Macbook Air a1932 (820-01521) 20V 0.1-0.2A
  • obelix24
    • Jun 2023
    • 300
    • Slovakia
    I got one Macbook Air a1932, when i connect charger it takes 20V and 0.1 - 0.2A.
    Trackpad is clicking (this means T2 is ok ???)
    I can put macbook to DFU and revive, restore via Apple Configurator.
    Problem is that there is nothing displayed, no chime, no caps lock light and it looks like is not turning on (as even with battery connected it's still only between 0.1 - 0.2A)
    I've tried connecting to external monitor and also no output ...
    I'm not able to find anything what can cause this ... I've tried to replace U8110 but still the same behavior ...
    Any idea ?
  • dbuergi
    Water damaged MacBook Air A1932 AmrestoreErrorDomin Error-9 trying to restore with configurator
    by dbuergi
    this Macbook was stuck at 5v and didn't start because of some water damage. I was able to clean everything and the board started. So i put everything back together and the Macbook seems to boot with 20v, 1,4A and 29W. So i decided a DFU recovery. At 50% of the system repair i get the error massage from the title. Display stays black and no Apple logo. Both repair and recovery don't work.
    Is there anything i can do?
    11-19-2024, 09:27 AM
  • bouch
    unlock macbook air A1932 2019
    by bouch
    hi
    i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
    i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
    i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
    have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
    I need help or information?
    Does anyone have the minat2 activator 1.4 software?
    Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
    Thank yo...
    03-12-2025, 10:14 AM
  • TOMÁŠ
    MacBook Air A1932
    by TOMÁŠ
    Hi, I've never worked with a MacBook before, so I need some advice.
    I have a MacBook Air A1932 (820-01521). When I plugged in the charger with an amp meter, it showed 19.7V and 1.9A, which indicates that it's charging, but when I press the power button, it doesn't turn on. So, I disassembled it, disconnected the battery, and plugged in the charger again. It showed 19.6V and 0.04A, and pressing the power button had no effect—no current draw at all. Then, I removed the motherboard, connected the charger again, and got the same results. I took a multimeter and checked all the coils, and everything...
    05-20-2025, 11:19 AM
  • Arshad alam4659
    macbook air a1932 sign out of find my
    by Arshad alam4659
    Today I receive a MacBook Air A1932, its apple ID has been deleted but when I am resetting it is showing a message(sign out of find my ) customer's have no apple id he bought this MacBook from someone else can someone help me remove this message...
    04-09-2025, 12:37 AM
  • astroboypaul
    Macbook A1932 Some Keys Not Working
    by astroboypaul
    Macbook A1932 had completely dead keyboard. I found liquid damage on circuitry on keyboard itself, and repaired it by replacing what i think was a 10k 0201 resistor (here's my post requesting schematic for keyboard circuitry where I included a photo of the resistor: https://www.badcaps.net/forum/troubl...ic-820-01294-a)
    Now most of the keyboard works and I can login, but the following keys don't work: Delete, "/', left...
    06-10-2024, 05:32 AM
