0 and still locked need help
          model n18q5...
          04-09-2024, 08:14 AM
        • dr_crx
          Dell 7740 Bios locked J3JSD43-8FC8
          by dr_crx
          Hello i need help please
          i have DELL 7740 ST: J3JSD43-8FC8
          i tried to read bios bit i think it is wrong because the size of the file is around 1mb
          anyone can help to show its location on motherboard please.
          i attached the results file the IC i read is : winbond 25q80dvsig
          i don't know if its the needed bios or another bios on the motherboard.
          thank you in advanced for your help...
          07-11-2025, 12:22 AM
        • pwnjuice
          Bitlocker issues
          by pwnjuice
          Customers laptop had a Motherboard go bad and replaced it. they want to try to get data but. I am having bitlocker issues. I will list below
          Issue 1: When connect the drive to my computer to decrypt it I get this message. "there are no supported protectors on this drive the drive cannot be unlocked"
          Issue 2: When I run powershell as admin and try manage-bde -protectors -get e: I get this message. " ERROR: An attempt to access a required resource was denied. I also get the same error when I try manage-bde -status e: When I try the same with terminal with
          01-06-2025, 05:33 PM
        • Ranch 44
          recovering abandoned Latitude 7430 laptop, bitlocker trouble
          by Ranch 44
          I've inherited a Dell Latitude 7430 with W10 that has Bitlocker installed. I have no documentation at all, so no recovery passwords.
          I want to format and re-install Windows with no Bitlocker. I've gone to BIOS and made the USB with the install the first boot option, and that works. But when following the prompts to install, when I am asked what drive to format the option area is empty. It suggests loading drivers.
          I have gone to Command Prompt and am able to see the C: drive and it's four partitions there.
          I can see the Bitlocker ID in Command Prompt...
          07-03-2023, 02:28 PM
