Need confirmation if PCH is dead
  • orientalsniper
    • Apr 2013
    • 461
    Hello, got a 820-00165, has orange led but won't power on, if I SMC bypass, the fan spins indefinitely, but the PCH/Processor does not even warm up.
    Here are the relevant voltages, need confirmation if PCH is dead to inform customer:
    PPVRTC_G3H - 0v (4 MOhms)
    RTC_RESET_L - 3.3v
    PCH_SRTCRST_L - 3.3v
    PCH_INTVRMEN_L - 2.4v
    PCH_DSWVRMEN - 2.3v
    PP3V3_S5 - 3.3v
    PM_DSW_PWRGD - 3.4v
    PP3V3_SUS - 3.3v
    PM_BATLOW_L - 3.3v
    PM_RSMRST_L - 3.3v
    PM_PWRBTN_L - 3.3v​
  • reformatt
    • Feb 2020
    • 1540
    More likely you have an issue around U1900, which is quite common given the bottom of the board cops most of the corrosion on this model.
    Dead PCH usually presents as a short on PP3V3_S5 or PP1V05_S0. The latter should measure around 150 ohms or more to ground when CPU is cold. Follow the power sequence on logi wiki for this model to troubleshoot.
    • orientalsniper
      • Apr 2013
      • 461
      Thanks reformatt my guy, means there's a chance, will check the wiki later.
      • piernov
        • Jan 2016
        • 4439
        • France
        RTC_RESET_L - 3.3v
        Not possible. RTC_RESET_L is pulled up to PPVRTC_G3H.
        • orientalsniper
          • Apr 2013
          • 461
          You are right piernov I must've not touched the probe to ground, PPVRTC_G3H is 3.3v and PP1V05_S0 is around 450 ohms against ground.
          I even got the voltages at the end of this power sequence ( https://logi.wiki/index.php/G3_to_S3..._and_Broadwell ). So I guess PCH_INTVRMEN_L and PCH_DSWVRMEN are okay.
Name:	Screenshot 2024-03-14 185326.png
          • reformatt
            • Feb 2020
            • 1540
            Most common issues on these boards are corrosion on the rear edge facing the keyboard, or minor spots around the board from either liquid or insect damage. Look over the board closely under a microscope for corroded test pads and components. Any components that aren't shiny often have corroded connection to the pad underneath. You need to remove each one, clean up the pads and replace with a component from a donor board. I do this before any serious troubleshooting.
            • orientalsniper
              • Apr 2013
              • 461
              reformatt I've checked and the only corrosion I found was around C3202, R3241 and C3200 relating to Thunderbolt, I really thought I mentioned the history of this device, but apparently I never did, the thunderbolt IC U2800 and the camera IC U3900 were heating up when power was plugged in, so I removed those chips, that was the first thing I did.
              At this moment, PM_SLP_S4_L pulses 2 times when power adapted is plugged in.
              I checked the the diagram made by piernov https://logi.wiki/images/b/b0/S3_to_S0_State.pdf and I'm not getting PP5V_S4RS3, is this a U7501 fault?
              • reformatt
                • Feb 2020
                • 1540
                Double pulse on these boards, I don't have a solution. Have seen this fault many times and fault always comes back to PCH/CPU. I believe a CPU reball would probably resolve it, but I don't have the rework station in which to do it to prove it. I use double pulse boards as donors these days and just replace the board if the customer wants to fix it.
                • orientalsniper
                  • Apr 2013
                  • 461
                  Thanks mate reformatt I'll double check everything again today and maybe do a reflow to PCH, if I don't update this post, that meant I couldn't fix it, thanks once again.
                  • double_DD
                    How can I be sure that my EC chip is dead?
                    by double_DD
                    As the title suggests, how can I be sure that my EC chip is really dead?
                    I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                    Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                    03-12-2025, 07:47 AM
                  • disorder
                    ps5 edm-033 dead after hdmi/usb ports destroyed
                    by disorder
                    hello guys,
                    i need help to repair a edm-033 ps2
                    history : as always hdmi port and usb ports destroyed after unplugged
                    after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                    so i changed it
                    now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                    but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                    i don't see any projection of liquid metal on pcb.
                    01-14-2025, 12:48 PM
                  • zunasthegreat
                    Chieftec GPS-450-AA with dead 20N60C3
                    by zunasthegreat
                    Hello everyone hope all doing well!
                    I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                    09-01-2024, 07:12 PM
                  • Beton
                    Finding a dead short component
                    by Beton
                    Hi guys!
                    I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                    So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                    I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                    I have a bench PSU and if I try to inject voltage the voltage...
                    12-10-2021, 01:05 PM
                  • FiguringITout
                    MSI Raider GE75 - Not posting, probable dead CPU
                    by FiguringITout
                    Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                    Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                    07-25-2024, 07:27 AM
