Acer Nitro AN517-52 FH51M LA-J871P Works on battery only. Won't charge.
  • gadgettree
    • Feb 2022
    • 15
    Hi there,
    I am having trouble diagnosing this gaming laptop.
    The laptop does not power on with AC Power only. The battery also does not charge. The laptop turns on when the battery is plugged in, regardless of whether or not the charger is plugged in until the battery dies of course.
    So something is stopping adapter power from getting to the laptop. I checked Adapdet to make sure that the motherboard knows when the adapter is plugged in. That works fine.
    I suspect the first Mosfet isn't turning on but I am unsure how to properly diagnose that 😶.
    I measure 0V across the first mosfet when the laptop is plugged in.
    It's an N channel mosfet and from what I have read online, the way to test it red probe on drain, black probe on source and I should get OL.
    I do get OL, so the mosfet is fine yes?
    I get the same result on the second smaller Mosfet right beside it.
    Click image for larger version  Name:	Voltage Measurement.png Views:	0 Size:	94.6 KB ID:	3225400
    If I am correct, then it occurs to me that whatever is supposed to turn the first mosfet on isn't triggering.
    I am unsure where to find what turns the mosfet on in the schematics. I think the following screen cap would be relevant but I'm not sure exactly.
    Click image for larger version  Name:	Schem Cap.png Views:	0 Size:	75.5 KB ID:	3225401
    Link to schematics and boardview
    Please let me know if you have any other questions. I am hoping someone is able to point me in the right direction here.
    PS: The power adapter is a brand new one that tests fine. The old power adapter wasn't outputting any voltage anymore. Before the old power adapter died, the laptop was working fine. I did a visual inspection and saw no blown components, burn marks, or anything else that I would consider being a problem (water damage signs, or corrosion).
  • mon2
    • Dec 2019
    • 13858
    Hey! The gate voltage will enable or disable the mosfets which is pin #4. Being n-channel the gate voltage must be higher than the voltage on the source / drain pins. So gate voltage should be ~25v to enable. Often, the 2nd dcin mosfet gets kille and takes down the party. See the above sticky by piernov on charger circuits for more details.
    Do check the voltage on pin #4 to ground of this mosfet.
    next, remove all power. Meter in resistance.
    measure the resistance across:
    source (1-2-3) & drain (5-6-7-8)
    source (1-2-3) & gate (4)
    gate (4) & drain (5-6-7-8)
    post each measurement. Repeat for the next dcin mosfet which is suspected to be shorted.
    • gadgettree
      • Feb 2022
      • 15
      Thank you for the response mon2.
      I have taken the measurements as requested and I am not seeing a short at all. I am noticing there is no voltage present at all at the gate of input mosfet 1.
      The measurements are as follows, and a picture for reference.
      Voltage at PQB3 Gate is 0V.
      Removing the power and measuring resistances now.
      PQB3:
      Source and drain: 3.3MOhm
      Source and Gate: 24.1kOhm
      Gate and Drain: 3.3MOhm
      PQB4:
      Source and Drain: 2.89MOhm
      Gate and Drain 2.92MOhm
Name:	N-Channel Mosfet Measurements.png
      I am going to see if I can track down the boosting circuit and see if I can diagnose any failed components on that line. If you have any pointers on where you would start on that front, or if you would go somewhere else entirely I would appreciate any and all hints.
      • mon2
        • Dec 2019
        • 13858
        PQB3:
        PQB4:
        In the mosfet world, the source-gate resistance is very low. Next, check the resistance to ground of the drain pin group (5-6-7-8) of PQB4 which is the main power rail. Post the measurement.
        With your hot air tool, carefully flux and remove PQB4 off the board. After this mosfet is removed, check the source to gate resistance again on PQB3 and the PQB4 PCB pads (with the removed PQB4 mosfet). After the removed mosfet is cooled down and on your work bench, measure its resistance again. Still have the very low resistance across the source & gate pins? If yes, this mosfet is defective and must be replaced.
        PS: The boost voltage circuit is internal to the charger IC. Once the proper conditions are met, the charger IC will boost the adapter voltage to a final voltage of = adapter voltage + REGN = ~19v + ~6 volts = ~25 volts for the gate pin(s) on the DCin mosfets.
        • gadgettree
          • Feb 2022
          • 15
          While PQB4 is still soldered on the drain to ground resistance is odd. It starts with a very low resistance of about 5kOhm and rises to about 50kOhm over about 30 seconds. Maybe my multimeter is charging some capacitors while measuring for resistance?
          After removing PQB4:
          PQB3 Measuring source and gate resistance I get 2.3MOhm
          PQB4 Motherboard Pads Source and Gate resistance I get: 3.3MOhm
          PQB4 mosfet source gate resistance: I am having trouble measuring source and gate pins with my probes, even under my microscope. Is it safe to say the Mosfet is defective at this point and replace it, or do I need to get that reading?
          So, N-Channel mosfets should have a very high resistance between source and gate? What is a normal acceptable range?
          N-Channel mosfets turn on with a gate voltage higher than source.
          How does a P-Channel mosfet work in this regard? Lower voltage on gate than source?
          Thanks for the info on the boost circuit on the charger IC. I got as far as the bq chip and looked at it's datasheet.
          • mon2
            • Dec 2019
            • 13858
            Correct. Good resistance should be at least high hundreds of kohms.
            yes, p-channel requires a lower voltage on the gate than the voltage being passed between source and drain pins.
            yes, just replace this removed mosfet and confirm the resistance is high. Resistance is futile.
            then test again.
            • gadgettree
              • Feb 2022
              • 15
              Awesome. I have ordered a replacement mosfet and I will let you know when it works.
              Thanks for your help, I have learned a lot.
              • mon2
                • Dec 2019
                • 13858
                No worries. The footprints and specs are very common. TI has some great subs at fair prices. Otherwise there is Digikey, Mouser and Arrow electronics.
                • Sephir0th
                  • Oct 2020
                  • 1260
                  Does 19V reach PQB3 Drain? If yes, it sounds more like a issue with or around the charging controller to me.
                  FairRepair on YouTube
                  • gadgettree
                    • Feb 2022
                    • 15
                    Okay. Part came in yesterday and I have soldered on the new Mosfet. I found the same part on LCSC so I used that. The resistances are all in the megaohm range now, so the defective part has been replaced with one that works. The laptop still does not turn on or charge.
                    There is still not a voltage at PQB3 Gate, so perhaps something is wrong with the charging chip as Sephir0th suggested.
                    I have done some measurements around the BQ chip, but I don't really know too much about what I should be looking for, or which measurements matter. The only one I really understand is ACDET which has a voltage of 2.6v when plugged into power, and that makes it to ACDET. I measured the voltages here, and all of this is without the battery plugged in.
                    Click image for larger version  Name:	BQChip.png Views:	0 Size:	89.1 KB ID:	3231837
                    PS: Here is a link to the datasheet for the BQ Chip: Link
                    • Sephir0th
                      • Oct 2020
                      • 1260
                      Regarding your Measurements both DC-IN Mosfets are not internal shorted. ACDET, REGN, VCC and even ACOK (weird!) are present. So there is no obvious reason, that the DC-IN Mosfets don't get ACDRV signal.
                      Check internal resistance of PRB4 and Resistance to GND of charging controller pin 4. if they both measure okay, best advise in my opinion is to replace the charging controller.
                        • 20374
                        Check resistance of PRB7 as well
                        • gadgettree
                          • Feb 2022
                          • 15
                          PRB4 Resistance: 4.8 Ohm
                          PRB7 Resistance: 4 KOhm
                          Resistance to GND of charging controller pin 4 is 1.9MOhm which I am assuming is fine.
                          I had already ordered the BQ chip to replace on this guy just in case, so I have replaced it but it still doesn't charge, nor is there a voltage on the Gate for PQB3.
                          • mon2
                            • Dec 2019
                            • 13858
                            Pin # 3 should not be @ 0v if you have 19v and the posted voltages on the charger IC. Confirm that pin #3 (CMSRC) has ~19 volts to ground. If it does not, it is not soldered correctly or the 4k resistor is not mating onto this pin.
                            There should be a ~4k resistance between the common junction of the DCin mosfets and this pin #3 (CMSRC).
                            Update - ignore the above - the charger IC is being powered by the raw adapter feed and is not due to the flow through the DCin mosfets.
                            Flux and remove PQB1 mosfet and test again. Be sure the polarity of the power adapter is suited for this laptop. PQB1 is used to prevent reverse polarity of the DC power adapter barrel connector.
                            • gadgettree
                              • Feb 2022
                              • 15
                              The resistance is correct between the common junction and pin 3 (4.02KOhm).
                              I will go over my soldering of the charging controller and see if I messed that up.
                              • mon2
                                • Dec 2019
                                • 13858
                                • gadgettree
                                  • Feb 2022
                                  • 15
                                  PQB1 has been removed, the result is the same. 0V on Pin3 of the charging controller.
                                  • mon2
                                    • Dec 2019
                                    • 13858
                                    Flux and reflow your charger ic. The conditions are correct for acdrv to be boosted. Be sure the dcin mosfets are properly soldered. Confirm that pin #1 of the parts are in their correct positions.
                                    • gadgettree
                                      • Feb 2022
                                      • 15
                                      I have reflowed the charging ic a few times. I'm very happy with it at the moment and would be quite surprised if it wasn't soldered on properly at this point. The DC-IN MOSFET as well. I made sure pin 1 of the bq is oriented correctly, as well as the MOSFET.
                                      That being said, I definitely need more practice so I will leave it for a couple days and try again.
                                      Currently it's still not charging or powering on.
                                      • gadgettree
                                        • Feb 2022
                                        • 15
                                        Alright, so I have reflowed the charger IC and it is still doing the same thing.
                                        I know it's not the best picture, as pressing the capture button without shaking the microscope is difficult. But I am confident it is on there properly.
                                        Could it be anything else, or is this still the most likely culprit.
                                        • Jane
                                          How do you test MOSFET in laptops ?
                                          by Jane
                                          I tried to use this method:
                                          Testing an N-channel MOSFET:
                                          Step 1: Discharge the Gate (turn off the MOSFET)
                                          Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                          Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                          Step 2: Charge the Gate (turn on the MOSFET)
                                          Now, place the red probe on the Gate (G) and the black probe on the
                                          09-27-2024, 03:31 AM
                                        • irfan karatela
                                          MOSFET no voltage at gate Quanta G7HA DAG7HAMB8EO
                                          by irfan karatela
                                          I'm working on a HP Pavilion Laptop Model 15-eh1508sa that is missing 19v. I've looked at the schematics and want to know what conditions the ISL9238C checks before it enables the gate for MOSFETs PQ8200 and PQ8201,
                                          I havent found any shorts on the board.
                                          I get 19v at +PRWSRC but around 1.7v at the Drain of PQ8201(+vin)
                                          On Page 82 of the attachment. Link to schematic - https://www.badcaps.net/forum/troubl...ilion-laptop-p...
                                          01-20-2025, 07:15 PM
                                        • tofik
                                          MOSFET equivalent K8A60DA
                                          by tofik
                                          Hello guys,
                                          I have a shorted MOSFET K8A60DA with the following characteristics:
                                          Type Designator: TK8A60DA
                                          Marking Code: K8A60DA
                                          Type of Transistor: MOSFET
                                          Type of Control Channel: N -Channel
                                          Maximum Power Dissipation (Pd): 45 W
                                          Maximum Drain-Source Voltage |Vds|: 600 V
                                          Maximum Gate-Source Voltage |Vgs|: 30 V
                                          Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
                                          Maximum Drain Current |Id|: 7.5 A
                                          Maximum Junction Temperature (Tj): 150 °C
                                          Total Gate Charge (Qg): 20 nC
                                          Rise Time (tr): 25 nS
                                          Drain-Source
                                          07-19-2023, 05:18 AM
                                        • MicroSMD Lab
                                          ASUS ROG Zephyrus GPU Mosfet repeat failure
                                          by MicroSMD Lab
                                          The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
                                          I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                                          01-10-2024, 06:36 AM
                                        • Scotchmist
                                          Asus GA502D keeps blowing mosfet
                                          by Scotchmist
                                          I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
                                          I have removed the mosfet and can run the laptop no problem
                                          The MOSFET is FDPC5018SG
                                          Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
                                          08-24-2024, 02:23 PM
