Missing components on motherboard (newbie question)
This topic has been answered.
  • Good2Know
    • 23
    Having some trouble understanding how compnents like resistors /caps etc that are present in board view and schematics but are missing on the actual board iam troubleshooting.
    In my case its about some resistors /caps around the charging ic.
    Click image for larger version  Name:	grafik.png Views:	0 Size:	229.4 KB ID:	3248476
    For example PR321 H_PROCHOT, since its an essential signal, how can the charging ic talk to the sio if there is no connection ?
  • Answer selected by Good2Know at 04-08-2024, 10:10 AM.
    piernov
    • Jan 2016
    • 4439
    • France
    @ means no stuff. Resistor symbol with line under it means bridged on the PCB.
      • 21880
      Post your motherboard model number and revision number. Post a LINK to the schematic/boardview if it is already posted in the schematic requests sub forum - https://www.badcaps.net/forum/troubl...-requests-only
      • Good2Know
        • 23
        My board:
        LA-E921P
        Rev 1B
        Schematic in use
        LA-E921P
        Rev 1A
        Think i got both schematic/boardview from external site.
        • piernov
          • Jan 2016
          • 4439
          • France
          • Good2Know
            • 23
            Thank you very much for the clear cut answer.
            This helped me a lot.
            I checked some test points and yes indeed, there is connection where i thought could not be because of the missing resistor.
            May you have a very good day.
            • Fernon@Repair
              MSI mpg b560m bazooka motherboard RSMRST# signal missing
              by Fernon@Repair
              I have MSI mpg b560m bazooka motherboard . this motherboard RSMRST# signal missing . i already reprogram bios but same condition
              My Motherboard this power stages are ok ...but 3vsb voltage have 4.17v (image added)
              VCCRTC ok
              RTCRST# ok
              ATX_5VSB ok
              SIO_3VA ok
              3VDSW ok
              DPWROK ok
              SLP_SUS# ok
              VSB_ENABLE# ok
              5VDUAL ok
              3VSB showing 4.17V
              PCH_1P8_VSB ok
              PCH_VCCIN_AUX ok
              RSMRST# No voltage
              this all voltages are ok but RSMRST# voltage is missing i did try to re program bios and change io but same...
              06-03-2025, 10:49 AM
            • Yolofolkss
              Huawei D14 dah98ambad0 rev d please help identify Missing components
              by Yolofolkss
              Hello I just bought this laptop to be used personally (that I'm currently trying to repair.), I am aware that liquid (gravy) has been spilled in this area before. but there are missing components it it possible to have a board view or a schematic of this? or just an idea on what components its missing?
              as far as I know this parts are connected as sense or enable.... that's how far I know...
              Images attached:
              the picture of the area. and some of the pinouts that I noticed on the chip...
              03-26-2023, 12:37 AM
            • Artakozu
              Xfx RX470 - Missing components
              by Artakozu
              Hi, I'm new to this forum.
              I recently bought a damaged XFX RX470 for around $10-12 USD. As you can probably see, I believe the only issue is some missing components, likely due to a scratch or a fall.
              Can anyone help me confirm which components are missing, and specifically, tell me the value of capacitor C502?...
              05-20-2025, 06:26 PM
            • summerwhite
              DJI Mini Pro 3 missing components near camera connector
              by summerwhite
              I have a DJI drone that is not displaying a video feed anymore after a repair.
              When tearing down the DJI drone to fix the armature there was some hot glue next to the camera connector that i had to remove.
              Now there are missing components either because they got pulled off or because they where never placed.
              I have two reference images from XXZ and a photo of mine.
              I'm truely hoping someone has another DJI Mini Pro 3 that they can help me identify what these components are and if they are necessary.
              On the board view from XXZ they...
              04-06-2025, 11:15 PM
            • Caspar
              MSI 1660S Ventus missing components
              by Caspar
              Hi all, I accidently knocked off some components on a MSI 1660S Ventus while trying to remove the heatsink to repaste the GPU. The missing components are located on the top left corner of the GPU. Does anyone happen to know what the values of the components are? I circled the missing components in the provided picture. Any help would be greatly appreciated.
              Thank you!
              PS If there's a boardview, that would help as well!...
              03-31-2023, 11:51 AM
