Dell XPS 9510 LA-K411P Liquid damaged
  • AJ847.63e
    • Aug 2020
    • 171
    • Africa
    Hi All,
    Just wanted to get some advice on a XPS 9510 we have. Unit suddenly decided it no longer wants to turn on. Sometimes pressing the power button, it sits on keyboard lights no picture and boot loops a few times before shutting down. Other times it completely ignores the power button and does nothing. There is no light at the front of the laptop.
    We are getting 20V on all 3 ports so the USB C PD communications working fine. We are getting 12V,3V3 and 5v so it seems like an issue quite late in the power sequence.
    Removed the board and found dust corrosion around the following: PL2801 PC2828 (top right corner above the CPU) which looks like one of the CPU phases. Remarkably none of those components there read short. PL1600 & PL1602 (mid left corner above the second VRAM chip) were completely charcoal due to a shorted line, which seems to be caused by corrosion on a MLCC directly on the other side of the board through 6 via. I have not removed any caps yet though so can't say for sure.I did however remove both burned inductors and it is the bottom pad towards the DIMM slots that is shorted 0.7 ohm. There also is dust corrosion around the passives above UV22 (top left corner diagonally left from the third VRAM chip) and the two MLCCs read dead short which looks like the power regulation for the video memory.
    Given that the corrosion is around the worst two spots on the board, CPU & VRAM, does anyone have known good readings of the CPU and video memory? This board's using GDDR6 Samsung. I don't want to dig into what's happened to find out congrats your GPU or CPU is dead.
    I unfortunately have not been able to find the correct schematic for this board, only the LA-H331P which seems to be the previous year's model. No boardviews either.
    I've attached two photos of the corroded areas for reference.
    Thanks for the assistance.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    PL1600/1602 is VIN for PU1600. Remove PL1600/1602 and checck resistance to GND on both pads of PL1600/1602. Lets first check whether there is any shorting.
    • AJ847.63e
      • Aug 2020
      • 171
      • Africa
      Thanks for the info. Removed both PL1600 & 1602 and found the second pin was shorted (pin closer to the RAM slot, apologies don't have the schematic, so I don't know whether it's pin 1 or 2).
      Turns out the cap I thought was shorted was indeed shorted. The big MLCC that is directly on the other side of the board through the 6 vias next to the two burned inductors. Removed that cap and what do you know she's working!
      Curious to know, what is that line for? Just want to try get a understanding of what happened and what caused it, and more importantly what could of been damaged and weakened in the process. She's working for now, even the 3050ti is showing up in device manager no dreaded error 48. But for how much longer.....?
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        The IC marked BAA on the pic is silergy product used as DC-DC regulator. It can be configured to output 4V-23V,so very likely its either used for 3.3V/5V rail.
        The cap is very important here and should be replaced. In the absence of schematic,try any cap rated for 25V and atleast 1uF(better to use 10uF/25V)
        • AJ847.63e
          • Aug 2020
          • 171
          • Africa
          Ok thanks. The 3v3 and 5V rail were up when I took the board out so hopefully nothings else has been damaged in the process of the inductors going nuclear. Both inductors have been replaced along with the cap so this should be good to go.
          Thanks again for your assistance.
          • master3112
            • Mar 2024
            • 81
            • Slovakia
            I have a Dell XPS 15 9510 and the device won't start. I found out that there is no voltage at the BIOS chip Winbond 25Q16JWIQ. At the Winbond 25R256JVEN has 3.3V present. When I connect a power supply unit, the device has a current consumption of 0.05A. After 10 seconds the consumption sings to 0.002A. Does anyone know where the 25Q16JWIQ is supplied with power? Does anyone have a circuit diagram for the device?
            • master3112
              • Mar 2024
              • 81
              • Slovakia
              I have measured all voltages at all PIN of the ISL9538CH, as described in the article by reeluff.Link: https://www.badcaps.net/forum/troubleshooting-hardware-devices-and-electronics-theory/troubleshooting-laptops-tablets-and-mobile-devices/3213351-dell-xps-15-9510-la-k411p-nvdc-isl9538c-no-boot-no-charge#post3213351
              My Results:
              4 I have 15V instead of 12V
              5 I have 14V instead of 10V
              6 I have 10V instead of 7V
              7 I have 1V instead of 2.3V
              9 I have 1V instead of 2.3V
              10 I have 10V instead of 7V
              11 I have 10 V instead of 7V
              12 I have 10 V instead of 12V
              13 I have 0.2 V instead of 9V
              31 I have 0V instead of 11.4V
              I probably have no voltage at PIN 31 because my battery was not connected. The only noticeable deviation is at PIN 13, where I have 0.2V. Since all other voltages match the specifications from reeluff, I assume that the ISL9538CH is OK, or what do you think? Does anyone have any idea why the voltage at PIN 13 is different and what else I can check?
              THX
              • mon2
                • Dec 2019
                • 14263
                If the voltage is not matching your golden sample list of voltages, remove all power -> meter in resistance mode (not diode mode). Measure the resistance to ground of pin #13. Post the measurement and the units of measure. One meter probe on pin # 13; other meter probe on ground (shield is ok). Even better if you post a pic of the meter face for a quick review.
                • master3112
                  • Mar 2024
                  • 81
                  • Slovakia
                  I have measured the resistance at pin 13 of the ISL9538CH against ground. This is 3.493MOhm. See pictures. AJ847.63e have you already solved your problem? If not and you still have your device, we can take a few measurements on the board and exchange ideas.​
                  • master3112
                    • Mar 2024
                    • 81
                    • Slovakia
                    I also measured the charging circuitry and noticed that the battery is not being charged. The battery voltage is 11.2V when it is not connected. When the battery is connected to the mainboard, without a power supply, the gate of the PQ1905 and also pin 31 of the ISL9538CH are 11.2 V (battery voltage). If I disconnect the battery and only connect the power supply unit, the voltage at the gate of the PQ1905 and also at pin 31 of the ISL9538CH is 12.5V. The voltage at the output of the PQ1905 is 0V. When I connect the battery and power supply, I measure 13.3V at the gate of the PQ1905. However, the voltage at the output of the PQ1905 and at the battery is only 11.2V. The voltage at the input of the PQ1905 is 12.56V. The device has a current consumption of only 0.045A and the battery is not charged. The resistance at the output of the PQ1905 to ground is 3.7MOhm. There is not a short. The PQ1905 is an B07P03 (see picture, but I could not find it anywhere. I could only find a B07N03, I don't know if this one is identical.) If there is a voltage at the input of the PQ1905 and also at the gate of the power controller ISL9538CH (pin 31) and the PQ1905 is OK, the battery should normally be charged, or not? Does anyone have any information on this? It does not explain why the 25Q16JWIQ does not receive a power supply. But it doesn't seem to be OK either.
                    Last edited by master3112; 03-26-2024, 06:35 AM. Reason: More information about the battery charging chip
                    • master3112
                      • Mar 2024
                      • 81
                      • Slovakia
                      I continued to look for faults and measured the transistors for the 3.3V and 5V voltage. I also measured and listed the gate voltage. I measured whether the 256MB Winbond 25R256JVEN is connected to this 3.3V rail. It is not. Maybe someone needs it.
                      • master3112
                        • Mar 2024
                        • 81
                        • Slovakia
                        I have also measured that 12V is present at the AKUN 650 (see photo.Does anyone have a datasheet for this IC?). The output is switched through to PIN 10 of the RAM memory. I assume that this is the power supply for the RAMs. I would expect 1.5V at the output, but I could not measure any voltage there. It is possible that this is only switched on at startup. Does anyone know which PIN the power supply for the RAM should be connected to? Is it PIN 10 as I assume?
                        • majkel_27@o2.pl
                          • Sep 2013
                          • 26
                          • konin
                          Hello, I am asking for help in identifying the element marked as UZ7, system sot-23-8, symbol 516A5
                          • mon2
                            • Dec 2019
                            • 14263
                            Post a clear pic of the part. SOT23-5 package?
                              • 21035
                              AKU* NB685GQ QFN-16 (3mm x 3mm) ​.Datasheet - https://www.monolithicpower.com/en/d...en/sku/NB685GQ
                              https://www.badcaps.net/forum/troubl...20#post1482820
                              Marking List April 2022 https://www.badcaps.net/filedata/fetch?id=2089349
                              • majkel_27@o2.pl
                                • Sep 2013
                                • 26
                                • konin
                                Witam, proszę o pomoc w identyfikacji elementu oznaczonego jako UZ7, układ sot-23-8, symbol 516A5
                                • majkel_27@o2.pl
                                  • Sep 2013
                                  • 26
                                  • konin
                                  another one was inserted in this place but it worked for 5 minutes and died, at the bottom of the photo there is 516A5 and there was one but I can't identify what it is
                                  • majkel_27@o2.pl
                                    • Sep 2013
                                    • 26
                                    • konin
                                    To powinny być ten sam układ
                                    • XxMicroSoldering
                                      ASUS Rog Strix G17-712LV Laptop Liquid damaged
                                      by XxMicroSoldering
                                      Hello Guys
                                      I have a ASUS Rog strix laptop that I bought recently to fix and the previous owner spilled water on it . He brought it into a repair shop for them to check it out and instead of fixing it they damaged the battery connector of the laptop ! Other than that they damaged damaged nothing . But since the liquid damage the laptop only turns on and the keyboard lights up and then immediately turns off. I really want to repair this laptop and I also have experience in repairing phones etc and laptops and a bit of soldering but the diagnosing part is where I need help with and...
                                      10-17-2024, 10:45 AM
                                    • bigbadbios
                                      a2338 2020 Macbook Pro liquid damaged won't turn on- weird issue
                                      by bigbadbios
                                      I am trying to fix this liquid damaged 2020 Macbook pro and I noticed something weird.
                                      When I push on/around the renesas 501cr0b IC, which appears to be a clock generator/ multiplier, If I apply lot of pressure, the device will reach 19.9 volts and seems to be trying to work.
                                      I have thoroughly reflowed that area and completely removed that chip (there was some liquid stain in that area) but no help. I have just 5v 0a unless I apply the pressure.
                                      Your help is GREATLY appreciated. Thanks!
                                      08-18-2024, 05:47 PM
                                      DELL XPS 9510 Notebook 15 Specification for Upgrade or Repair
                                      This specification for the DELL XPS 9510 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9510 boardview and 9510 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS 9510 Notebook...
                                      09-07-2024, 02:50 AM
                                      09-07-2024, 02:00 AM
