A1502 820-3536 no backlight - PPVOUT_S0_LCDBKLT=0V
  • vincelx
    • Mar 2020
    • 7
    • Portugal
    On this board I have no backlight, but I can see that an image is present when I put a strong light behind the lid.
    On LCD connector:
    PPVOUT_S0_LCDBKLT =0V - resistance to ground on this pin: 163ko
    LCD_HPD_CONN =2.5V
    PP5VR3V3_SW_LCD =5V
    EDP_PANEL_PWR_OR_PSR_EN =3.3V
    EDP_PANEL_PWR =3.3V
    LCD_PSR_EN =0V
    EDP_BKLT_EN =3.3V
    EDP_BKLT_PSR_EN =3.3V
    LCDBKLT_EN_L =12.5V
    On U7700:
    VDDD =5V
    VDDA =5V
    EN =3.3V
    SD =12.4V
    VSENSE_N =12.6V
    VSENSE_P =12.6V
    Any suggestion on how to continue troubleshooting?
  • mon2
    • 14287
    Replace the backlight IC (U7700).
    • reformatt
      • Feb 2020
      • 1416
      Probably a good start. You can also refer to the wiki
      https://logi.wiki/index.php/Backlight_Troubleshooting
      Main issue I see is that Q7700 is not being turned on by U7700.
      • vincelx
        • Mar 2020
        • 7
        • Portugal
        Thanks for this information.
        I did the PRAM reset, no change.
        SMC_LID =3.4V
        Tested R7732, R7731: values are ok, traces too.
        Tested D7710: in diode mode: 0.3V in one way and 3V in the other.
        I replaced U7700: still no backlight, the above measurements are the same.
        What can be the next move? Replace Q7701?
        • mon2
          • 14287
          Replace the diode D7710. The diode must block in one direction and conduct in the other direction.
          If still not working after this replacement, then replace Q7701.
          • reformatt
            • Feb 2020
            • 1416
            From the 1st post, Q7700 was not being switched on. You stated that pin 11 (SD) was 12.4V in the original post. This needs to be 0V in order to pull the gate of Q7700 to 5.5V and turn on.
            Refer to this part of the Wiki
            BKLT_EN high but LCDBKLT_EN_L is not being pulled down
            • vincelx
              • Mar 2020
              • 7
              • Portugal
              The diode D7710 should be ok with these measures in diode mode: 0.3V in one way and 3V in the other. I confirmed on a working board.
              About BKLT_EN high but LCDBKLT_EN_L is not being pulled down​, indeed I2C_BKLT_SDA was not reaching the LCD, trace cut close to C8358, also damaged.
              After repair, backlight is finally present. BKLT_SD is now at 6V, 0V is not even needed. Also confirmed on a working board. Then LCDBKLT_EN_L is at 8.8V
              Thanks for the support! In future I will always check these communication lines first...
              • mon2
                • 14287
                Q7701 is a P-channel mosfet so the gate pin must be lower than the voltage being passed through source / drain pins to enable. 0v; 6v are both low enough voltages to enable the P-channel mosfet. The datasheet for the part will offer details on the mininum negative (lower voltage) that is required to enable the mosfet.
                For N-channel type, the gate pin must be a higher voltage than what is being passed through source / drain pins and the data sheet will reference a positive voltage to enable.
                • triplefour
                  by triplefour
                  09-13-2023, 10:43 PM
                • DanPoka
                  by DanPoka
                  02-15-2025, 05:05 AM
                • Comp_Pro
                  No Backlight Macbook A1990 820-01041
                  by Comp_Pro
                  Hello all,
                  Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                  Tests performed:
                  There is no backlight even with a good screen.
                  Backlight IC is receiving the correct support voltages.
                  Fuse F8400 ok
                  Current sense resistor R8400 ok
                  Backlight IC is receiving 3.3V on enable pin.
                  Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                  Backlight IC receiving 5V from PP5V_G3S
                  Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                  I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                  05-06-2024, 10:23 PM
                • cheebster
                  iPad Pro 12.9 5th Gen Backlight Issue
                  by cheebster
                  Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                  Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                  Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                  The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                  Anyone...
                  05-20-2025, 09:17 AM
                • sdogs
                  Macbook A1502 820-3476-a no backlight
                  by sdogs
                  Happy Sunday guys ;-)
                  I have a macbook pro 13 A1502 on my hands with a backlight problem.
                  After the measurements I noticed that PPVOUT_S0_LCDBKLT shorted to ground, in order I removed the following components:
                  C8300 and C8303 and always at pin 1 of both short circuit present;
                  D7710 short circuit present at pin 2;
                  R7731 and R7732 and short circuit always present;
                  C7713,C7714,C7715,C7716,C7717 and short circuit always present;
                  I also replaced the LVDS connector but the result hasn't changed, even without the connector on the logic pin 1 is shorted..... what...
                  07-16-2023, 09:47 AM
