VPCSB no audio
  • silvernadal
    • Oct 2013
    • 14
    • España
    VPCSB no audio
    Hi¡
    I have a sony Vpcsb1z9e and it works good but I don´t have audio by speakers or headphones, but HDMI yes.
    I wanted to know if anyone has happened and how to fix it.
    I check the cables and fills good, and I have another plate where is the chip audio and nothing, maybe the error is in the mainboard.
    Thanks for your help, excuse my english.
  • lord
    • May 2011
    • 319
    • Croatia
    Re: VPCSB no audio
    Check Audio IC.
    • Pragmatiko
      • Jul 2013
      • 468
      • IT
      Re: VPCSB no audio
      Originally posted by silvernadal
      Hi¡
      which bios version have?
      • lefos
        • Nov 2013
        • 321
        • Greece
        Re: VPCSB no audio
        Are you sure that it isn't driver / os related? Have you tried on a clean install?
        • silvernadal
          • Oct 2013
          • 14
          • España
          Re: VPCSB no audio
          Thanks for reply.
          I install a original windows 7, on a clean install, and on ubuntu, and nothing happened.
          • silvernadal
            • Oct 2013
            • 14
            • España
            Re: VPCSB no audio
            Versión y fecha de BIOS INSYDE R0120H4, 10/02/2011
            Versión de SMBIOS 2.6
            • silvernadal
              • Oct 2013
              • 14
              • España
              Re: VPCSB no audio
              Realtek High Definition Audio Driver, Version 6.0.1.6225 for Microsoft® Windows® 7
              • alihomee
                • Dec 2012
                • 1576
                • malaysia
                Re: VPCSB no audio
                frist try with orignal driver
                • silvernadal
                  • Oct 2013
                  • 14
                  • España
                  Re: VPCSB no audio
                  Hello.
                  I have already installed the original drivers, downloaded from the official website of sony.
                  The fault seems more of hardware than software, wondering because I've seen more people that happened, but I have not seen the solution.
                  • silvernadal
                    • Oct 2013
                    • 14
                    • España
                    Re: VPCSB no audio
                    The audio ic is in another plate, and I have two. The same problem are in both plates.
                    Maybe the problem are in the HM65, who control IHDA. I made a reflow and nothing happened.
                    Do you think if I replace this chip could fix it? I have another same.
                    Or check the IHDA circuit before?
                    Thanks.
                    • Pragmatiko
                      • Jul 2013
                      • 468
                      • IT
                      Re: VPCSB no audio
                      Thanks.
                      But have speaker icon?
                      • silvernadal
                        • Oct 2013
                        • 14
                        • España
                        Re: VPCSB no audio
                        Yes, I have. The sound aparently is working.
                        • sorin_mirza
                          • Feb 2014
                          • 5
                          • Spania
                          Re: VPCSB no audio
                          write me at sorinmirza @ gmail . com for solution to your problem
                          • spidey
                            climbs
                            • Dec 2012
                            • 644
                            • Cyprus
                            Re: VPCSB no audio
                            change audio out jack. or first try applying wd-40 or something similar to jack first.
                            • silvernadal
                              • Oct 2013
                              • 14
                              • España
                              Re: VPCSB no audio
                              Hello. Thanks for responding.
                              The problem is not in the jack, since I have another whole keyboard, including the sound card, speakers and jack.
                              The problem is the motherboard, but not how to look at it, if I might say in the schemes corresponding page the audio circuit and revised it, or that's what sends the signal to the audio chip.
                              • jtamad44
                                • Apr 2013
                                • 145
                                • israel
                                Re: VPCSB no audio
                                why don't you share bro.
                                • samson7point1@yahoo.com
                                  Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                                  by samson7point1@yahoo.com
                                  The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                                  The player processes the audio signal using two different reference frequencies. The "R"...
                                  04-30-2024, 11:22 AM
                                • estabilito
                                  ProBook 650 g2 audio/headphones problem
                                  by estabilito
                                  I have problem with probook 650 g2 - laptop shows connected headphones Even without them. If i pług headphone Jack - computer show disconnected headphones. Speakers work when i change sound output.
                                  I replaced Jack board - nothing changed. Computer shows connected headphones even without Jack board connected to motherboard.
                                  02-01-2023, 12:51 PM
                                • i_am_patch
                                  Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
                                  by i_am_patch
                                  Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
                                  04-30-2024, 08:20 PM
                                • MOSSEP
                                  Monitor Audio RSW12 - Green light but no audio
                                  by MOSSEP
                                  Hi
                                  Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                  Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                                  The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                  I have already tried replacing all of the...
                                  01-26-2025, 08:18 AM
                                • grimacelord
                                  MacBook Air 2337 - Right I/O Board Audio IC - Alternative Replacement?
                                  by grimacelord
                                  I'm working on a MacBook Air A2337 that had liquid damage on the right I/O board. I ultrasonic cleaned the board and it all functions except the computer has no audio. I tried reballing the audio IC which is TAS5770AC0, but that did not restore audio. I could just replace the entire board, but I wanted to see if replacing the audio IC would fix it first. Mouser has a similar audio IC in stock which is TAS5770LC0YFFR, but I wasn't sure if it is compatible. I was just wondering if anyone knew if I could use the one from mouser as an acceptable replacement or if I need to purchase...
                                  12-11-2023, 11:13 AM
