macbook a1932 no screen , no backlight
  • defdjamel
    • Jul 2025
    • 20
    • france
    hi there , in this A1932 - Air 13 Retina 2018 820-01521, there no screen , no backlight.
    no liquid damage.
    i have change the lcd flex ,
    tested with a working lcd screen but no display , no backlight.
    hdmi over usbc is ok .laptop is working .
    the same.
    here measurement
    • PP3V3_LCD = 3,3 V
    • PP5V_LCD = 5 V
    • I2C_SDA_TCON / I2C_SCL_TCON = 3,3 V (no oscilation)
    • LCD_PWR_EN = 5 V
    • LCDBKLT_EN_L = 12 V
    • EDP_BKLT_EN = 0 V
    • IPD_LID_OPEN = 1.8 V
    i am stuck, if you have an idea....
  • mon2
    • 14691
    • EDP_BKLT_EN = 0 V
    Should be:
    • LCDBKLT_EN_L = 0v (active low signal)
    • EDP_BKLT_EN = logic high = '1' to enable (active high signal)
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • MagJ_
      MacBook Air M1 A2337 Screen Replacement - keeping TrueTone
      by MagJ_
      Hello Everybody,
      I have a cracked screen and want to fix it. Usually, TrueTone will be gone as long as one does not prune open the screen and exchange only the LCD. However, I have seen the following Youtube video https://www.youtube.com/watch?v=MBNqhp6p_ZM, Solve MacBook M1 Pro screen true tone issue from the channel Master Liu, where only two chips called "display control chip" and "code chip" are swapped over to the new screen. I know, it is for the MacBookPro version. Though, I had the hope that it could work similarly for the MacBook Air as well.
      10-09-2024, 02:51 PM
    • bouch
      unlock macbook air A1932 2019
      by bouch
      hi
      i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
      i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
      i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
      have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
      I need help or information?
      Does anyone have the minat2 activator 1.4 software?
      Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
      Thank yo...
      03-12-2025, 10:14 AM
    • sofles
      Macbook Pro 16" A2141 screen artefacts, kernel panic
      by sofles
      Hi there.
      I have Macbook Pro 16" 2019, model number A2141, motherboard number 820-01700. I have some problem with dedicated graphic card. When Macbook switches to dedicated GPU it is getting instantly hot and starts to show glitches on screen, then it freezes (trackpad is not clicking anymore) and shuts down.
      I tried to reinstall MacOS But it was a pain, it started to show glitches in middle of installation and I could not finish it. I only was able to reinstall MacOS when I put Macbook outside (it is winter and -2 Celcius).
      Now situation looks like this, If...
      02-05-2025, 05:05 AM
