Lenovo B50-50 (80S2) No display no Post
  • toty79
    • Mar 2019
    • 42
    • Italia
    Hello friends and welcome back,sorry for my English but I'm in Italy and I'm using a google to translate
    Main board CG410/CG510 NM-A681 rev 1.0
    I have this Lenovo laptop under repair with strange behavior, no display at first I thought it has a corrupt bios but now after disassembling it I have doubts, the laptop turns on automatically after inserting the charger without pressing the power button, If I hold down the power button for 8 seconds, it turns off for 1 second but turns on immediately after 1 second, so you can't even turn it off, tested with and without RAM, same behavior, the power light is always on and the battery light flashes which is loading normally, CMOS reset carried out without results, external monitor also tested without changes, 3V voltage present on UC3 (SPI W25Q64FVSSIQ) carrying out some measurements to detect the presence of a short circuit, I note that there is a short circuit at the ends of PC708, and next to it PQ39 ( Mosfet N AON6764) I detect a short circuit between drain and source, if I'm not mistaken this area is used to generate the CPU-CORE voltage which is equal to 0v, the cpu is completely cold, the fan does not move at all but 5v is present, I state that these measurements are made on PCB with soldered components, being SMD I wouldn't want to mess with the soldering and restrict it to the minimum possible, any advice is well accepted and thanks in advance
    The two components mentioned above can be found on page. 59 of the attached manual
    [MOD EDIT] Link to schematic - https://www.badcaps.net/forum/troubl...ematic-and-bvd
  • shmyzdrek
    • Jun 2014
    • 6
    • Uzbekistan
    Hello. How many ohms there?
    • toty79
      • Mar 2019
      • 42
      • Italia
      0 ohm
      Thank you shmyzdrek
      • shmyzdrek
        • Jun 2014
        • 6
        • Uzbekistan
        I'm sorry but I have never seen 0 ohms on multimeters, there is always an measurement error. Okay it does not matter. You can unsolder the inductor and measure from both sides, the processor side and the source side.
        • toty79
          • Mar 2019
          • 42
          • Italia
          It has a small percentage 00.2 ohm and as if it were a net short, so you advise me to desolder PQ39 and measure outside the circuit and then measure the circuit itself without the inductor right?
          PC708 at its ends I detect the same measurement, could it be influenced by PQ39 or could it also be vice versa?​
          • shmyzdrek
            • Jun 2014
            • 6
            • Uzbekistan
            Desolder PL9 and check which side is short.
            I think SoC is dead, but we try...
            • toty79
              • Mar 2019
              • 42
              • Italia
              Dissaldare PL9 e verificare quale lato è corto.
              Penso che il SoC sia morto, ma ci proviamo...
              Once PL9 has been desoldered, the short circuit remains on PQ39 and also on PC708, another piece of advice Thank you very much 1) PC708 desoldered out of circuit and fine, the short remains on the PCB and PQ39 2) PQ39 desoldered externally the circuit and not shorted, the short remains on the PCB Sounds more serious than expected, thanks​
              • toty79
                • Mar 2019
                • 42
                • Italia
                With PL9 removed from the circuit on the CPU CORE side I have a 0.02 ohm resistor short circuit to gnd, so I assume that the game is over with a fried CPU, I'm wrong, is there still hope?
                • rddube
                  Lenovo L490 Ram voltage circuit malfunction
                  by rddube
                  Hello friends,
                  Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
                  I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
                  07-15-2025, 04:41 PM
                • twonk9098
                  Lenovo Legion 5 high fan spin turns off after 34 seconds
                  by twonk9098
                  I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                  I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                  I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                  I have tried a few new bios but exactly...
                  07-14-2024, 11:19 AM
                • keepread
                  Lenovo Ideapad S400 turns off when booting into any OS desktop
                  by keepread
                  I've been using this laptop for quite some time w/o battery. It has Linux installed. Recently, someone sent me a web link in an instant messenger. When I clicked on that link the laptop turned off that instant, before the browser even loaded to open it. Since then it turns off several seconds after I start it up and log into the Linux graphical desktop. I can see the mouse cursor moving around the screen when I draw my finger on the touchpad or move the mouse, and then a terminal window begins to load because the desktop autostarts it from last time, and then I hear a pop from the speakers and...
                  12-18-2024, 08:32 AM
                • judamex
                  Lenovo Legion 5 Pro - NM-D601 REV1.0 Turns off with battery conected
                  by judamex
                  I have a Lenovo Legion 5 Pro laptop - NM-D601 REV1.0 when I connect the battery it turns off after 5 minutes of use, if I don't connect the battery the laptop can keep working perfectly, I have already checked the charging voltages and they are fine, no I know if any mosfet is not working well, how can I know?
                  07-04-2024, 01:53 AM
                  Lenovo 3000 Series Schematic
                  Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                  3000 C100 laptop with Braille keyboard
                  Lenovo 3000 C
                  C100, C200 - 15-inch XGA screen
                  Lenovo 3000 N
                  N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                  N500 - 15.4 inch screen.
                  Lenovo 3000 V
                  V100, V200 - 12.1-inch WXGA models
                  Lenovo 3000 G
                  G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                  10-04-2024, 06:05 AM
