Macbook Pro A1989 820-00850 No Power
  • rarinpear
    • 9
    • Italy
    Hi all!
    I have a Macbook A1989 820-00850 that completely died out of the blue.
    I have used a usb tester and the computer is (not) drawing 5v 0amp.
    I have now taken the board out and there are no visual clues of components going bad.
    Can you help me diagnose the problem?
  • mon2
    • Dec 2019
    • 14212
    Carefully measure the voltage to ground @ F7000 - check both sides. If the voltage is not in a normal range, power down and configure the meter into RESISTANCE mode. Remove all power / no battery. Measure the resistance to ground on each side of the fuse F7000.
    If the resistance to ground is low, carefully flux and remove F7000 fuse. Allow the board to cool and then measure the resistance to ground again on each side of the remove fuse PCB pads @ F7000.
    Which side of the removed fuse is with a low resistance? Post each measurement.
    • rarinpear
      • 9
      • Italy
      The voltage on both of the F7000 sides cycles between 1.1 and 0.95 v.
      Resistance to ground is 1 (infinite? measured with the 2M ohm setting of my multimeter).
      should I remove f7000? this might take some time as I do not have a hot air station here
      • mon2
        • Dec 2019
        • 14212
        Suggest to use a lower resistance scale and measure this fuse again. Short your probes and you should read ~0 ohms. Measure the resistance to ground again at the fuse. If you read a '1' then the resistance is too high to measure and a higher meter scale should be used. Either way, you should have a lower resistance on this rail. At this time, you do not need to remove F7000 unless we can confirm there is a part that is shorted on this power rail.
        Next, with the meter in DC volts mode (20v or higher), measure the voltage to ground of PPDCIN_G3H.
        • rarinpear
          • 9
          • Italy
          My multimeter does not have OL, it reads 1 instead. It reads 1 when measuring resistance to ground of F7000 (both sides), under all ranges (2M - 200).
          Resistance on F7000 (probes on the two ends of F7000) is close to 0 (resistance of the cable).
          The voltage to ground of PPDCIN_G3H is 5.16v, measured at the test point on the left of C8464.
          • rarinpear
            • 9
            • Italy
            Hi all!
            Diagnosis (following repair.wiki and CD3215 Bootup Sequence):
            PP3V3_UPC_**_LDO - 3V3, present, for all 4 CD3215s
            PP1V8_UPC_**_LDOA - 1V8, present, for all 4 CD3215s
            PP1V8_UPC_**_LDOD - 1V8, present, for all 4 CD3215s
            PP1V1_UPC_**_LDO_BMC - Not Present, for all 4 CD3215s
            is it an indication of a bad cd3215? Is it normal for me to observe PPDCIN_G3H (see my last reply)?
            • mon2
              • Dec 2019
              • 14212
              PP1V1_UPC_**_LDO_BMC ; should be present for the active USB port used to power the logic board. Remove all power and measure the resistance to ground of this rail. Also test in DIODE mode. With no power, red meter probe to ground; black meter probe to this LDO rail.
              • mon2
                • Dec 2019
                • 14212
                Sharing a diode chart for the inductors on this board. Remove all power. Meter in diode mode. Red probe to ground. Black probe to the inductor to test.
                • rarinpear
                  • 9
                  • Italy
                  resistance to all PP1V1_UPC_**_LDO_BMC rails is 130k ohms.
                  Diode mode beeps for all inductors in groups 3 and 2 (L7220, L7210, L7410, L7420, L7430).
                  • mon2
                    • Dec 2019
                    • 14212
                    Yes, the low voltage rails will tone beep due to the very low resistance to ground on the respective tested rails. What about the other inductors on the board? Do their diode mode readings match the posted reference diagram?
                    • rarinpear
                      • 9
                      • Italy
                      Here are all the measurements in diode mode (red on ground):
                      Inductor: Expected - Actual
                      L9021: 273 - 320
                      L9020: 273 - 320
                      L9030: 349 - 295
                      L9080: 358 - 310
                      L9081: 358 - 310
                      L6900: 362 - 316
                      L6901: 362 - 316
                      LB700: 190 - 407
                      L8102: 28 - 130
                      L7270: 12 - 35
                      L8100: 116 - 199
                      L7220: 3 - 9
                      L7210: 3 - 9
                      L7410: 2 - 9
                      L7420: 2 - 9
                      L7430: 2 - 9
                      L7702: 56 - 70
                      L7600: 401 - 334
                      L7660: 413 - 348
                      F7000: 390 - 332
                      L7030: 472 - 385
                      L8410: 840 - 806
                      L3500: 217 - 412
                      • rarinpear
                        • 9
                        • Italy
                        I also checked and 5v are being fed to U7000 (isl9420), but then I get 0v on PP3V3_G3H, is that normal?​
                        • mon2
                          • Dec 2019
                          • 14212
                          PP3V3_G3H is created by U7650. If it is 0 volts at the output then there could be an excessive current event on this rail and/or the ENABLE pin is not turning on this power rail.
                          Remove all power. Meter in resistance mode. Measure the resistance to ground of this power rail. What is the measurement? Checking for an out of the normal range resistance on this leg. If it is too low, there is a shorted part onboard.
                          • rarinpear
                            • 9
                            • Italy
                            Diode mode reads 350. I cannot measure resistance because it changes while I am reading it (it either keeps increasing or decreasing for reasons I do not understand).
                            • ErinV
                              MacBook Pro A1989 820-00850-A not powering on
                              by ErinV
                              Hey everyone!
                              I have a MacBook Pro A1989 with a 820-00850-A board that recently stopped working. I used it overnight to charge my phone, in the morning it didn't turn on, I assumed flat battery but now won't charge and doesn't start at all.
                              I have fully dissassembled it, when disconnected the battery reads at 0.012V. Even with the battery disconnected the laptop doesn't boot.
                              The diode voltages around all 4 CD3215's seem fine.
                              For all CD3215 (UB300, UB400, U3100 and U3200) I read just above 5V on PP20V_USBC_TA_VBUS, 3.3V on PP3V3UPC_TA_LDO, 1.8V...
                              09-30-2024, 10:21 PM
                            • Madoy104
                              Macbook Pro A1989 - No image, working fine with external monitor
                              by Madoy104
                              I have a MacBook Pro A1989 that was likely exposed to liquid. It doesn't display an image on the built-in screen, but the screen is backlit (you can't see the Apple logo or any other elements when held up to light). The laptop provides 20V and 1.5-2A, and it works fine when I use it with an external monitor. Currently, the connector for the display (J8500) is disconnected. I'm writing to ask for help in diagnosing the issue. I've heard that when the J8500 is exposed to liquid, the processor pin responsible for the display might short-circuit, and I'd like to know...
                              08-15-2024, 10:01 AM
                            • PITERPENY
                              Macbook A1989, 820-00850, won't boot. 20V, 0A.
                              by PITERPENY
                              Today I have a MacBook A1989 at work 820-00850. When assembled, the laptop switches to 20 volts but the consumption is 0.00 ampere. if the motherboard is on the table then the consumption of all ports is 5 volts and0.35 amperes and does not go to 20 volts only if you assemble a MacBook.
                              Here are some measurements, maybe someone can tell what the problem is.
                              The initial problem was a burnt out induction coil L8504 (replaced).
                              When connected to another MacBook, it constantly hangs in dfu and cannot install updates, something is wrong.
                              here are some measurementsmotherboard...
                              01-16-2024, 02:19 PM
                            • Nikan.e
                              MacBook A1989 repair / no CPU voltage no boot signs
                              by Nikan.e
                              Hello everyone.
                              I have recently obtained a MacBook Pro A1989 model with a touch bar and Apple ID. Unfortunately, it does not want to start up.
                              No CPU Voltage.
                              U7800 Does produce voltages.
                              T2 Chip warming up very very little.
                              I do have voltages like 1.8, 0.9, 3.3, 2.5 volts, etc., present. I did not find any short circuits. Unfortunately, the device has no touch ID/start button. So, I have used the debug jumper to put the device into DFU mode. - It is getting recognized as a Macintosh while not in DFU mode and as Apple (DFU) while in DFU mode....
                              11-24-2023, 11:55 PM
                            • biosdi
                              MacBook Pro A1989 trackpad and keyboard not working
                              by biosdi
                              Hi guys.
                              I Just replaced battery on my MacBook Pro A1989. Unfortunately doing that, I’ve broken the trackpad flex cable (821-01701-a), and I’ve already ordered a spare one. At the same moment I’ve noticed that also the keyboard it’s not working anymore and I’ve found an SMD chip unsoldered and moving freely inside the backplate. I can read L20L on the chip. Is something could explain the keyboard not working or the keyboard doesn’t work due the unconnected trackpad?
                              thanks...
                              04-17-2025, 09:42 AM
