what model this chip is, thank you. X415JA Main board R2.1
  • aoqiangzhang
    • Mar 2024
    • 4
    • The United States of America
ID:	3245066Can anyone tell me what model this chip is, thank you. X415JA MAIN BOARD R2.1
  • aoqiangzhang
    • Mar 2024
    • 4
    Does anyone have the schematic diagram of this motherboard? Could you please provide it? Thank you.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Post a clear picture of the IC. markings are not visible in your pic.
      • mon2
        • Dec 2019
        • 14677
        See attached. PU8900 (from a similar board) and is TI part # SN2867RUYR.
        Do you need the BV file (X415EA) that is similar?
        • ngger handoko
          • Mar 2024
          • 32
          • indonesia
          BQ24780S
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
          • ygorsan
            by ygorsan
            🧩 Problem Summary:
            • I
            07-28-2025, 08:34 AM
          • JDC
            (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
            by JDC
            ONN 100012588
            Issue: No Power, Then Rebooting After Main Board Change
            Short answer: replace main board and power board
            Technical answer: replace main board and Q306 & Q307 on power board.
            Long answer:
            TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
            07-15-2022, 07:39 AM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • cheeky2
            by cheeky2
            05-25-2024, 03:27 AM
