820-00165 Random green light on charger
  • ahoonid
    CapsLOCK
    • Jun 2023
    • 52
    Thanks for your input reformatt.
    I checked voltage on R7012 with only the battery connected and both pins show 0v.
    On D7005 with only the battery:
    Pin 1: 7.66v
    Pin 2: 0.09v
    Pin 3: 7.47v
    On R7180 which, I initially got 8.40v but it dropped a little every time I connected the multimeter probes and finally stopped at 7.38v.
    So is it the D7005 that's leaking via pin 2?โ€‹
    • mon2
      • 14765
      Test this way...remove all power. Meter in DIODE mode. Short your meter probes and the meter should tone beep.
      With no power to the board; no battery to the board - connect the RED meter probe onto pin # 1 (anode) of this dual common cathode diode. BLACK meter probe onto pin # 3 (cathode).
      You should have a voltage reading. What is this value?
      Now reverse the meter leads and the diode should block. Confirm this.
      Repeat with pins 2 & 3 on this same dual diode. So in diode mode, the diode should conduct in one direction and block in the other. Be sure this part is behaving correctly otherwise it is defective and should be replaced.
      • reformatt
        • Feb 2020
        • 1544
        Pin 1: 7.66v
        Pin 2: 0.09v
        Pin 3: 7.47v
        No. Looks ok to me. If you have your ~18V when the charger is plugged in at PPDCIN_G3H (even during your fault condition), then that side of it is ok.
        The LED on the charger going out is most often the magsafe connector itself or the one on the charger. It's the centre pin of the connector and often jiggling the connector often resolves it. AFAIK, there aren't any 'new' LIO boards in the market, they are all 2nd hand. Use of the aftermarket chargers can damage these connectors due to the sparking when plugging in. I always have a genuine charger around to use as a sanity check for these kinds or problems. Anything you get on eBay, Aliexpress are knockoffs BTW.
        Also pay close attention to the connector for the LIO board (J9500), either the pins internally or at the base of the connector. Very common to have these liquid damaged.
        • ahoonid
          CapsLOCK
          • Jun 2023
          • 52
          Red on 1 Black on 3: Beeps once and shows .197v
          Reverse: No beep and shows 1.930v
          Red on 2 Black on 3: Beeps once and shows .199v
          Reverse: No beep and shows .0Lv
          Does it confirm the issue must be here?
          • ahoonid
            CapsLOCK
            • Jun 2023
            • 52
            Yes I have the 18v indeed. I am dead sure about my magsafe being genuine. The magsafe cabe connected to my PSU is also geniune. They have no issue with working devices!
            As for the LIO, I tested an original and working one from another device and still got the same issue. connectors on both side seem very clean.
            One thing I noticed after leaving the device for a few days was that the magsafe light from the original charger wouldn't turn on at all. The system information was recognizing it as connected but in front of charging was written No. I waited for a few minutes and even did an smc reset but still got the same no light on the magsafe.
            Then I connected it to my PSU magsafe and after a 10-15 seconds (fluctuating between 30 to 60 and 70mA and then to 1A and dropping to 60 and 40mA), the light came on and cosequently the original magsafe started to turn on as well and charge the device!
            • ahoonid
              CapsLOCK
              • Jun 2023
              • 52
              Do you think I should go ahead mon2?
              • mon2
                • 14765
                Disconnect the battery. Attach the power adapter only. Measure the voltage to ground on each leg of D7005. Post each measurement.
                • ahoonid
                  CapsLOCK
                  • Jun 2023
                  • 52
                  1: 8.60
                  2: 16.49
                  3: 16.28
                  I did this measutments with the MLB inside the laptop only disconeecting the battery. The magsafe light was on for a minute, I took the measurments, and then the light turned off! The laptop is still up and running and system information confirms the charger is connected!
                  Charger is original 65w magsafe.
                  I get the same values on D7005 with the charger light out.
                  • mon2
                    • 14765
                    After the led on MagSafe turns off, what is the voltage of the 3v42 rail?
                    • ahoonid
                      CapsLOCK
                      • Jun 2023
                      • 52
                      It is 3.42v surprisingly!
                      tested from R5127 and C5127 and the testpad nearby.
                      • mon2
                        • 14765
                        Review this article that was the first breakthrough one for this topic:
                        http://www.righto.com/2013/06/teardo...gsafe.html?m=1
                        review the voltage of the adapter sense pin.
                        Do you have an arduino?
                        • mon2
                          • 14765
                          Magsafe troubleshooting - LogiWikiโ€‹
                          • ahoonid
                            CapsLOCK
                            • Jun 2023
                            • 52
                            Thanks for all your inputs and feedback mon2. I finally fixed it. Unfortunately it was a faulty io board all along!! My spare io seemed to have the same problem and I only found out by chance when I tried the board inside another laptop! It was never the magsafe itself as I tried it with many other laptops. Probably something faulty with the one wire circuit on the io.
                            Appreciate your help anyways ๐Ÿ‘Œ
                            • mon2
                              • 14765
                              Yes, LIO board was addressed in post # 4. Glad you figured it out. Appreciate the follow up for future readers.
                              • ahoonid
                                CapsLOCK
                                • Jun 2023
                                • 52
                                Yes indeed. But out of bad luck of having another bad io board, I completely disregarded any possible issues with io ๐Ÿ˜… my bad anyways. Goes to show how important it is to not just double but triple check stuff sometimes!
                                Cheers mate.
                                • vdrokko99
                                  MBP wont turn on Only green light on charger
                                  by vdrokko99
                                  I have a similar problem... I got an old MBP for free, but wont turn on... Only green light on charger. I measured these voltages. If i try to do an smc reset using keyboard, nothings happen, wont go out the green led. I dont know how to continue, please help me.
                                  SMBUS_SMC_BSA_SCL 3.5V
                                  SMBUS_SMC_BSA_SDA 3.5V
                                  โ€‹
                                  12-01-2024, 12:18 PM
                                • MOSSEP
                                  Monitor Audio RSW12 - Green light, but no sound
                                  by MOSSEP
                                  Hi
                                  Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                  Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first โ€˜decent' bit of audio equipment I ever purchased and is a little sentimental.
                                  The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                  I have already tried replacing all of the...
                                  01-26-2025, 08:33 AM
                                • MOSSEP
                                  Monitor Audio RSW12 - Green light but no audio
                                  by MOSSEP
                                  Hi
                                  01-26-2025, 08:18 AM
                                • lcdcaps1
                                  820-2610-A Sys onewire help, no green light. Please help from the gurus
                                  by lcdcaps1
                                  Hi
                                  I have an 820-2610-A motherboard that has no green light.
                                  I have noticed is when I do a SMC reset the light on the Magsafe blinks.
                                  From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
                                  The sys onewire circuit on this model and others is more involved
                                  I was hoping if anyone knows about this and how it works, can reply and let me know
                                  I know this is an old model but I am sure there are people who still works on these or knows about them
                                  I get 1.1v on the C7771 capacitor and will replace...
                                  11-06-2023, 01:28 PM
                                • mcnamj70
                                  820-00165 no green light on the charger and no fan spin
                                  by mcnamj70
                                  I am troubleshooting a Macbook Air and the SMC posts a voltage of 8.2V at PPBUS_G3H.
                                  Should I replace the SMC?
                                  Macbook appears dead with no green light on the charger and no fan spin.
                                  03-20-2023, 03:57 PM
