MacBook Pro 2018 - A1990 Dead - not charging - only 5V
  • robka
    • 12
    my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
    I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
    The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
    After that the Macbook was dead. It isn't charging anymore.
    The USB-C Port where the charger was plugged is burned. Also The Cable and the power adapter. So probably this had a fault.
    I checked the voltage and it's only pulling 5v on each port.
    Can somebody tell me, where and how to check first with a multimeter?
    Edit: check F7000 & F7001 - ok
    Thank you
  • mon2
    • Dec 2019
    • 14239
    Remove all power -> meter in resistance mode -> measure the resistance to ground @ F7000 or F7001. If the resistance is not low -> meter in voltage mode (DC setting; 20v or higher) -> measure the voltage to ground @ F7000 or F7001.
    Post each measurement.
    Thieves.
    • robka
      • 12
      both won’t dial in. The value is increasing and decreasing all the time.
      • kevingill
        • Jun 2013
        • 152
        • England
        Check power rails in power up sequence.
        Use this site as a guide for your board.
        https://openboarddata.org
        • robka
          • 12
          I‘m not sure if I understand right. I should check power rails when I‘m booting? The MacBook won't boot. It's dead - probably the battery is empty also.
          sorry, English isn't my mothertongue and therefore some words are probably missing.
          Unfortunately, I can't do anything with it because I don't know how to use it.
          • robka
            • 12
            nobody?
            • mon2
              • Dec 2019
              • 14239
              Post the range of the resistance being observed from post # 3. Need measured values to understand if there is a short on the board or not.
              • Stephen
                Meow Meow MEOW!
                • Apr 2020
                • 667
                Originally posted by robka
                nobody?
                Can you show us the type of MacBook Charger you are using? I am curious about that first hand. We do not want you to continue using a KNOCK OFF NON OEM charger, most of these issues could arise from hot plugging, however, knock off chargers are known to frying the port even if you plug it in correctly and not send the voltage down the wrong rail. If it doesn't have an Apple Logo on the brick chances I would do is throw that charger away and get a used OEM one online. Not a new one from Amazon or wherever. Secondly, if one port is fried and causing issues but all the other ports are working, I would highly suspect that individual port is the issue and I would replace that USB C chip is fried and needs to be removed and replaced with a good one.
                "because every local shop charges around 600€ (650 usd).​ "
                OUCH! You can get a good working A1990 board for half that price I believe, however a board repair at our shop costs $300 for 2018 and above. 2017 and below A1707 and A1706 boards $150.00 (not going into data recovery) if you just need it fixed to retain the information.
                sigpic
                MEOWING IN THE IMPOSSIBLE UNIVERSE!
                • robka
                  • 12
                  Thieves.
                  F7000 & F7001 0 Ohm
                  F3000 & F3001 5v
                  • robka
                    • 12
                    Originally posted by Stephen
                    Can you show us the type of MacBook Charger you are using? I am curious about that first hand. We do not want you to continue using a KNOCK OFF NON OEM charger, most of these issues could arise from hot plugging….
                    no knock off.
                    I‘m using the original delivered charger.
                    • mon2
                      • Dec 2019
                      • 14239
                      What is the current draw at the 5 volts by the power adapter?
                      for resistance checks, be sure there is no power. Meter in lowest resistance scale. One probe on the fuse F7000. Other probe to ground. You still have 0 ohms measurement?
                      • robka
                        • 12
                        Draw is always 5v.
                        Resistance was checked without power plugged in.
                        • mon2
                          • Dec 2019
                          • 14239
                          Ok but what is the current draw? Or you can post a pic of the meter face to show the readings. It should be in mA or A (milli amps; Amps, etc.). This will help to diagnose the case.
                          • robka
                            • 12
                            I'm sorry.
                            It bounces between 0.048, 0.321 and 0.459 A @ 5V
                            • mon2
                              • Dec 2019
                              • 14239
                              Ok. Would you say the current draw is cycling from 0.048A = 48 mA to 0.459A = 459 mA and then back to 48mA and repeats? Then this is power cycling. Can you confirm this?
                              • robka
                                • 12
                                Yes, that’s correct.
                                • mon2
                                  • Dec 2019
                                  • 14239
                                  Is this the same pattern for each USB Type C port? Do check by flipping the adapter cable head by 180 degrees as well. Before doing this, unplug the power adapter -> perform the switch to the other side of the type C blade connector and then power up with the external adapter. Personally do not trust the removal and insertion of this interface while the power is 'hot' from the power adapter.
                                  Perhaps one of the type C ports is stable and does not power cycle / loop? As requested, test topside and bottom side of the power head.
                                  • robka
                                    • 12
                                    https://imgur.com/a/UcIicwK
                                    please see attached photos and descriptions for values.
                                    • mon2
                                      • Dec 2019
                                      • 14239
                                      Concerned about the USB Type C meter. There are silk screened markings for 'INPUT' and 'OUTPUT'. Is this meter not bidirectional? This may be a factor in the review. That is, the power adapter side should be the INPUT and respectively, the logic board should be the OUTPUT.
                                      The contacts look dirty -> use IPA (alcohol) and a Q-tip / cotton swab and clean each side of each USB Type C connector.
                                      • robka
                                        • 12
                                        just verified the function with my M2 MacBook Pro. It shows 2.2amps @ 20v.
                                        Click image for larger version  Name:	contacts.png Views:	0 Size:	3.39 MB ID:	3231211
                                        it's burned
                                        • envym
                                          MacBook Pro 2018 with Activation Lock
                                          by envym
                                          Hi everyone!
                                          I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                                          I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                                          06-27-2025, 08:54 AM
                                        • mattknudstrup@gmail.com
                                          2018 Macbook Pro A1990 2Tb, SSD1 dead
                                          by mattknudstrup@gmail.com
                                          Hello All,
                                          My 2018 Macbook Pro (2TB) crapped out recently, won't turn on. Diagnosed so far as shorted second terabyte SSD1. Question for the forum. I'm thinking about removing or disabling SSD1 and just using SSD0 which will still give me 1Tb usable. I'm assuming all the boot up stuff is all in SSD0. Am I correct about this? If so is there a way to disable SSD1 without removing all the associated components? Will just powering it down do the trick?
                                          I currently have U9580 (TPS62180) removed as it was fried but that is as far as I have gone with it. In other words I...
                                          08-30-2023, 09:15 AM
                                        • pcash0007
                                          Dead 2018 Macbook Pro A1990 820-01041-07 stuck at 5V 0A
                                          by pcash0007
                                          First time looking at a logic board this closely, learnt enough from videos and forums here to be dangerous
                                          I was doing a OS update when the screen went blank at some point. Does not seem to be in DFU mode (checked using apple configurator).
                                          PPDCIN_G3H is 5.16V​
                                          PPBUS_G3H is 0.045V
                                          Resistance between TP_PPBUS_G3H and ground is 23.8 Ohms (which seems low)
                                          F7000 and F7001 seems fine.
                                          From what I learnt seems like there might be short on the down side on PPBUS_G3H.
                                          Is injecting low voltage and see what...
                                          03-07-2024, 06:19 PM
                                        • flat-earther
                                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                                          by flat-earther
                                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                          Windows also shows ''Plugged in'' when charger is not connected.
                                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                          If I let battery run out and say it has 3% Windows will...
                                          06-24-2025, 09:32 AM
                                        • netboy69
                                          Macbook Pro 15, A1990 2018, showing recovery not dfu, error 9 when restore, HELP
                                          by netboy69
                                          Hi to all i have a faulty a1990 from 2018, no liquid damage, died during update, now on configurator i see recovery not dfu, and i get error 9. caps around u7701 show short after removing u7701 and shorted caps still short. can any help....
                                          02-07-2024, 04:34 PM
