Well I am dumb to buy a faulty water damaged motherboard from ebay and i need help :)
are u using lab psu or usb-c psu ? do u have amperomether for usb-c ? just to know how many amp it's drawing.
voltage should be 3,3 for nbswon.
this is power sequenze for similar notebook.
without fan, pc should start at least for few seconds and cpu should get warm. then power off without heatsink.1 PhotoComment
i shorted it all still ain't starting (the connector above)
ec chip getting 3.3v and 1.8v not getting hot sitting cold while doing something (i was checking all the pads near ec chip there were some weird voltages like 0.4-0.8v bios chip also has 3.3)Comment
i just saw somewhere that if the power button is not pressed and you reset the bios the laptop will start?(dont see any way to reset bios on this thing)
one more thing is it possible like i need to replace the caps i removed like i have a other laptop motherboard and take a big ceramic (only 1 of like a higher voltage and current value presumably) capacitor and place there .
I have a water damaged Toshiba TV that was hanging nicely on the wall then over the summer we had a new multi-million pound boiler system put in and right where this TV was hanging is a nice new pair of water pipes for the radiators...
The TV hasnt been used for a fair few months but it was needed again the other day and needless to say, it didn't power on or show any signs of life (no standby LED etc). After checking the fuse in the plug (and that the socket it was plugged in to worked) I decided to get up some step ladders to take a closer look and low and behold! It looks like... -
by rzsnHello friends, so I have got a "water damaged" (or cola/beer/coffe .. something dark and sticky) G513I system - which has the board and schematics from this thread. After cleaning up all the visible sticky residue with water and detergent (thankfully mostly on the top/keyboard side), I have a partial success. IPA was of no use for cleaning this.
Using a bench power supply on the DCIN jack (as it seems that the PSU keying pin is not wired at all - series resistor R6003 is not populated), and using a shoring wire for the power button (either pin 5 on CN251 keyboard, or one... -
by estabilitoHi,
I have water damaged Dell Latitude E5590 around charging ic.
Laptop was dead but i replaced some components like capacitors, resistors, resoldered charger(intersil 9538h) but traces under PQ904 dual mosfet(AOE6936) was burnt.
I rebuilt traces and both mosfets(PQ904 and PQ905) and after all this work laptop started turning on.
I dont have battery so i want to be sure if laptop behaviour is normal before buying.
On PL902 i have weird voltage around 5Volts, on battery socket voltage looks normal - 13.5v.
Is this voltage on pl902 normal?... -
by abajorLike title says A2141 came in with Water Damage, customer desperately wants the data.
The actual water ingress doesn't appear too bad it sat for a day but was very dusty internally. I have no idea why L8504 was arced there is no apparent moisture there or around the LVDS cable; however, the LVDS to screen screw studs had popped off at some point and somebody tried securing it with kapton tape.
I had to create a micron wire pad jumper to reconnect the south side of the L8504 since the primary pad was blasted down to the vias.
That said after cleaning up the... -
by martyjelenHello, I have laptop Lenovo ideapad D330-10IGM which won't turn on. It was water damaged, but as I know it was clear water. I cleaned the board already.
Now, I noticed, that some component is heating up (see picture) there is a code GAASKJ on it. I don't really know what component is this and what is it's function.
It seems that charging works normally because current draw is about 1A and voltage is 19V.
Could you help me with it?
Thank you
BTW there is a flux on component. No damage.
Martin... - Loading...
