HOW BAD IS MY PCB DAMAGE A2338 820-02337 water damage burnt caps
  • TheNuclearOption
    • Jan 2024
    • 31
    Short on ppbus. Taking 3a at 1v and nothing is heating up. I have at least 3 pads that are badly burnt from capacitors. Ive scraped (at least attempted to) not sure how good I did? Are these possibly containing internal shorts? Do you think they need to be scraped more?
  • mon2
    • Dec 2019
    • 14239
    Check their resistance to ground. You may be shorting to the next layer(S) of this multilayer pcb. No power during these tests.
    • TheNuclearOption
      • Jan 2024
      • 31
      Thanks for the replay.
      They all measure at 0.5 ohms (a dead short I think)
      What else can be done if they are shorting to the next layers? Cut them out?
      These are all part of the left speaker channel.
      • TheNuclearOption
        • Jan 2024
        • 31
        There was an internal short. I was able to carve it out. Ppbus is no longer shorted to ground but it is measuring at 21 ohms. I'm getting 12.4 volts at ppbus when plugged in. Is a partial short. Likely still? It's drawing 0.01 amps now on ppbus
        • mon2
          • Dec 2019
          • 14239
          Measuring 12v4 on PPBUS is a good start but the resistance @ 21 ohms does not make sense. Remove all power. Meter in the lowest scale. Then measure the resistance to ground again here. You can also post a picture of your meter face so we can confirm the units of measure of this rail. Perhaps it is 21 kohms here?
          • TheNuclearOption
            • Jan 2024
            • 31
            My mistake, I'm getting 12.24v to ppvbatt and 21ohms I think to ppbus.
            I removed my fuse, it's blown
            • mon2
              • Dec 2019
              • 14239
              To confirm, you have removed the blown use?
              the downstream side of the removed fuse is showing ~21 ohms to ground?
              • TheNuclearOption
                • Jan 2024
                • 31
                Yes I removed the blown fuse. I'm not sure what side's the downstream side but ppvbatt (bottom pad on the motherboard in the photo) is one side of the fuse ppbuss(top pass on the photo) is the other. Ppbuss was showing a short to ground previously until I carved out the internal short. Now it's showing 21 ohms I think. I'm not sure if that photo comes across
                • TheNuclearOption
                  • Jan 2024
                  • 31
                  Did I get that reading right? Does that mean there's most likely a partial short still?
                  • mon2
                    • Dec 2019
                    • 14239
                    A2338 820-02337
                    - having a hard time locating this logic board schematic. Did you mean 820-02773 ?
                    Update: Confirmed that the BV file matches if 820-02773. The pad you are showing in the pic is the downstream side of PPBUS_AON.
                    • TheNuclearOption
                      • Jan 2024
                      • 31
                      Okay thank you. Is that too little ohms for the downside stream of ppbus_aon?
                      • mon2
                        • Dec 2019
                        • 14239
                        Yes, the resistance is too low for a normal rail. Remove all power, meter in the lowest scale on your meter (200 ohm is ok) -> apply one meter probe (either color is ok) on this same downstream PCB pad; other meter probe onto any inductor on the board. What you are hunting for is if a high side mosfet is defective and causing a leak onto another power rail.
                        That is, this high voltage rail of PPBUS_AON is used as a buck convertor by other power rails. This is where a high voltage input is used to create a lower voltage rail by other circuits on the same board.
                        The key concern is that a high side and a low side mosfet will toggle on / off to dial up the desired lower voltage rail. If the high side mosfet is defective then that low voltage rail has been spiked by the high input voltage and this board will then most likely be a no-fix case. To be determined.
                        Probe away and report anywhere you see a low resistance between this pad and the inductor. Then that inductor needs to be reviewed as to which power rail is impacted by this hit.
                        • TheNuclearOption
                          • Jan 2024
                          • 31
                          I'm getting 23.7 ohms on the 3 inductors (L5840, L5820, L5800) on the pp3v3 rail and 21 ohms on the inductor (LF800) on the pp5v rail (same resistance as the downstream ppbus)
                          • mon2
                            • Dec 2019
                            • 14239
                            Measure the resistance from the PPBUS_AON pad of the removed fuse to L5840. One meter probe on PPBUS_AON and other probe on L5840. What is the resistance?
                            Repeat for PPBUS_AON and LF800 inductor. What is the resistance?
                            • TheNuclearOption
                              • Jan 2024
                              • 31
                              about 17 ohms on L5840 and and 14.5 ohms on LF800. That seems very weird to me since I just measured them and got the resistance I mentioned last post.
                              • TheNuclearOption
                                • Jan 2024
                                • 31
                                I measure again, and now im getting around 4 ohms. seems to keep dropping. Im gunna look at the internal short again
                                edit: I injected 1v into ppusb_aon and it's still only drawing 0.05a
                                • TheNuclearOption
                                  • Jan 2024
                                  • 31
                                  I measured again today, 19ohms and 16ohms. Is there a chance there is something wrong with my multimeter? Could it be a partial short moving around slightly?
                                  • TheNuclearOption
                                    • Jan 2024
                                    • 31
                                    I'm not sure where to go from here?
                                    • TheNuclearOption
                                      A2338 water damage with burnt charge port connector
                                      by TheNuclearOption
                                      Hi everyone, I bought a damaged a2338 MacBook pro with water damage and I'm hoping to learn how to fix it. I've worked on electronic for a long time for never attempted repairing water damaged components. The charge port connection on the motherboard along with the USBC connector is burnt. I'm hoping this is worth my effort and I'm not wasting my time. I've sourced some parts but first I was wondering if there was a way to check to see if it was Beyond repair if there was a fried CPU. Is there anything I should check before I order parts?
                                      01-31-2024, 08:57 PM
                                    • edugimeno
                                      Stagg sms12p audio amp has water damage
                                      by edugimeno
                                      Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
                                      I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
                                      There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
                                      There is only one signal wire connecting the first boards...
                                      05-24-2025, 06:00 AM
                                    • gizaha
                                      macbook pro M1 a2338 820-02020 water damage
                                      by gizaha
                                      Small water damage, cleaned it.
                                      Shorted CL002, i removed it carefully with soldering iron, now it has voltage.
                                      5v instant 180ma and then 100ma stable. I didn't found cycling voltage nor shorts in the motherboard.
                                      I don't have pp5v_s2 because uc300 does not get enable pin from u8100 (it gets VIN). pp5v_s2 is not shorted, nor enable pin line.
                                      PP3V3_S2 OK
                                      PP3V3_S2_UPC OK
                                      PP1V5_VLDOINT_MPMU OK
                                      PP3V3_AON OK
                                      PP1V8_AON OK
                                      PP1V25_S2 OK
                                      PP1V8_S2 OK
                                      PP1V8_S2SW_VDD1 OK
                                      PP3V8_AON OK
                                      u8100 did not have corrosion...
                                      07-15-2022, 07:12 AM
                                    • mferna14
                                      Apple MacBook Pro A2338 820-02773-A AON Rail burnt
                                      by mferna14
                                      Hi Dear Friend., I am working on a Apple MacBook Pro A2338 820-02773-A. The history was that the AON Rail on the Trackpad connector JT400 was burnt. After I removed the burnt connector, I tested with the meter & no shorts. Connected the USB C power & all booted fine, no problems at all. I soldered a New TP connector put in the old trackpad with a brand new Flex cable. The laptop beeped in the start but no display. I removed the connector & the display was fine again. USED a known good Trackpad & a Flex cable, even with this still the same problem. I checked the connector whether...
                                      06-25-2025, 11:26 AM
                                    • abajor
                                      A2141 820-01700 Water Damage L8504 Damaged, U3100/U3200 power cycles UB300/UB400 5V .25A
                                      by abajor
                                      Like title says A2141 came in with Water Damage, customer desperately wants the data.
                                      The actual water ingress doesn't appear too bad it sat for a day but was very dusty internally. I have no idea why L8504 was arced there is no apparent moisture there or around the LVDS cable; however, the LVDS to screen screw studs had popped off at some point and somebody tried securing it with kapton tape.
                                      I had to create a micron wire pad jumper to reconnect the south side of the L8504 since the primary pad was blasted down to the vias.
                                      That said after cleaning up the...
                                      12-21-2024, 07:16 PM
