macbook A1932 820-01521-A
  • PITERPENY
    • Jul 2023
    • 461
    • Ukraine
    Hi all ! I really need help with my motherboard! consumption 20V / 0.060-0.280 A is unstable! not detected in DFU! There is no picture on either the external or internal monitor!
    PPBUS_G3H=12,61v
    PPBUS_HS_CPU=12.61v
    PPDCIN_G3H=19.94v
    PP5V_G3S=5.12v
    PP5V_S5_LDO=5.12v
    PP3V3_G3H_RTC=3.3v
    PP3V3_G3H=3.3v
    PP3V3_G3SSW_SNS=2.3-2.6v is unstable!
    PP3V3_G3S=3.3v
    PP3V3_TBT_X_S0=0v
    PP2V7_NAND=2.513v
    PP1V8_G3S=1.8v
    PPVCC_S0_CPU=0v
  • mon2
    • Dec 2019
    • 14659
    Remove all power -> meter in resistance mode -> measure the resistance to ground. Someone on this 'sensor' dedicated power rail is consuming too much current and causin this voltage fluctuations.
    Also review / reflow the load switch @ U8225. It is this load switch that passes the PP3V3_G3H to power these sensors. Be sure that PP3V3_G3H is stable @ U8225.
    • PITERPENY
      • Jul 2023
      • 461
      • Ukraine
      PP1V8_SLPS2R 1.8v but 0.003 diod mode
      U8225
      1=3.3V stable(6.7kohm)
      2=0v (3.89 mohm)
      3-4=3.3V stable(6.7kohm)
      5-6=2 .3-2,6v unstable(0.436mhom)
      7=2 .3-2,6v unstable(5mhom)
      • PITERPENY
        • Jul 2023
        • 461
        • Ukraine
        • mon2
          • Dec 2019
          • 14659
          Not sure what is going on here since there is no short on the consumer side of this load switch.
          If you wish to experiment, swap this Silego part used here with another from a donor board or even from U8210 or U8220. The same component is present at these locations. Being a 4A rated load switch, it should be able to handle ample current but it is possible the part is defective.
          If the next part behaves the same then there is some other fault.
          • PITERPENY
            • Jul 2023
            • 461
            • Ukraine
            • mon2
              • Dec 2019
              • 14659
              Cannot be both. With no power and meter now in resistance mode, measure the resistance to ground of this power rail. Post the measurement.
              • PITERPENY
                • Jul 2023
                • 461
                • Ukraine
                the problem was in the CD 3215, after replacing the poppy came back to life but did not undergo activation
                • PITERPENY
                  • Jul 2023
                  • 461
                  • Ukraine
                  Has anyone encountered this and how to solve the problem?
                  • mon2
                    • Dec 2019
                    • 14659
                    How to Fix "The Recovery Server Could Not Be Contacted" Mac Error (howtogeek.com)
                    • PITERPENY
                      • Jul 2023
                      • 461
                      • Ukraine
                      HI.the problem is that there is no terminal and utility section
                      • mon2
                        • Dec 2019
                        • 14659
                        Can you attempt to install the MacOS over USB media?
                        • PITERPENY
                          • Jul 2023
                          • 461
                          • Ukraine
                          I have the same problem with USB, it asks me to activate my MacBook.
                          • bouch
                            unlock macbook air A1932 2019
                            by bouch
                            hi
                            i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
                            i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
                            i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
                            have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
                            I need help or information?
                            Does anyone have the minat2 activator 1.4 software?
                            Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
                            Thank yo...
                            03-12-2025, 10:14 AM
                          • nikolayu
                            MacBook Air A1932 internet recovery loop
                            by nikolayu
                            I have A1932 that is going to internet recovery every time.
                            i tried nvram and smc reset but it looks that MacBook is not reacting to that.
                            i tried to restore it through DFU but it restarts in the middle of process and Apple Configurator does not show any error, just stays like in progress.
                            keyboard is working because I can connect to WiFi but internet recovery always fails with 2100 or 2003 error.
                            also won’t open option to boot from usb device.
                            and I noticed that is not possible to turn off the MacBook. It’s always turning on by itself.
                            07-22-2025, 02:55 AM
                          • TOMÁŠ
                            MacBook Air A1932
                            by TOMÁŠ
                            Hi, I've never worked with a MacBook before, so I need some advice.
                            I have a MacBook Air A1932 (820-01521). When I plugged in the charger with an amp meter, it showed 19.7V and 1.9A, which indicates that it's charging, but when I press the power button, it doesn't turn on. So, I disassembled it, disconnected the battery, and plugged in the charger again. It showed 19.6V and 0.04A, and pressing the power button had no effect—no current draw at all. Then, I removed the motherboard, connected the charger again, and got the same results. I took a multimeter and checked all the coils, and everything...
                            05-20-2025, 11:19 AM
                          • Arshad alam4659
                            macbook air a1932 sign out of find my
                            by Arshad alam4659
                            Today I receive a MacBook Air A1932, its apple ID has been deleted but when I am resetting it is showing a message(sign out of find my ) customer's have no apple id he bought this MacBook from someone else can someone help me remove this message...
                            04-09-2025, 12:37 AM
                          • astroboypaul
                            Macbook A1932 Some Keys Not Working
                            by astroboypaul
                            Macbook A1932 had completely dead keyboard. I found liquid damage on circuitry on keyboard itself, and repaired it by replacing what i think was a 10k 0201 resistor (here's my post requesting schematic for keyboard circuitry where I included a photo of the resistor: https://www.badcaps.net/forum/troubl...ic-820-01294-a)
                            Now most of the keyboard works and I can login, but the following keys don't work: Delete, "/', left...
                            06-10-2024, 05:32 AM
