A2338 M1 Not turning on - Repaired slightly but still having issues
  • mon2
    • 14747
    This may be one of the bastard macbooks that needs a good battery to boot. Can you test with a charged battery?
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 676
      O M G YOU ARE RIGHT I will do that test now and see I do have a spare M1 top case laying around somewhere ill do that shortly....
      sigpic
      MEOWING IN THE IMPOSSIBLE UNIVERSE!
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 676
        Well, lucky for us we have a spare MacBook Pro 13" M1 base model in stock, battery works on it but need to charge it. I will come back with my findings
        sigpic
        • Stephen
          Meow Meow MEOW!
          • Apr 2020
          • 676
          Update: swapped out good MacBook top case with good board and put the board we fixed into the top case, battery was left at 30 percent charge. No power, no DFU showing up or recovery, no shorts presently showing on Thermal Imager. When trying to attempt DFU input, the meter shoots up to .28 amps staying at 5Volts. :/
          When holding power button only, no spike in amps, but when you input the exact DFU keys the meter spikes up to .30 amps then stays at .28amps then once you let go, it drops to .02 amps
          Upon checking further: it seems the UC300 Rail has no power on the ENABLE Signal, however I just replaced the APL 1096 chip and the short went away once I did that. Would a faulty UC300 cause the signal to not move forward? I am seeing this has no voltage readings whatsoever and that it needs it.
          sigpic
          • Stephen
            Meow Meow MEOW!
            • Apr 2020
            • 676
            I replaced UC300 and then I found a short on the board after doing that. Why is UT620 shorted? this is the power Touch ID area? That area was reaching 320 degrees and higher that is ABNORMALLY high for a short.
            I replaced that chip, but it keeps shorting out, so something is forcing that area to keep shoring. When that area is replaced the board jumps up to .45 amps then drops down to .33amps and stays until that area gets super hot. It came back once I replaced UC300. So I am assuming this is the cause why this board is not turning on.
            checking further Q5840 is showing 120 degrees and rising. So these two areas are showing up after replacing UC300.
            Right now currently the Board is sitting at .47A
            sigpic
            • Stephen
              Meow Meow MEOW!
              • Apr 2020
              • 676
              Hey mon2 got any ideas?
              sigpic
              • szape
                Macbook A2338 M2 (820-02773) not turning on
                by szape
                Hello!
                I have a Macbook Pro M2 2022 which does not turn on. Both ports have the same behaviour: 5v, then 20v then meter turns off and restarts.
                DFU mode works but trying to recover in Apple Configurator fails (Unexpected device state 'DFU' expected 'RestoreOS' (Probably forced into DFU mode externally)). Apple logo comes on, after 20-30 seconds apple logo disappears but backlight stays on for a minute and then switches off completely at the restore process.
                Charging works in DFU mode.
                PPBUS_AON is fluctuating between 12V-12.4V (diode mode reads...
                08-20-2025, 09:41 AM
              • alex1105
                Asus TUF A15 issues turning ON
                by alex1105
                Hello, I have the following laptop:
                Asus TUF A15
                Model: FA507XI-LP018W
                Motherboard: DA0NJSMBAD0 REV: D; Model: NJS
                Issue: It powers on, all the leds work but there is no video signal at all, neither on the original display nor on an external display. Also the coolers don't move at all, even though they get power. And to turn it off i need to keep pressing the power button for 10 seconds.
                The laptop had the motherboard battery connector completely sheared off, so I had to solder it back. I'm not sure how that happened but i didn't open the laptop at all, until...
                08-28-2024, 01:58 AM
              • MyronViegas
                A1466 Dead and Not turning on. Had repaired it before
                by MyronViegas
                Hi guys, I have an A1466 (820-00165-A) board which came in dead, had corrosion on R7181 near ISL6259 chip. I removed corrosion and replace R7181 and the macbook powered on.
                After sometime I didn't get any light on the charger but fan was spinning and I was getting battery charge logo on the screen, so I replaced the ISL6259 chip and it came on! everything was working fine.
                (NOTE: Customer had previously got the battery replaced from another shop and it was third party bad quality)
                I had used my test SSD and my known good original battery.
                11-10-2023, 03:29 AM
              • jkruns
                M1 A2338 screen and touchbar issues after cleaning up liquid damage
                by jkruns
                This is my first post after browsing this wonderful treasure trove of knowledge for many, many evenings. I've decided to learn how to fix these things, properly.
                My patient is an A2338 Macbook Pro M1 (late 2020).
                It had some corrosion around JT710 and JT700 caused by liquid spill, as well as against the protective barrier around the USB-C chips UF000 and UF100. So I took the main board out and cleaned it with a toothbrush and alcohol, then with alcohol in an ultrasonic cleaner. Cleaned the touchbar flex connectors as well. The board looks...
                04-22-2024, 06:45 AM
              • gretti
                MSI Z370-A Pro, works but does not power off or reboot and USB issues
                by gretti
                I have a MSI Z370-A Pro. The board does not reboot or shut down from the Windows recovery console. USB communications stop and the status light on USB 1 stays on and does not blink. I have programmed a new BIOS with a CH341A programmer already, swapped RAM, PSU, CPU. The board will power off when the power button is held and resets when the reset switch is pressed, but it will not react to the reset switch if already told by software to shut down or restart. The board will reboot from BIOS after a save and exit command.
                The MSI BIOS included the ME firmware for the board. The size...
                10-16-2025, 02:14 AM
