HP Elitebook 850 G8 flashes capsl 7 times after bios un/resolder
  • Quin TeknoLife
    • Mar 2024
    • 21
    • the Netherlands
    Hello all,
    I am trying to remove bios pw from this laptop so I desoldered, dumped and flashed and resoldered the chip on the back but ever since doing this caps lock just flashes 7 times, no fan no screen, also the charging/power light immediately comes on when connecting the battery.
    What do I do?
  • mon2
    • Dec 2019
    • 14661
    The bios is the suspect. Confirm the bios contents and the soldering of this device. Post the details in the dedicated bios forum.
    • Quin TeknoLife
      • Mar 2024
      • 21
      • the Netherlands
      I am about to remove the chip again and verify the flash. I'm tempted to solder the chip in afterwards on the jumper pads to see if that changes anything. Am using several layers of tinfoil heat shielding, so I'll have to remove that first :P
      Would pictures (before/after/other) be helpful here?
      • mon2
        • Dec 2019
        • 14661
        Check the seating of your ram.
        https://youtu.be/Na0kzRuCHBw?feature=shared
        • Quin TeknoLife
          • Mar 2024
          • 21
          • the Netherlands
          I already tried that.
          These pics are after soldering
          • mon2
            • Dec 2019
            • 14661
            See attached. Suggest to flux the sides of this flash device and then run your pencil soldering iron tip along these joints. The solder will then melt and rise up onto the flash device pads. We use a cone pencil tip at high heat and that works very well with Koki solder flux or similar.
            • Quin TeknoLife
              • Mar 2024
              • 21
              • the Netherlands
              Click image for larger version  Name:	solder_joints.png Views:	76 Size:	1.10 MB ID:	3250018
              Things have progressed... downhill..
              fn light on, no charging light, power button unresponsive 😱
              Ive measured across the board and all voltages seem to be there​
              • mon2
                • Dec 2019
                • 14661
                Post an updated pic of the reworked areas.
                • Quin TeknoLife
                  • Mar 2024
                  • 21
                  • the Netherlands
                  Thank god for 64mp cameras
                  • Quin TeknoLife
                    • Mar 2024
                    • 21
                    • the Netherlands
                    Any thoughts?
                    • romky
                      • Nov 2015
                      • 9
                      • Poland
                      Missing resistor close to pin nr 5
                      • Quin TeknoLife
                        • Mar 2024
                        • 21
                        • the Netherlands
                        By any chance you know the ratings of this resistor (and possibly circle where it should go)? Could I just bridge the two points?
                        • romky
                          • Nov 2015
                          • 9
                          • Poland
                          If i remember correctly it was the same as the one next to it
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            If you dont know the rating, try with 33 ohms resistor.
                            • Quin TeknoLife
                              • Mar 2024
                              • 21
                              • the Netherlands
                              ​Having trouble pinpointing the location on the pcb, if you could point it out on the pic(s) I included earlier I would be very grateful 🖤
                              I'll have to scavange something from other broken/unusable pcbs, most likely the motherboard from a dell Chromebook I got laying around lol
                              • Quin TeknoLife
                                • Mar 2024
                                • 21
                                • the Netherlands
                                I've been examining the area around the bios chip but I can't find the spot or it's companion resistor anywhere 😵
                                • esqmooo
                                  • Jul 2024
                                  • 5
                                  • DRC
                                  I have the same issue, but I didn't touch the bios or anything. It just suddently starts flashing the CAPS lock light 7 times when trying to power up. Also the charging light is constantly on. Any idea?
                                  • romky
                                    • Nov 2015
                                    • 9
                                    • Poland
                                    You're welcome
                                    • motanya
                                      • Nov 2021
                                      • 162
                                      • Kenya
                                      I am having the same problem after I tried to program the bios, I doubt there is a missing resistor somewhere. If anyone has a similar board please help me double check and point to me what is missing or added and shouldn't. Any assistance will be appreciated
                                      • STKR123
                                        The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                        by STKR123
                                        Greetings badcaps community,
                                        I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                        So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                        Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                        I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                        These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                        I learned that desoldering...
                                        10-29-2024, 06:03 AM
                                      • macabook
                                        by macabook
                                        🧩 Initial Issue
                                        07-24-2025, 02:17 PM
                                      • Guest
                                        Elitebook 850 G5 BIOS bricked
                                        by Guest
                                        I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                                        I assume the BIOS update failed, so I searched for the BIOS chip.
                                        I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                                        However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                                        Can the corrupted...
                                        03-24-2025, 01:21 AM
                                      • pirati
                                        by pirati
                                        Yesterday, 04:20 PM
                                      • Vesko356
                                        by Vesko356
                                        08-11-2023, 03:27 AM
