HP Omen 17-W202NV Error 90D
  • tech_guru
    • Nov 2018
    • 44
    • Greece
    Hello.
    I am facing an issue with this laptop HP Omen 17-W202NV with motherboard: DAG37DMBAD0 REV D G37D 915467-601 which has a weird symptom.
    It turns on and shows at post, error 90D (overheating issue). It starts immediately fans at full speed. Then once it goes to login screen, it shows the logo for half second and it shuts off, and in the next boot it shows again 90D error.
    If you stay in the BIOS menu it does not turn off. I also managed only 1 time to boot into Strelec WinPE temporary system to diagnose and it did not show the NVIDIA gpu in the HWInfo. Looks like it's missing somehow.
    I have tried until now:
    -Flashed Clean ME bios
    -Cooler is working, transfering heat, thermal paste is replaced
    -Temperature is not rising. Looks like the error is fake.
    -Measured THRM_MOINTOR1 and THRM_MOINTOR2 using schematics and boardview (please attach them if available, I have them with watermarks) and they were above 2.5v when it was turning off suddenly, which I think looks normal...
    Any ideas what to check next, please?
    Thank you in advance.​
    • 21874
    Originally posted by tech_guru
    -Measured THRM_MOINTOR1 and THRM_MOINTOR2 using schematics and boardview (please attach them if available, I have them with watermarks) ​
    Use the forum search.. when you find them just post the link to them https://www.badcaps.net/forum/troubl...37dmbad0-rev-d
    • Sus256
      HISENSE 65E7KQ PRO - no boot
      by Sus256
      Hi all!
      HISENSE 65E7KQ PRO
      RSAG7.820.13512 - chassis
      MT9618BAATAB - cpu
      RSAG7.820.12059 - power
      HD650Y3U77 - panel
      KLM8G1GETF - emmc
      Replaced emmc.
      Terminal log
      UART
      AC_ON
      E-B
      FDE enabled
      06-01-2025, 02:11 AM
    • questore
      HP OMEN 15-ce012nh give error code 5long 3 short after CPU LOW SIDE MOSFET BURN
      by questore
      Hello everyone.
      Someone brought this poor hp in.
      All power rails had normal resistances so i turned it on. Instant power cutoff...
      First mosfet was shorted so replaced it...
      After that I have tryed to start since no short was on the main power rail. the CPU middle dual mosfet heated up and protection shut down the laptop.
      After investigating i have found that when the mosftet turning on then the mostfet got instantly hot (not the CPU)
      Removed the faulty mosfet. -> now laptop turns on CPU mildly gets hot but laptop gives the common 5 long 3 short LED...
      08-25-2025, 10:09 AM
    • sushilachuthan
      APC UPS error P13
      by sushilachuthan
      one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
      the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
      The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
      We replaced the SCR with new device,, but the device is not power on as expected.
      Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
      09-26-2025, 09:00 AM
    • Superbee_dad
      Sharp 80” long short flash backlight error - Help
      by Superbee_dad
      Hello Sharp TV experts
      Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
      > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
      > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
      01-24-2025, 11:51 PM
    • ktmmotocross
      HP Omen 17-an108nc - 3long and 2 short/memory error/ after capacitor short on 5V line
      by ktmmotocross
      Hello.
      I have this HP Omen 17-an108nc that show 3long and 2 short/memory error/ led blinks on Caps-lock after capacitor short on 5V line.
      Come with one shorted capacitor on 5V line. After replce it just blinks memory error. i flash main and EC bios but still the same. I have all voltages on start, cpu fan spining, but onli capslock blinks and no picture
      any hint?
      01-03-2023, 06:07 AM
