A2141 MacBook Pro 16" Turns on but no life, holds charge.
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 667
    Customer computer came in, did a DFU revive, no luck, gives error, swapped out battery with two known working batteries still no luck. Board gets 20Volts, raises up to 1Amp then restarts, track pad clicks etc. Tried DFU restore, informed the customer that data recovery is most likely not possible since it didn't give us a revive and DFU restore was the next method to save the board, however it looks like not even DFU Restore is working as well. What could be causing this? I am assuming this is the infamous A2141 flaw that has the flawed Data lines that fail? Any suggestions would be great.
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 667
    Update: put thermal camera and found a shorted Cap. Will update with my findings.
    sigpic
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 667
      Repaired, shorted cap. Board works now. No liquid damage just a bad find.
      sigpic
      • mon2
        • Dec 2019
        • 13849
        Nice!
        • Instafixx
          • Jul 2022
          • 374
          • India
          I have a similar issue.
          I get the charging sign but nothing further, The current draw drops to 0.03Amps.
          • mon2
            • Dec 2019
            • 13849
            Posts #2 & #3.
            • Instafixx
              • Jul 2022
              • 374
              • India
              I plugged in the charger and did the thermal scan. Nothing.
              i am using a 96W adapter. Does this machine boot up without a battery?
              • mon2
                • Dec 2019
                • 13849
                Remove all power. Meter in DIODE mode. Red meter probe, yes red to ground.
                Black meter to point to test.
                Test the following SMBUS lines:
                I2C_PWR_SCL
                I2C_PWR_SDA
                Share the diode mode measurements of each line. ESD diodes @ U6950 may be defective from an ESD transient and causing these SMBUS lines to fail.
