Dell Inspiron M5030 Power Problem
    when press power it turns on after a few seconds it turn off . already try with other cpu and ram but same result..
    only led 1 indicator light and the other led 2, led 3 nothing happen..
    one kind i notice when press power botton turns on a split seconds turn off while the led 1 still have light ..then when i try to press on again the the led 1 its become turning off..
    My laptop is dell inspiron M5030..
    Thanks and advance
    Re: Dell Inspiron M5030 Power Problem
    change lcd and cable
      It has nothing to do with the screen.
      Its amd or intel?
        M5030 is AMD, using RS880M/HD4250 northbridge. Most likely the NB has failed due to overheating. Recommended solution is to replace the chip with a new one. Reflowing may work for a while, but it's not worth attempting to reball it as it'll likely die.
        A working TV? How boring!
