CPU replace | OEM Hash key poblem
  • Vusal
    Senior Tech.
    • Feb 2016
    • 45
    • AZerbaijan
    first of all hello everyone
    If there is a short circuit on the motherboard of the HP laptop. The CPU was broken (i3-10th) I found a donor motherboard on ebay and replaced the CPU.
    The CPU on the donor motherboard had the OEM Hash key. But I did not check the OEM Hash key before ordering the donor motherboard.
    Normally, after changing the CPU, the motherboard started and the white LED light on the DC jack was blinking.
    The motherboard was in reset state and the current drawn was 60mah.
    I checked the BIOS information and added the OEM Hash key on the donor motherboard to the BIOS.
    This time the motherboard started and shut down 3 times and the current drawn was 620mah.
    then it was fixed at 620mah current. and caps lock 5 long 3 short gives blink error (BIOS error)
    I tried many edits in BIOS but I did not get any results.
    Now my real question. Won't a CPU with an OEM Hash key work on another motherboard? Because I added the OEM Hash key to the other BIOS.
    By the way, bootguard was at profile 0​
    • 22312
    If the donor board was exactly the same then just cleaning the ME firmware would have been enough,if there was an OEM key in the original bios it should still be there after cleaning. 5 long 3 short could be a bios problem or RAM pins not soldered.Post your original bios backup in the bios requests section if you want someone to have a look at it.
    • Vusal
      Senior Tech.
      • Feb 2016
      • 45
      • AZerbaijan
      CPU broken motherboard code: da0padmb8g0 (OEM has key - empty) SRGKF (Intel Core i3-1005G1)
      Donor motherboard code: 6050A3156701-MB-A01 (OEM has key) SRGKF (Intel Core i3-1005G1)
      this broken&donor board BIOS
    • Vusal
      Senior Tech.
      • Feb 2016
      • 45
      • AZerbaijan
      There is no problem with CPU soldering. It was soldered ideally.
      • Vusal
        Senior Tech.
        • Feb 2016
        • 45
        • AZerbaijan
        Mr admin. I did not open a BIOS request. So, I shared the other BIOS file in case someone wants to change or analyze this section in the BIOS. Because, the issue is already related to BIOS
        • piernov
          • Jan 2016
          • 4439
          • France
          Sure that Boot Guard was disabled in the PCH? Need check the report of MEInfo on the running machine before removing CPU…
          If it is enabled in the PCH, you can only use it with BIOSes signed with the correct key.
          • Vusal
            Senior Tech.
            • Feb 2016
            • 45
            • AZerbaijan
            Boot Guard profile is in order 0. But it has a Hash key, that is, OEM configuration.
            • piernov
              • Jan 2016
              • 4439
              • France
              What matters are the PCH Field Programmable Fuses (FPF). If Boot Guard Verified Boot is enabled in the PCH fuses, then the BIOS needs to be signed for the fused key.
              • Vusal
                Senior Tech.
                • Feb 2016
                • 45
                • AZerbaijan
                Can this processor work if the BIOS is signed?
                Or can I get results if I make a change via Flash Image Tool?
                Because I made changes in many places with FIT but I couldn't get any results.​
                • glovecaps
                  Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                  by glovecaps
                  I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                  My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                  The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                  11-25-2024, 04:23 PM
                • to5it0
                  Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                  by to5it0
                  Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                  I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                  This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                  I have opened the laptop and identified the main BIOS chip...
                  10-24-2025, 01:35 AM
                • oragano
                  ASUS ex-b250-V7 motherboard bios corrupted - by me
                  by oragano
                  hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
                  So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
                  i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
                  10-17-2024, 02:53 AM
                • AkaBukai
                  Is it okay to flash stock bios onto the motherboard's BIOS?
                  by AkaBukai
                  Hi there,
                  I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
                  The little LED on the power button is flashing slowly and nothing happen.
                  This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
                  So I decided to flash the BIOS using a cheap programmer.
                  And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
                  I also...
                  12-19-2024, 12:15 PM
                • GardevoirForEver
                  Embedded Controller issues, living an absolute H*LL with my ASUS Vivobook Pro 16X OLED
                  by GardevoirForEver
                  I've been dealing with so many complications for months, trying to find and then fix the root cause of the issue I really need help and I have to solve this on my own (Going to Asus headquarters isn't an option for me. First, because I'm very stubborn and want to insist that I can fix this sort-of-myself somehow, and second, the location is too far away for me anyway).
                  Right now I'm desperate trying to put an end to this nightmare, but OK, I'll do my best to be somewhat brief in explaining and relating the entire situation and context.
                  The motherboard of my ASUS...
                  11-15-2025, 04:30 PM
