MSI GT72-2QE (MS-17811) Mb starts with no post
  • zwect
    • Oct 2022
    • 45
    • Brazil
    I recently got this laptop on a trade labeled for parts, when first testing it, the motherboard starts on, the power LED stays on while the gpu and cpu fans ramp up in different speeds, then it turns off after half a minute or so.
    No flashes from the LED daughterboard that indicates battery and HDD, but the battery seems perfect and even charges if plugged (with it's LED on accordingly).
    BIOS and EC were reflashed, did a clean ME already, no change in symptom but then i noticed 3 things while looking through the board:
    PU5 (NB671LGQ-Z) was burnt in one of the pins, i swapped it out for an non-L variant of it which was the one i could get because of availability, that didn't change the symptom.
    The BIOS chip does not receive 3.3v on it's VCC line, it instead gets 1.8v to 1.9v while the board is on (but without an schematic i can't really know if that is normal)
    All parts of the board except for the initial power lines after the power jack doesn't heat up in any of the tests (but i didn't measure if CPU or even chipset get any power, doesn't seem like it since they do not heat up)
  • Mita99
    Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
    by Mita99
    Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
    Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
    Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
    04-27-2025, 07:20 PM
  • chaos-theory
    Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
    by chaos-theory
    I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
    Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
    03-14-2025, 05:37 PM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • dragon3x
    by dragon3x
    power on.
    Here are some examples :
    switching supply area).
    than 6.3 V.)
    03-21-2025, 02:46 PM
  • Mark D
    Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
    by Mark D
    The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
    10-29-2024, 03:15 PM
