Asus X1403ZA rev 2.1 no power short on main
  • johnbeton
    • Jun 2021
    • 95
    • Belgium
    I have an Asus X1403ZA board. Came in with no power or charge light. One screw of the hinges let loose and was dancing around inside the laptop.
    I have 19v coming in the first mosfet, but nothing on the source or gate. (also no voltages on other rails, no shorts on coils)
    The current resistor and source of the second mosfet are short to ground. I have looked for schematic or boardview, but nothing to be found.
    Anyone have tips where to start ?
  • shiyab
    • Sep 2023
    • 1238
    • india
    5V &3V CHEK
    • mon2
      • Dec 2019
      • 13837
      Review the topside markings of the DCin mosfets and also the nearby charger IC. Post each of these details for a review.
      Post pics of your logic board where you are noting the first mosfet to save on some time against the review of the boardview file.
      From the BV review,
      PU8901 BQ24800RUYR//TI is the charger IC.
      PQ8901 & PQ8902 DCin mosfets are the suspects. Carefully flux and remove the 2nd DCin mosfet.
      Check this removed mosfet after it is cool and on your work table. Likely it is defective.
      Here is the link for the BV file for this board:
      Asus X1403ZA Boardview file - Badcaps
      • johnbeton
        • Jun 2021
        • 95
        • Belgium
        i have no 5v or 3v
        PQ8901 and PQ8902 are E180AJ
        PU8901 is BQ24800TI 258 A1J3
        I removed the second mosfet. From Source to drain I have 1.8Oms resistance, from Source to gate and drain to gate no continuity.
        After removing the second mosfet still 0v after 1st mosfet
        • shiyab
          • Sep 2023
          • 1238
          • india
          19 V CHEK
          FULL
          • mon2
            • Dec 2019
            • 13837
            Is the 1R8 ohm's resistance measurement of the removed mosfet that is on your work bench? Or is this the measurement of the pcb pads on the logic board after removing the 2nd dcin mosfet?
            continue to measure the resistance of the first dcin mosfet that is on your logic board.
            measure:
            source (1-2-3) & drain (5-6-7)
            source (1-2-3) & gate (4)
            gate (4) & drain (5-6-7-8)
            post each measurement. No power during these checks.
            • johnbeton
              • Jun 2021
              • 95
              • Belgium
              The 2nd mosfet was measured on the mosfet itself on the bench.
              These are the measurements on the 1st mosfet (still on the board, 2nd mosfet is still removed):
              source (1-2-3) & drain (5-6-7) = 167 Ohm
              source (1-2-3) & gate (4) = nc
              gate (4) & drain (5-6-7-8) = nc​
              • shiyab
                • Sep 2023
                • 1238
                • india
                measure:
                19 V CHEK THEN 5V&3V
                • johnbeton
                  • Jun 2021
                  • 95
                  • Belgium
                  Hello Shiyab, I checked 19V, it is present before 1st mosfet, but not after.
                  No 5V or 3V present.
                  I have been trying to follow the traces by the boardview. I notice very low resistance to ground on AC_BAT_SYS (12 ohms). Is this something ?
                  • mon2
                    • Dec 2019
                    • 13837
                    The first mosfet also appears to be shorted. Remove it and confirm the same resistance measurements. Both mosfets will need to be replaced but first need to check if there are other shorts in this area of the logic board.
                    • johnbeton
                      • Jun 2021
                      • 95
                      • Belgium
                      OK, removed both mosfet, now I have no NC on the board in every combination (D S G)
                      I tested both mosfets on the bench with the multimeter in Diode-mode. Both have the same result: I have open circuit from Source to Drain, and NC on all other combinations.
                      • mon2
                        • Dec 2019
                        • 13837
                        Requested resistance (not diode) measurements so we can compared against other mosfet readings. A low resistance measurement means the mosfet is shorted. The 1R8 = 1.8 ohms is a short on the mosfet from the removed 2nd mosfet.
                        Continue to check in resistance mode the PCB pads where these parts used to be onboard. That is, check the resistance to ground of the source (1-2-3) to ground; then gate (4) to ground; then drain (5-6-7-8) to ground.
                        Post each measurement. Again, if there is a low resistance measurement on any of these PCB pads, then there may be a shorted component onboard that needs to be reviewed.
                        • johnbeton
                          • Jun 2021
                          • 95
                          • Belgium
                          Ok, i did wrong the previous time, here are the measurements on PCB Pads:
                          1st mosfet
                          Source - GND: NC
                          Gate - GND: NC
                          Drain - GND: 68.2k
                          2nd mosfet:
                          Source - GND: NC
                          Gate - GND: NC
                          Drain - GND: 12 ohms
                          • mon2
                            • Dec 2019
                            • 13837
                            The 12 ohms to ground means that you have a shorted part on this main 19v rail. Would you have an adjustable power supply?
                            need to use it to inject 1 volt (no higher) at 3-5amps onto this rail. Then inspect on who is heating up.
                            • johnbeton
                              • Jun 2021
                              • 95
                              • Belgium
                              Yes, I have a power supply, I injected 1 volt, at first 3amps then went up to 5amps (rail is pulling around 0.9A). I injected this on the drain of the 2nd mosfet. But nothing getting hot or even warm. I can only test with feeling around and using IPA.
                              • mon2
                                • Dec 2019
                                • 13837
                                Check the heat from the CPU / PCH without the heatsink.
                                • johnbeton
                                  • Jun 2021
                                  • 95
                                  • Belgium
                                  the cpu and PCH don't warm up, not even a little bit.
                                  On inspecting all components in AC_BAT_SYS, I noticed PJP8102 looks like it is pressed down a little bit, maybo from that screw, I dont' know.
                                  Could it be possible this is short to ground from a trace underneath ?
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    Keep injecting 1V/5A for 15 mins and then see if any area is slightly warm.
                                    • shiyab
                                      • Sep 2023
                                      • 1238
                                      • india
                                      chek mosfet get voltage then ok change the mosfet
                                      chek mosfet out put shor or normal
                                      • johnbeton
                                        • Jun 2021
                                        • 95
                                        • Belgium
                                        I injected 1V/5A for about 20 mins, the cpu feels a little bit warmer than the rest of the board. No other components feel warm.
                                        IPA on CPU vaporises very slow, but little faster compared to other areas.
                                        So this is probably end of story ?
                                        • Scotchmist
                                          Asus GA502D keeps blowing mosfet
                                          by Scotchmist
                                          I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
                                          I have removed the mosfet and can run the laptop no problem
                                          The MOSFET is FDPC5018SG
                                          Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
                                          08-24-2024, 02:23 PM
                                        • jkyoho
                                          ASUS TUF FA506IV-AS76 vram mosfet short, then battery cant charge
                                          by jkyoho
                                          I recently fixed a FA506IV cam with Vram mosfet short on Vin(19v)to ground. Got both mosfet replaced and now laptop could turns on and GPU everything works but battery not charging. Battery status shows 100% on both BIOS page and Windows system.
                                          Measured voltage got 0.3v on battery red lead not going up. charging mosfet gate low and 19v not passing through inductor.
                                          I also tried dc bench supply 14v charge directly onto battery but seems not drawing anthing.
                                          Any idea?
                                          07-11-2022, 03:39 PM
                                        • aaronkatrini
                                          DELL Nvidia GTX 750Ti Mosfet goes short after a few minutes
                                          by aaronkatrini
                                          I have recently picked up this Dell OEM Nvidia GTX 750Ti 2GB Video card. Its an old card I know but still wanted to get it working if possible. The problem is the following:
                                          - Put the card in my testing motherboard and start running Heaven benchmark
                                          - Benchmarks seems to run smoothly up until half way then the motherboard completely shuts off immediately
                                          - Try to start it again and I get a slight move from the PSU fan - a clear short
                                          - A little troubleshooting later I find one shorted Mosfet - Replace them both - short is gone
                                          - Put the...
                                          05-18-2025, 04:18 PM
                                        • joshAU
                                          Acer AN515-55-528T FH52M LA-J891P - Short ciruit after PQW1 MOSFET on +1.35VSDGPU rail.
                                          by joshAU
                                          Hi all.
                                          This notebook was showing no signs of life.
                                          I removed the FH52M LA-J891P mainboard and found that there was 19V at the DC jack.
                                          However there was zero volts on the two PRB2 and PRB46 resistors immediately after the two polarity protection MOSFETs (PQB11 & PQB12).
                                          If I remove the PQW1 MOSFET, the 19V rail starts working, and I can turn on the unit - at least I get the fans, and the power light comes on, when I simulate the power button being pressed. No display.
                                          I tried replacing the MOSFET with a new one, but again no voltage on the...
                                          05-29-2024, 12:33 AM
                                        • OOF DIO
                                          ASUS FX505DV no power shorted at PWM controller Pin 3 VREG3 TPS51225C, need pinpointing of the short.
                                          by OOF DIO
                                          (If anyone has a functional boardview file of FX505DV/DU that would be helpful)
                                          (Had 3 problems, now just 1)
                                          I have no experience or knowledge and usage of tools to repair devices besides the entire past 12-10 days of researching, watching YouTube repair videos and troubleshooting this laptop motherboard. ChatGPT was used as a guide to ask questions.
                                          I used boardviews of mostly FX505GD-M, and some FX505DU, FX505DD. Used schematics of FX505DU.
                                          I had originally intended to replace the BQ24780s first (due to previous battery removal while benchmarking) but I...
                                          04-19-2025, 05:03 PM
